PCB PCBA Small Low Cost Factory in China for Small Order
sakibnaz
Full Member level 3
Hi All.
Does any one have contacts with China based small PCB PCBA Factory? I like to make some sample 5 piece Boards. I get quote from some factory (from Google Search I found then). But all quote is very high. So far I understand the quote is high because they do Machine based SMT Soldering. But for my small order quantity I like to have hand Soldering Service so the cost should be low.
Also may be the Google search based company are middle-man ... its another reason their quote is high :(
Anyone have contacts with real small factory can support hand soldering ... up-to 0402 SMT resistor and capacitors.
Thanks in advance.
Regards.
I can do this for you. I am an hardware engineer from China.
