My VHDL code -Controller for roller-blinds DC motor
FlyingDutch
Advanced Member level 1
Bydgoszcz - Poland
Hello Everybody,
I am new to this forum and to "programmable logic" so I would like to say Hello :roll: to forum members and ask for indulgence. I am learning VHDL and FPGA's for about a half of year. I had finished only one my own project - "Controller for roller-blinds with 12V DC motor". Project is written in VHDL for Xilinx Spartan3A
(for synthesis I am using ISE Webpack 14.7) - more precisely for "Elbert V2" board (and MOSFET bridge as a driver for 12V DC motor). Here is link to this board:
https://numato.com/product/elbert-v2-spartan-3a-fpga-development-board
There is three buttons:
- one for starting closing of rollers
- one for starting opening for rollers
- reset (for reseting error state - for example overloading of motor)
There are also few sensors:
- analog comparator for detecting to much current of motor
- two final sensor (position of rollers: end position and start position)
I am using pwm generator (core from opencores.org) for generating of 'soft-start' and 'soft-stop' of DC motor for avoiding overvoltage of motor. The major component is a state-machine steering most of others components. The project is practically deployed in my flat and is working OK (before I had write bench-tests for veryfiing the correctness of project). I also have simple one way comunication from controller (FPGA) over RS-485 protocol and converters UART-RS485. The FPGA controller is sending status vector (4 bit of his internal state) to Arduino UNO with small OLED display.
Here is my major project entity:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity Project is
    Port ( CLK : in  STD_LOGIC;
           RST : in  STD_LOGIC;
           b1 : in  STD_LOGIC;--button zamykaj
           b2 : in  STD_LOGIC;--button otwieraj
           krancEND : in  STD_LOGIC;--wyłącznik krancow
           krancPOC : in  STD_LOGIC;--wyłącznik krancow
           OVERLOAD : in  STD_LOGIC;--z komparatora (za duży prąd płynie przez silnik)
              brakZasilaniaCz : in  STD_LOGIC;--Brak zasilania czujnikow (aktywne 0)
              zdalneZamykanie : in  STD_LOGIC;--Zdalne zamykanie drzwi(aktywne 0)
           DIRPIN : inout  STD_LOGIC;
           SLPPIN : out  STD_LOGIC;
           AWARIA : out  STD_LOGIC;--Aktywne 1
              STATUS : out STD_LOGIC_VECTOR (3 downto 0);--Opis stanu ukladu (Praca/Awaria)
           LEDOTWARTE : out  STD_LOGIC;
           LEDZAMKNIETE : out  STD_LOGIC;
           LEDPRACA : out  STD_LOGIC;
           LEDAWARIA : out  STD_LOGIC;
              WyjPWM : out  STD_LOGIC_VECTOR (0 downto 0)
              );--wyjscie pwm na mostek MOSFET
end Project;
architecture Behavioral of Project is
    component divider is
       Port ( clk : in  STD_LOGIC;
              clk_out : inout  STD_LOGIC := '0');--clk_out 1MHZ
   end component;
   component debounce is
       port (   clk    : IN  STD_LOGIC;  --input clock
                    button  : IN  STD_LOGIC;  --input signal to be debounced
                    result  : OUT STD_LOGIC); --debounced signal
   end component;
   component DMASM is
           RST : in  STD_LOGIC;
           bt1 : in  STD_LOGIC;--btn zamykanie
           bt2 : in  STD_LOGIC;--btn otwieranie
              krancEND : in  STD_LOGIC;--active 0
              krancPOC : in  STD_LOGIC;--active 0
              OVERLOAD : in  STD_LOGIC;--active 0 (przeciazenie silnika)
              TIM2LONGZ : in  STD_LOGIC;--Timer operacja trwa za dlugo(zamykanie)
              TIM2LONGO : in  STD_LOGIC;--Timer operacja trwa za dlugo(otwieranie)
              NoPowerSensors : in  STD_LOGIC;--Brak zasilania czujnikow (aktywne 0)
              RemoteZamykanie : in  STD_LOGIC;--Zdalne zamykanie drzwi(aktywne 0)
           DIRPIN : out  STD_LOGIC;--Direction Motor ( 0 - FORWARD)
           SLPPIN : out  STD_LOGIC;--SLEEP PIN Mostek (0 - mostek zablokowany)
           pb1_Zam : out  STD_LOGIC;--gdy 0 zamykanie
           pb2_Otw : out  STD_LOGIC;--gdy 0 otwieranie
              blokada_Zam : out  STD_LOGIC;--gdy 0 blokada
           blokada_Otw : out  STD_LOGIC;--gdy 0 blokada
              SELO : out STD_LOGIC_VECTOR (1 downto 0);--wybor pwm dla multiplexera
              AWARIA : out  STD_LOGIC;--gdy 1 awaria ukladu
              STATUSO : out STD_LOGIC_VECTOR (3 downto 0);--Opis stanu ukladu (Praca/Awaria)
              LEDZAMKNIETE : out  STD_LOGIC;--gdy 1 LED zamkniete
              LEDOTWARTE : out  STD_LOGIC;--gdy 1 LED otwarte
              LEDPRACA : out  STD_LOGIC;--gdy 1 LED Zamykanie/otwieranie
              LEDAWARIA : out  STD_LOGIC);--gdy 1 LED awaria;
  end component;
 component WEKTORY_WYPELNIEN is
       port ( clk :in std_logic;
         pushB :in std_logic;
            blokada :in std_logic;
            rst : in  STD_LOGIC; --aktywne 0
            timerO : out std_logic;
         data : out std_logic_vector(7 downto 0) );
 end component;
 component WEKTORY_REVERSE is
 end component;
   component pwm is
           reset_n : in  STD_LOGIC;
           ena : in  STD_LOGIC;
           duty : in  STD_LOGIC_VECTOR (7 downto 0);
           pwm_out : out  STD_LOGIC_VECTOR (0 downto 0);
           pwm_n_out : out  STD_LOGIC_VECTOR (0 downto 0));
  end component;
 component mux4to1 is
            Port ( SEL : in  STD_LOGIC_VECTOR (1 downto 0); -- select input
           A   : in  STD_LOGIC_VECTOR (0 downto 0);  -- inputs
              B   : in  STD_LOGIC_VECTOR (0 downto 0);
              C   : in  STD_LOGIC_VECTOR (0 downto 0);
              D   : in  STD_LOGIC_VECTOR (0 downto 0);
           X   : out STD_LOGIC_VECTOR (0 downto 0)); -- output
 end component;
   signal data1_signal :STD_LOGIC_VECTOR (7 downto 0);
    signal data2_signal :STD_LOGIC_VECTOR (7 downto 0);
    signal data3_signal :STD_LOGIC_VECTOR (7 downto 0);
    signal data4_signal :STD_LOGIC_VECTOR (7 downto 0);
    signal b1_DB :STD_LOGIC;
    signal b2_DB :STD_LOGIC;
    signal clk_1MHz :STD_LOGIC;
    signal pwm1_out :STD_LOGIC_VECTOR (0 downto 0);
    signal pwm2_out :STD_LOGIC_VECTOR (0 downto 0);
    signal pwm3_out :STD_LOGIC_VECTOR (0 downto 0);
    signal pwm4_out :STD_LOGIC_VECTOR (0 downto 0);
    signal pwm1_n_out :STD_LOGIC_VECTOR (0 downto 0);
    signal pwm2_n_out :STD_LOGIC_VECTOR (0 downto 0);
    signal pwm3_n_out :STD_LOGIC_VECTOR (0 downto 0);
    signal pwm4_n_out :STD_LOGIC_VECTOR (0 downto 0);
    --signal WyjPWM :STD_LOGIC_VECTOR (0 downto 0);
    signal pb1_Zam :STD_LOGIC;
    signal pb2_Otw :STD_LOGIC;
    signal blokada_Zam :STD_LOGIC;
    signal blokada_Otw :STD_LOGIC;
    signal SELO :STD_LOGIC_VECTOR (1 downto 0);
    signal TIM2LONGZ :STD_LOGIC;
    signal TIM2LONGO :STD_LOGIC;
    --signal brakZasilaniaCz :STD_LOGIC;
    --signal zdalneZamykanie :STD_LOGIC;
begin
    C1: divider port map (CLK, clk_1MHz);
    C2: debounce port map (clk_1MHz, b1, b1_DB);
    C3: debounce port map (clk_1MHz, b2, b2_DB);
    C4: WEKTORY_WYPELNIEN port map (clk_1MHz, pb1_Zam, blokada_Zam, RST, TIM2LONGZ, data1_signal);
    C5: WEKTORY_WYPELNIEN port map (clk_1MHz, pb2_Otw, blokada_Otw, RST, TIM2LONGO, data2_signal);
    C6: DMASM  port map   (clk_1MHz,
                                  RST,
                                  b1_DB,
                                  b2_DB,
                                  krancEND,
                                  krancPOC,
                                  OVERLOAD,
                                  TIM2LONGZ,
                                  TIM2LONGO,
                                  brakZasilaniaCz,
                                  zdalneZamykanie,
                                  DIRPIN,
                                  SLPPIN,
                                  pb1_Zam,
                                  pb2_Otw,
                                  blokada_Zam,
                                  blokada_Otw,
                                  SELO,
                                  AWARIA,
                                  STATUS,
                                  LEDZAMKNIETE,
                                  LEDOTWARTE,
                                  LEDPRACA,
                                  LEDAWARIA);
    C7: pwm port map (clk_1MHz, RST, '1', data1_signal, pwm1_out, pwm1_n_out);
   C8: pwm port map (clk_1MHz, RST, '1', data2_signal, pwm2_out, pwm2_n_out);
    C9: WEKTORY_REVERSE port map (clk_1MHz, blokada_Zam, data3_signal);
    C10: WEKTORY_REVERSE port map (clk_1MHz, blokada_Otw, data4_signal);
    C11: pwm port map (clk_1MHz, RST, '1', data3_signal, pwm3_out, pwm3_n_out);
   C12: pwm port map (clk_1MHz, RST, '1', data4_signal, pwm4_out, pwm4_n_out);
    C13: mux4to1 port map (SELO, pwm1_out, pwm2_out, pwm3_out, pwm4_out, WyjPWM);
end Behavioral;
Below entity WEKTORY_WYPELNIEN for generating changing PWM signal (soft-start for example):
library IEEE;
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity WEKTORY_WYPELNIEN is
  generic (
        NBit : natural := 30;
        Div : natural := 3_000_000 --3s
end WEKTORY_WYPELNIEN;
 architecture BEHAVE of WEKTORY_WYPELNIEN is
  signal ADDRESS :integer range 0 to 32 :=0;
   signal TEMP :integer range 0 to 10_000_000 :=0; -- liczba impulsów
   -- jaka ma minąć zanim dojdzie do zmiany adresu
      signal GENERACJA_SERII_WEKTOROW : std_logic :='0';
   -- okreslanie kiedy ma sie zaczac generacja serii wektorow
    signal GENERACJA2_SERII_WEKTOROW : std_logic :='0';
   signal KONIEC_GENERACJI_WEKTOROW : std_logic :='0';
   -- okreslenie kiedy koniec generacji serii wektorow
   signal OPOZNIENIE_BUTTONA :integer range 0 to 1_000_000 :=0;
    signal cnt: std_logic_vector(Nbit -1 downto 0) := (others=>'0'); --licznik timera czasu otwarcia
    type mem is array ( 0 to 2**5 - 1) of std_logic_vector(7 downto 0);
  constant my_Rom : mem := (
    0  => "00000011",
    1  => "00000111",
    2  => "00001110",
    3  => "00001111",
    4  => "00010101",
    5  => "00011100",
    6  => "00100011",
    7  => "00010000",
    8  => "00101010",
    9  => "00110001",
    10 => "00111000",
    11 => "00111111",
    12 => "01000110",
    13 => "01001101",
    14 => "01010100",
    15 => "01011011",
    16 => "01100010",
    17 => "01101001",
    18 => "01110000",
    19 => "01110111",
    20 => "01111110",
    21 => "10000101",
    22 => "10001100",
    23 => "10010011",
    24 => "10011010",
    25 => "10100001",
    26 => "10101000",
    27 => "10010111",
    28 => "10110110",
    29 => "11011001",
    30 => "11100000",
    31 => "11111111"
begin
    --  ZWIEKSZANIE ADRESU KOLEJNYCH WEKTOROW WYPELNIEN
   process (CLK)
   begin
      if rising_edge(CLK) then
         if (rst= '0') then
               ADDRESS <= 0;
                TEMP <= 0; -- liczba impulsów
               GENERACJA_SERII_WEKTOROW <= '0';
             GENERACJA2_SERII_WEKTOROW <= '0';
            KONIEC_GENERACJI_WEKTOROW <= '0';
            OPOZNIENIE_BUTTONA <= 0;
            else
              -- SPRAWDZENIE CZY PRZYCISK JEST NACISNIETY CZY NIE
              if (pushB = '0') then -- lub '0' gdy po nacisnieciu
              -- przycisku generowane jest przerwanie
                  if (OPOZNIENIE_BUTTONA < 10_000) then
                  -- opoznienie dzialania przycisku, aby za szybko
                  -- nie szla generacja po nacisnieciu
                     OPOZNIENIE_BUTTONA <= OPOZNIENIE_BUTTONA + 1;
                  else
                     if (KONIEC_GENERACJI_WEKTOROW = '0') then
                     -- jesli jest koniec to nie wznawiaj generacji
                         GENERACJA_SERII_WEKTOROW <= '1';
                     end if;
                  end if;
              else
                  -- zeruj  koniec, gdy przycisk jest puszczony
                  -- zeruj opoznienie przycisku
              end if;
              -- GENERACJA SERII WEKTOROW PO NACISNIECIU PRZYCISKU
              -- ORAZ OKRESLENIE JEJ KONCA PO JEJ WYKONANIU
              if (GENERACJA_SERII_WEKTOROW = '1') then
                        if (TEMP < 20_000) then --okolo 0,02 s : 0,64 s calosc
                      TEMP <= TEMP + 1;
                        else
                      TEMP <= 0;
                      if (ADDRESS < 31) then
                         ADDRESS <= ADDRESS + 1;
                     else
                         KONIEC_GENERACJI_WEKTOROW <= '1';
                                 GENERACJA2_SERII_WEKTOROW <= '1';
                         ADDRESS <= 0;
                     end if;
                        end if;
              else
                 TEMP <= 0;
              end if;
              end if;
      end if;
   end process;
      -- GENEROWANIE WEKTOROW WYPELNIEN
   process (CLK)
   begin
        if (rst= '0') then
            DATA <= "00000000";
        elsif (blokada = '0') then
            DATA <= "00000000";
        else
        if (GENERACJA_SERII_WEKTOROW = '1') and (GENERACJA2_SERII_WEKTOROW = '0')  then-- gdy trwa generacja             -- wektorow
               DATA <= my_rom(ADDRESS);
         else if     (GENERACJA2_SERII_WEKTOROW = '1') then
                    DATA <= "11100000";
        else  -- gdy generacja nie trwa
          DATA <= "00000000";
             end if;
         end if;
    end if;
    end if;
   end process;
       -- Timer do odliczania czasu otwierania
    process(CLK)
    begin
        if (CLK'event and CLK='1') then
          if ((rst = '0') or (blokada = '0')) then
                cnt <= (others => '0');
                timerO  <= '0';
          else
            if ((GENERACJA_SERII_WEKTOROW = '1') or (GENERACJA2_SERII_WEKTOROW = '1')) then
                if cnt < Div then
                    --timerO <= '0';--Check this
                    cnt <= cnt+1;
                else
                    cnt <= (others=>'0');
                    timerO <= '1';
                end if;
            end if;
          end if;
        end if;
   end process;
end BEHAVE;
And last example: state-machine:
library IEEE;
use IEEE.NUMERIC_STD.ALL;
entity DMASM is
    Port ( CLK : in  STD_LOGIC;--Zegar
           RST : in  STD_LOGIC;--Reset
              AWARIA : out  STD_LOGIC;--gdy 0 awaria ukladu
end DMASM;
architecture BEHAVE of DMASM is
        type STATE is (S0Otwarte, S1ZamykanieLocal, S2Zamkniete, S3OtwieranieLocal, S4ZamykanieRemote,
                              S5Overload, S6TooLongOper, S7NoPowerSensors, S8PositionError,
                              S9UnknowError, S10Awaria, S11DomkZamykanie, S12DomkOtwieranie,
                              S13BetweenEdges);
       signal CURRENT_STATE, NEXT_STATE: STATE;
         constant LICZNIK_LIMIT : integer := 2_000_000; -- 2s deklaracja stalej z max wart licznika
         signal licznik : unsigned(24 downto 0); -- definicja syg lokalnego
begin
SEQ: process (RST, CLK, krancPOC, krancEND, OVERLOAD, NoPowerSensors, RemoteZamykanie)
begin
        if (RST = '0') then
             licznik <= b"0000000000000000000000000";
             if ((krancPOC = '0') and (krancEND = '1')) then
             CURRENT_STATE <= S0Otwarte;
           else if ((krancPOC = '1') and (krancEND = '0')) then
             CURRENT_STATE <= S2Zamkniete;
                elsif ((krancPOC = '1') and (krancEND = '1')) then
             CURRENT_STATE <= S13BetweenEdges;
                end if;
           end if;
        elsif (CLK' event and CLK = '1' ) then
                if (CURRENT_STATE = S11DomkZamykanie) and (NEXT_STATE = S11DomkZamykanie) then
                    licznik <= licznik + 1;
                     if licznik = LICZNIK_LIMIT then
                     end if;
                elsif (CURRENT_STATE = S12DomkOtwieranie) and (NEXT_STATE = S12DomkOtwieranie) then
                     end if;
                elsif (OVERLOAD = '0') then--tu obsluga bledow dla all states
                     CURRENT_STATE <= S5Overload;
                elsif (NoPowerSensors = '0') then
                     CURRENT_STATE <= S7NoPowerSensors;
                elsif ((krancEND = '0') and (krancPOC = '0')) then
                     CURRENT_STATE <= S8PositionError;
                else
                CURRENT_STATE <= NEXT_STATE;
                end if;
        end if;
end process;
COMB: process (CURRENT_STATE, RST, bt1, bt2, krancEND, KrancPOC,
                   TIM2LONGZ, TIM2LONGO)
begin
case CURRENT_STATE is
    when S0Otwarte => DIRPin <= '0';
            SLPPin <= '0';--mostek zablokowany
            pb1_Zam <= '1';
            pb2_Otw <= '1';--blokada ALL
            blokada_Zam <= '0';
            blokada_Otw <= '0';
            SELO <= "11";
            AWARIA <= '0'; --klawisz nieaktywny
            LEDZAMKNIETE <= '0';
            LEDOTWARTE <= '1';
            LEDPRACA <= '0';
            LEDAWARIA  <= '0';
            STATUSO <= "0000";
            if (bt1 = '0') then
                 NEXT_STATE <= S1ZamykanieLocal;
              elsif  (RemoteZamykanie = '0') then
                  NEXT_STATE <= S4ZamykanieRemote;
           elsif ((krancPOC = '0') and (krancEND = '1')) then
             NEXT_STATE <= S0Otwarte;
           elsif ((krancPOC = '1') and (krancEND = '0')) then
             NEXT_STATE <= S2Zamkniete;
                NEXT_STATE <= S13BetweenEdges;
           end if;
    when S1ZamykanieLocal => DIRPin <= '0';
            SLPPin <= '1';--FORWARD,MOSTEK OTWARTY
            pb1_Zam <= '0';
            pb2_Otw <= '1';
            blokada_Zam <= '1';
            blokada_Otw <= '0';
            SELO <= "00";
            LEDOTWARTE <= '1';
            LEDPRACA <= '1';
            LEDAWARIA  <= '0';
            STATUSO <= "0001";
         if (bt2 = '0')    then
           NEXT_STATE <= S3OtwieranieLocal;
           else
              if ((krancEND = '0') and (krancPOC = '1')) then
                  NEXT_STATE <= S11DomkZamykanie;
             elsif (TIM2LONGZ = '1') then
               NEXT_STATE <= S6TooLongOper;
           else
           end if;
           end if;
    when S2Zamkniete => DIRPin <= '1';
            SLPPin <= '0';
            pb1_Zam <= '1';
            blokada_Zam <= '0';
            blokada_Otw <= '0';
            SELO <= "10";
            LEDZAMKNIETE <= '1';
            LEDOTWARTE <= '0';
            LEDPRACA <= '0';
            LEDAWARIA  <= '0';
            STATUSO <= "0010";
        if (bt2 = '0')then --Button otwieranie
        else
              end if;
        end if;
    when S3OtwieranieLocal => DIRPin <= '1';
            SLPPin <= '1';
            pb1_Zam <= '1';
            pb2_Otw <= '0';--BACKWARD,MOSTEK OTWARTY
            blokada_Zam <= '0';
            blokada_Otw <= '1';
            SELO <= "01";
            LEDOTWARTE <= '0';
            LEDPRACA <= '1';
            LEDAWARIA  <= '0';
            STATUSO <= "0011";
          if (bt1 = '0') then --Button zamykanie
          elsif ((krancPOC = '0') and (krancEND = '1')) then  -- zmiana stanu czuj. krancowych
              NEXT_STATE <= S12DomkOtwieranie;
          else -- gdy nie ma awarii
             if (TIM2LONGO = '1') then  -- gdy jest awaria
           else
          end if;
          end if;
    when S4ZamykanieRemote => DIRPin <= '0';
            pb1_Zam <= '0';
            pb2_Otw <= '1';
            blokada_Zam <= '1';
            blokada_Otw <= '0';
            SELO <= "00";
            LEDOTWARTE <= '1';
            LEDPRACA <= '1';
            LEDAWARIA  <= '0';
            STATUSO <= "0100";
            if (bt2 = '0') then --klawisz otwieranie
           elsif ((krancEND = '0') and (krancPOC = '1')) then
           else
             if (TIM2LONGZ = '1') then  -- gdy jest awaria
           else
           end if;
        end if;
     when S5Overload => DIRPin <= '1';--stan S4Awaria
            SLPPin <= '0';--blokada mostka
            pb1_Zam <= '1';
            pb2_Otw <= '1';--klawisze nieaktywne
            blokada_Zam <= '0';
            blokada_Otw <= '0';
            AWARIA <= '1'; --sygnal aktywny
            LEDOTWARTE <= '0';
            LEDPRACA <= '0';
            LEDAWARIA  <= '1';
            STATUSO <= "1000";
            NEXT_STATE <= S10Awaria;
     when S6TooLongOper => DIRPin <= '1';--stan S4Awaria
            pb1_Zam <= '1';
            blokada_Zam <= '0';
            blokada_Otw <= '0';
            LEDOTWARTE <= '0';
            LEDPRACA <= '0';
            LEDAWARIA  <= '1';
            STATUSO <= "1010";
     when S7NoPowerSensors => DIRPin <= '1';--stan S4Awaria
            pb1_Zam <= '1';
            blokada_Zam <= '0';
            blokada_Otw <= '0';
            LEDOTWARTE <= '0';
            LEDPRACA <= '0';
            LEDAWARIA  <= '1';
            STATUSO <= "1001";
     when S8PositionError => DIRPin <= '1';--stan S4Awaria
            pb1_Zam <= '1';
            blokada_Zam <= '0';
            blokada_Otw <= '0';
            LEDOTWARTE <= '0';
            LEDPRACA <= '0';
            LEDAWARIA  <= '1';
            STATUSO <= "1011";
     when S9UnknowError => DIRPin <= '1';--stan S4Awaria
            pb1_Zam <= '1';
            blokada_Zam <= '0';
            blokada_Otw <= '0';
            LEDOTWARTE <= '0';
            LEDPRACA <= '0';
            LEDAWARIA  <= '1';
            STATUSO <= "1100";
     when S10Awaria => DIRPin <= '1';--stan S10Awaria
            pb1_Zam <= '1';
            blokada_Zam <= '0';
            blokada_Otw <= '0';
            LEDOTWARTE <= '0';
            LEDPRACA <= '0';
            LEDAWARIA  <= '1';
   when S11DomkZamykanie => DIRPin <= '0';
            SLPPin <= '1';
            pb1_Zam <= '1';
            blokada_Zam <= '0';
            blokada_Otw <= '0';
            SELO <= "10";
            LEDOTWARTE <= '1';
            LEDPRACA <= '1';
            LEDAWARIA  <= '0';
            STATUSO <= "0101";
            else
            end if;
  when S12DomkOtwieranie => DIRPin <= '1';
            SLPPin <= '1';
            pb1_Zam <= '1';
            blokada_Zam <= '0';
            blokada_Otw <= '0';
            SELO <= "11";
            LEDOTWARTE <= '0';
            LEDPRACA <= '1';
            LEDAWARIA  <= '0';
            STATUSO <= "0110";
            else
            end if;
   when S13BetweenEdges => DIRPin <= '0';
            pb1_Zam <= '1';
            blokada_Zam <= '0';
            blokada_Otw <= '0';
            SELO <= "11";
            LEDOTWARTE <= '0';
            LEDPRACA <= '0';
            LEDAWARIA  <= '0';
            STATUSO <= "0111";
            if (bt2 = '0') then --Button otwieranie
              elsif (bt1 = '0') then --Button zamykanie
           else
              end if;
           end if;
    when others => STATUSO <= "1010";--sygnalizacja TooLongOper
    end case;
  end process;
end BEHAVE;
For last month I had started to learn myself Xilinx Vivado. I also had purchased a 'larger' FPGA board - "Digilent Cmod-A7' board:
https://reference.digilentinc.com/reference/programmable-logic/cmod-a7/start?redirect=1id=cmod_a7/cm
with Xilinx Artix-7 FPGA
and I would like to experiment with Xilinx soft-CPU Microblaze.
I am also interested with HLS (High Level Synthesis) and "Vivado HLS".
Best Regards
Your post was moved to the Do-it-yourself section, in case readers wish to generate discussion.
We invite you to create your own blog page. (Edaboard provides each member with his individual blog area.)
Sorry, your weblinks are not working correctly.
Schematics, photographs, etc., can be uploaded as Edaboard attachments, in normal circumstances. Click the Rules tab to find more information.
Well done on your project.
If I may ask, what is it you're after? Project resources/templates or ideas? Project collaboration?
Regards,
thanks ;)
I haven't any precised plans on future. I wolud like to develop my skills regarding PLDs, next step are Soft-CPU and SoCs with FPGAs.
Kind Regards
