ivlsi
Advanced Member level 3
[Altera.QuartusPrime] VHDL-2008 'context' clause of the packages -> not recognized?
Hi All,
Does Altera Quartus Prime support VHDL-2008 'context' clause of the packages?
I'm receiving the following error:
for the following file contents:
It seems Questa Prime does not recognize the context keyword...
So, how to fix/workaround?
Thank you!
Hi All,
Error (10500): VHDL syntax error at t_all.vhd(6) near text "context"; expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration"
context t_all is
library pkgs;
use pkgs.t_bit.all;
use pkgs.t_lpfsm.all;
use pkgs.t_des.all;
use pkgs.t_fifo.all;
use pkgs.t_ports.all;
use pkgs.t_tbl.all;
end context t_all;
Thank you!
