which Wireless Communication Protocol should I use?
Nizar_Ib
Member level 1
I'm not familiar with IoT but I want to make a small project, includes two systems communicating with each other wirelessly, I'm talking about a range of 200-300 meter
Which protocol can I use here? started out from the assumption that I have enough power on the two PCB's.
I think you can use two esp8266 modules . they are cheap, easy to program with the arduino IDEand can reach that distance.
So it is WIFI, thanks.
now, what about longer ranges? I heard about GPRS and GSM.. how do they work? are they free to use?
The issue behind this question was not very clear, as there are several aspects to consider such as safety, speed, reliability, among other items.
The expression Wifi is more commonly used to designate a local network (understood in the initial question), whereas GPRS / GSM protocols are related to telephony operators, for which you will really have spent money to keep the service working. It should also be mentioned that the mechanics where the product will be placed has a deep effect on the range, which in some cases it is recommended to use modules that support the connection of external antennas.
