[SOLVED] concurrent vhdl code generating latches
rafimiet
Member level 5
I have to find maximum of a sequence. For that I have written a code below:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity threshold_calculator is
    GENERIC (word_length : INTEGER := 8);
    Port ( data1,data2 : in STD_LOGIC_VECTOR (word_length-1 downto 0);--input can be negative as well
           we1,we2 : in STD_LOGIC;-- Consider input for Max calculation or not
           max_coeff : out STD_LOGIC_VECTOR (word_length-2 downto 0));--- This is the maximum of sequence
end threshold_calculator;
architecture Behavioral of threshold_calculator is
    signal s1,s2,s4,s5 : SIGNED (word_length-1 downto 0);
    signal s3,s6,s7,s8 : SIGNED (word_length-2 downto 0);
    signal thrsh,thrsh1 : SIGNED (word_length-2 downto 0) := (OTHERS => '0');
begin
    ---- Get Magnitude of first input data ---
    s1 <= signed(data1) WHEN we1 = '1' ELSE
          (OTHERS => '0');
    s2 <= -s1;
    s3 <= s1(word_length-2 downto 0) WHEN data1(word_length-1) = '0' ELSE
          s2(word_length-2 downto 0);
    ---- Get Magnitude of second input data ---
    s4 <= signed(data2) WHEN we2 = '1' ELSE
          (OTHERS => '0');
    s5 <= -s4;
    s6 <= s4(word_length-2 downto 0) WHEN data2(word_length-1) = '0' ELSE
          s5(word_length-2 downto 0);
    --- Compare the two inputs ---
    s7 <= s3 WHEN s3 > s6 ELSE
          s6;
    s8 <= s7;
    --- Comapare with already maximum yielded ---
    thrsh <= s7 WHEN s8 > thrsh1 ELSE
             UNAFFECTED;
    thrsh1 <= thrsh;
    max_coeff <= std_logic_vector(thrsh);
end Behavioral;
When I synthesize it I get the following ERROR:
[Synth 8-327] inferring latch for variable 'thrsh_reg'
It also affects my simulation which is very obvious. Please suggest me how to make it work in concurrent code. Because in sequential code, I know how to suppress it.
Line 34 and 35 implement a memory function, I presume intentionally. It's not possible without latches or registers.
The message is a synthesis warning, not an error. In the present code it's indicating potentially unsafe behavior. A safe maximum memory can be implemented with clocked registers.
If we use a process to replace Line 36 like this
process(clk)
begin
if clk'event anf clk = '1' then
thrsh1 <= thrsh;
end if;
end process;
Would it then fix the error?If not, please make me understand what you mean by memory function?
As reported by the warning, the latch is implemented for the conditional assignment to thrsh. Respectively this assignment must performed in an edge sensitive process.
Code C - [expand]
if rising_edge(clk) then
  if s7 > thrsh then
    thrsh <= s7;
  end if;
end if;
Superfluous signal copies omitted.
Your original code was a warning, not an error, but using latches are not recommended.
If your code:
thrsh <= s7 WHEN s8 > thrsh1 ELSE UNAFFECTED;
thrsh can only change when s8 > thrsh1, otherwise it stays at the same value - this requires memory, and hence the latch as no clock is involved.
To avoid latches, either synchronise the circuit (like you did) or ensure every signal is assigned a new value in all cases.
