matrixofdynamism
Advanced Member level 2
Can the **broken link removed** directly drive an 8ohm speaker? how do I know from the datasheet if this is possible or not possible?
Since the output of this DAC has full range of 3.5 Vpp (typical) shown in page 7, and I use it with LM386 audio amplifier that has a gain of 20 with no extra parts used to set the gain, wouldn't that cause the LM386 to be in saturation as soon as the DAC output connected to the LM386 reaches 175mV? That really is a very small signal actually. Since the input of the DAC is 24 bits, that means that the binary value 0000 0000 0000 1100 1100 1100 corresponding to 175mV (assuming linear relationship) shall be enough to cause the LM386 to saturate.
Am I missing something here? Does the output of the DAC need a voltage divider to reduce the voltage by atleast than 1:40 maximum 24 bit binary input to the DAC shall give no more than 87.5mV (half of 175mV) as its after conversion output?
