VHDL Instantiation in modelSim
hareeshP
Member level 3
Hi i have written a vhdl code along with the testbench..when i simulate it in the modelSim i don't get an expected result
The VHDL Code is given below
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
Library ieee;
    use ieee.std_logic_1164.all;
    entity PowerSeq is
        port(fpga_clk: in std_logic;
                Enable_Bias_1V, Enable_3V3, Enable_1P5V, Enable_1V: out std_logic;
                PG_3V3: in std_logic);
    end PowerSeq;
    architecture MPU_PowerSeq of PowerSeq is
        signal pon_state: integer:= 0;
    begin
        process(fpga_clk)
        begin
            if(rising_edge(fpga_clk)) then
                if(pon_state = 0) then
                    Enable_3V3 <= '1';
                    Enable_1P5V <= '1';
                    Enable_1V <= '0';
                    Enable_Bias_1V <= '1';
                    pon_state <= 1;
                end if;
                    if(pon_state = 1) then
                        if(PG_3V3 = '1') then
                            Enable_1V <= '1';
                        end if;
                    end if;
                end if;
            end process;
    end MPU_PowerSeq;
and the Test bench is also given below
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
library ieee;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity PowerSeq is
end PowerSeq;
component Sequence is
    port(fpga_clk : in std_logic;
        Reset: in std_logic;
    end component;
signal  Reset: std_logic:= '0';
signal  fpga_clk : std_logic:= '0';
signal  Enable_Bias_1V: std_logic:= '0';
signal  Enable_3V3: std_logic:= '0';
signal  Enable_1P5V: std_logic:= '0';
signal  Enable_1V: std_logic:= '0';
signal PG_3V3: std_logic:= '0';
constant tb_time: time:= 15.5 ns;
begin
uut: sequence port map(
    Reset => Reset,
    fpga_clk => fpga_clk,
    Enable_Bias_1V => Enable_Bias_1V,
    Enable_3V3 => Enable_3V3,
    Enable_1P5V => Enable_1P5V,
    Enable_1V => Enable_1V,
    PG_3V3 => PG_3V3
stimlus: process
begin
    fpga_clk <= '0' after tb_time, '1' after 2 * tb_time;
    wait for 2 * tb_time;
end process;
tb: process
begin
wait for 50 ns ;
Reset <= '0';
Enable_Bias_1V <= '0';
Enable_3V3 <= '0';
Enable_3V3 <= '0';
Enable_1V <= '0';
wait for 50 ns;
Reset <= '1';
wait for 1 us;
end process;
end;
What exactly are you expecting to see? the UUT is clearly not the same as the code you posted - it is a different named entity (PowerSeq in code, Sequence in testbench) and it has a different port map (PowerSeq has no reset port).
So, why not post the code thats actually being simulated?
the below is the code which i compiled in modelsim. but when i start simulation it is showing error in loading design
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
Library ieee;
    entity PowerSeq is
        port(fpga_clk,Reset: in std_logic;
                PG_3V3, PG_1V: in std_logic);
    end PowerSeq;
    begin
        process(fpga_clk)
        begin
            if(reset = '1') then
                Enable_3V3 <= '0';
                Enable_1P5V <= '0';
                Enable_1V <= '0';
            end if;
                Enable_3V3 <= '1';
                Enable_1P5V <= '1';
                Enable_1V <= '0';
                pon_state <= 1;
            end if;
                        Enable_1V <= '1';
                    end if;
                end if;
                end if;
            end process;
    end MPU_PowerSeq;
test bench is given below
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
library ieee;
entity PowerSeq is
end PowerSeq;
component PowerSeq is
           Reset         : in std_logic;
         PG_3V3        : in std_logic
    end component;
    signal   Reset          : std_logic:= '0';
    signal   Enable_Bias_1V : std_logic:= '0';
    signal    Enable_3V3     : std_logic:= '0';
    signal   Enable_1P5V    : std_logic:= '0';
    signal    Enable_1V      : std_logic:= '0';
    signal   pon_state      : integer:= 0;
    signal   PG_3V3         : std_logic:= '0';
    constant tb_time        : time:= 1 ns;
begin
 --sim:/powerseq
uut: PowerSeq port map(
    Reset => Reset,
    PG_3V3 => PG_3V3
stimlus: process
begin
end process;
tb: process
    begin
    wait for 5 ns ;
    Reset <= '0';
    Enable_3V3 <= '1';
    Enable_1P5V <= '1';
    wait for 5 ns;
    Enable_3V3 <= '1';
    Enable_1P5V <= '1';
    pon_state <= 1;
    end if;
    PG_3V3 <= '1';
    Enable_1v <= '1';
    end if;
    -- wait for 5 ns;
    --Reset <= '1';
    end process;
end;
Im surprised you got this to work, as your testbench has the same entity name as the UUT.
You also seem to be driving outputs from the UUT in the testbench, so I dont beleive the wave form you shows is from simulating any code you have posted.
Please find out exactly what you are simulating, and post it.
Code
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
library ieee;
entity powering is
end powering;
architecture behavioral of powering is
signal pon_state : integer := 0;
begin
process(fpga_clk)
begin
if(pon_state=0) then
Enable_3V3 <= '1';
Enable_1P5V <= '1';
pon_state <= 1;
end if;
    Enable_1V <= '1';
    end if;
end if;
end if;
end process;
end behavioral;
Testbench
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
library ieee;
entity sequence is
end sequence;
architecture behav of sequence is
component powering port(
    Reset: in std_logic:= '0';
    fpga_clk : in std_logic:= '0';
    Enable_3V3 : out std_logic:= '0';
    Enable_1p5V: out std_logic:= '0';
    Enable_1V: out std_logic:= '0';
    Enable_Bias_1V : out std_logic:= '0';
    PG_3V3: in std_logic:= '0');
end component;
constant tb_time: time:= 1 ns;
begin
uut: powering port map (
        Reset => Reset,
    PG_3V3 => PG_3V3
stimuls: process
begin
end process;
tb: process
begin
    wait for 5 ns;
    Reset <= '1';
    Enable_3V3 <= '0';
    Enable_1P5V <= '0';
    Enable_1V <= '0';
    wait for 5 ns;
    PG_3V3 <= '1';
    Enable_1V <= '1';
end process;
end;
Im sorry, this STILL isnt the correct code. The component does not match the entity.
So I suggest this is a massive user error.
The uut is powering which is the entity name of main code. the same should be assigned to the component right?
And i could even compile this code in modelsim without any error..but i couldnt do the simulation.
The latest code you posted in post #5 has a missmatch between the "powering" entity and "powering" component. the entity has a port called PG_1V and the component does not, so you cannot map the component to the entity (you get a compile/mapping error).
So what you have posted clearly is NOT what you have tried to simulate or compiled, as it will not compile for me.
The fact you have posted 3 different sets of code that ALL have this problem, I suspect your project is a bit of a mess. Please tidy it up.
IS there any issue other than this PG_1V?
Yes, you are driving the outputs of the UUT, so you will get X's in the testbench if the UUT drives '0' and the TB drives '1' (or vice versa)
Why are you driving the outputs of the UUT from the testbench?
Actually in the main code if the pon_state is 0, signals Enable_3V3, Enable_1p5V and Enable_Bias_1V should be activated. If the pon_state is 1, PG_3V3 is monitored, if it is '1' Enable_1V is activated. But i could not find a way to implement this in test bench thats is why im driving outputs UUT in tb. And is it okay to use 'if' statement inside component instantiation?
you post shows you still have a total lack of understand of VHDL - I highly suggest finding a digital logic textbook and actually reading it.
can you suggest best book to learn vhdl?
I think they have a lack of understanding of digital design. The code presented does not implement a circuit that would likely work as the power enables would be constantly "on" all the time. As there isn't even a default for the 1V enable it might not even power up as 0.
Makes me wonder if these power enables go to the POL supplies for the FPGA that is enabling them... :shock:
A power sequencer is typically implemented as a FSM not this ad hoc 32-bit integer pon_state, there is no power down sequence to shut off the power (which usually requires power to be removed in the opposite order of power on). There is no "protection" from rails not being up before the 1V is enabled or is 3.3V the only rail required for 1V to be up?
