spottymaldoon
Newbie level 5
I'm using a TI LMP7721 3-femtoamp bias current op amp to measure an extremely small current in an ion cell. I have it in inverting mode with a guard around the input, driven to follow the non-inverting input voltage. This works extremely well and gives me an output between +/-5V.
After some discussion in an earlier post relating to choice of a suitable AD converter I have fixed upon an Analog Devices AD7171 which uses the sigma-delta routine; has 16 bit resolution and a conversion rate of 125 S/s. It also has a differential input of +/-5v (with Vdd=Vref=5v).
I am proposing to pass the -5v rail voltage to the negative AD input and the amplifier output to the positive. Now, relative to ground, this may mean that there will sometimes be a negative voltage applied to the positive input (unless I apply bias which would be a pity since it then cuts my dynamic range).
Looking at the spec and absolute limits however I see this:
Does this kill my idea? If so my fall-back will be to ground the negative input and ensure the signal is suitably biassed. Your thoughts would be appreciated.
PHP:
Absolute AINx Voltage Limits GND − 0.03 VDD + 0.03
