Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
  1. #21
    Newbie level 6
    Points: 89, Level: 1
    Sep 2017
    13
    89
    Re: AC DC full bridge power supply
    im very thankful Klaus, schmitt trigger it seems that yes i will giveup keeping TX1 and i will change the design ;) thank you guys
    •   Alt20th September 2017, 16:12
      advertising
  2. #22
    Points: 27,852, Level: 40
    Sep 2008
    cambridge
    5,851
    27,852
    40
    Do a 2 transistor forward converter for your 30v 5a.
    Upstream of that, do a BCM Boost pfc stage.
    ...BCM pfc stages are really easy
    ...remember to use a bridge rectifier to rectify the mains first...then go into the boost pfc.
    I think this is your smallest solution.
    •   Alt24th September 2017, 10:34
      advertising
  3. #23
    Newbie level 6
    Sep 2017
    13
    89
    Please learn to give useful informatins.
    --> we can not know what this means: is it 1cm x 1cm x 1cm or is it 1m x 1m x 1m...
    That´s not the problem of an autotransformer.
    In your case the 160VA autotransformer is as small as an 100W standard transformer.
    They have all form options than a standard transformer: toroidal, or standard, it may be PCB mount or not, potted or not... and so on.
    If an autotransformer is too big, then every low frequency transformer will be too big.
    Review the thread to see how many other options you have to generate 80V/2A AC from 230V AC. I see none.
    I doubt that repeatedly asking the same question will bring new results. (More than 440 times this thread has been viewed)
    I doubt that repeatedly refusing facts or posting unverified statements will bring you a step ahead.
    Honestly, I gave the best (smallest) possible solution that I know.
    hey Klaus Relaxe man, you are not obliged to reply me
