Results 1 to 6 of 6
    Full Member level 3
    Points: 1,761, Level: 9
    ctzof's Avatar
    Mar 2012
    Munich
    155
    1,761
    9
    I Q signals lower sampling rate
    According to this article https://www.dsprelated.com/showarticle/192.php by using IQ signals we have at the end the benifit that Each A/D converter operates at half the sampling rate of standard real-signal sampling. Can somebody explain why? I mean the signal has still the same BW.
    •   Alt6th December 2017, 12:23
      advertising
    Points: 241,334, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,884
    241,334
    100
    Re: I Q signals lower sampling rate
    The argument is referring to sampling rate, not signal bandwidth.
    If I understand right, it says that a signal with carrier fc can be either sampled with a single ADC at fs >= 2fc (Nyquist sampling) or quadrature sampled with two ADCs at fs = fc.
    •   Alt6th December 2017, 12:38
      advertising
    Full Member level 3
    ctzof's Avatar
    Mar 2012
    Munich
    155
    1,761
    9
    I don't think this is what he means. After all you can still sample in lower sampling rate than the Nyquist rate if you use undersampling techniques https://en.wikipedia.org/wiki/Undersampling.
    It has to do with spliting the signal to two ADCs and in that way the sampling rate is not 2B anymore but B. But still dont understand why.
    •   Alt6th December 2017, 13:47
      advertising
    Advanced Member level 3
    Points: 6,046, Level: 18
    Jul 2010
    Sweden
    784
    6,046
    18
    With IQ signals, positive and negative frequencies are not the same. This means that the represented range is -fs/2 to +fs/2, so the bandwidth is equal to fs.
    It is the baseband signal that is represented by the IQ samples. The carrier is not visible in the IQ "domain".
    A fixed value of the IQ baseband signal (= zero frequency) corresponds to the carrier frequency in the RF domain.
    Full Member level 3
    ctzof's Avatar
    Mar 2012
    Munich
    155
    1,761
    9
    Still don't get it. Supposed our signal has a BW of B as in Fig18 what is the sampling rate of each ADC and waht is the benifit over not-complex down convertion?
    •   Alt6th December 2017, 16:26
      advertising
    Jul 2010
    Sweden
    784
    6,046
    18
    The sample rate of each A/D is fs, as usual. With "not-complex" sampling the frequency goes from 0 to fs/2, which means that BW = fs/2.
    With complex IQ signals, the frequency goes from -fs/2 to fs/2, which means that BW = fs.
    Figure 18 assumes complex sampling. With non-complex sampling, both the negative and positive frequencies will map to the range 0 - fs/2, so they can't be separated.
