How to use T flip flops in vdhl to simulate LED's blinking on/off
NickDefick
Newbie level 1
I am new to vhdl, I would like to modify this code to simulate 4 led's that the following:
0 = on
x = off
clock 1: 0000
clock 2: 000x
clock 3: 00xx
clock 4: 0xxx
clock 5: xxxx
clock 6: xxx0
clock 7: xx00
clock 8: x000
clock 9: loops the code back to what clock 1 is like.
This is what I have so far as far as code:
library IEEE;
use IEEE.std_logic_1164.all;
entity state_T is
    port(
        clock : in  std_logic;
        reset : in  std_logic;
        o     : out std_logic_vector(2 downto 0)
end state_T;
architecture arch of state_T is
    component T_ff
        port (
            clk   : in     std_logic;
            clear : in     std_logic;
            T     : in     std_logic;
            Q     : out    std_logic;
            Qbar  : out    std_logic
    end component;
    signal T3, T2, T1, T0, Q3, Q2, Q1, Q0, Q3bar, Q2bar, Q1bar, Q0bar: std_logic;
    begin
	 s3 : T_ff port map (
            clk   => clock,
            clear => reset,
            T     => T3,
            Q     => Q3,
            Qbar  => Q3bar
        s2 : T_ff port map (
            clk   => clock,
            clear => reset,
            T     => T2,
            Q     => Q2,
            Qbar  => Q2bar
        s1 : T_ff port map (
            clk   => clock,
            clear => reset,
            T     => T1,
            Q     => Q1,
            Qbar  => Q1bar
        s0 : T_ff port map (
            clk   => clock,
            clear => reset,
            T     => T0,
            Q     => Q0,
            Qbar  => Q0bar
	T3 <= (Q3bar and Q2)    or (Q3 and Q2bar);
        T2 <= (Q2bar and Q1)    or (Q2 and Q1bar);
        T1 <= (Q1bar and Q0)    or (Q1 and Q0bar);
        T0 <= (Q2bar and Q0bar) or (Q2 and Q0);
	O(3) <= Q3;
        O(2) <= Q2;
        O(1) <= Q1;
        O(0) <= Q0;
end arch;
any help would be great, maybe someone here could point me in the right direction.
Re: how to use T flip flops in vdhl to simulate LED's blinking on/off
I don't have an answer for you, but I recommend to use:
0 = off
1 = on
Because x = don't care.
How I'd solve it:
Pseudo code:
If (Q0...Q3 = 0000) OR (Q0...Q3 = 1111) then toggle Q0
Q1 = Q0
Q2 = Q1
Q3 = Q2
Klaus
tip #1: use d flip-flops
tip #2: build an FSM
