[SOLVED] ultrasonic reading error
arunbharathi.arasu
Full Member level 2
Chennai, Tamil Nadu, India
Hi friends,
I tried ultrasonic coding. But I cannot receive data from ultrasonic.
I am using PIC18F4550 controller.
Here is code:
#include<stdio.h>
#include <string.h>
#include"uart.h"
#define _XTAL_FREQ 20000000
#define trigger RD2
#define echo RD3
void port_init()
   TRISA1=0;
   TRISD3=0XFF; //echo
   TRISD2=0X00; //trigger
   T1CON = 0x80;
   TMR1IF = 0;
   TMR1=0;
void delay(unsigned int de)
    unsigned int maxde,minde;
    for(maxde=0;maxde<de;maxde++)
        for(minde=0;minde<453;minde++);
void Delay10Us()
    int dCnt;
    for(dCnt=0;dCnt<3;dCnt++);
void trigger_US()
    trigger=1;
      __delay_us(10);
    trigger=0;
    __delay_us(10);
    while(echo == 0);
    TMR1=0;
    TMR1ON=1;
    while(echo == 1 && !TMR1IF);
    Time=TMR1;
    TMR1ON=0;
    Distance = ((float)Time/117.00);
void main()
    port_init();
    port1_init();
    UART_init();
   while(1)
       RA1=1;  //led on
       delay(2000);
       RA1=0;    // led off
       delay(2000);
       trans_string("\n test");   // test uart
       trigger_US();
       sprintf(Total_distance,"%.03f",Distance);
       trans_string(Total_distance);
please tell me if any error / correction.
hello,
What compiler are you using ?
You can not affect a Byte to a bit ..
in MikroC syntaxe :
TRISA1_bit=0;
TRISD3_bit=1; //echo (inpout)
TRISD2_bit=0; //trigger (out put)
and use LATA instead of PORT for output
#define trigger LATD2_bit
#define echo PORTD3_bit
hi,
I am using Hi-tech C compiler.
So I have changed in to
#define echo RD3
Now it is working. thank you very much.
But why we have to mention LATD2, Is it consider as trigger?
YOU defined this as trigger !
You didn't show us your schematic,
but i suppose that this output is the commande to start the ultrasonic Burst of a HC-SR04 module (trigger input)
