Importing MATLAB Functions to ADS
hanen88
Member level 1
HI;
I need to import a model of function from MATLAB to ADS. Knowing tha i select Tools > Import System Model > MATLAB Function but i discover that this bottom of matlab function is disabled what can i do to makeke this bottom operate.I use the version of ADS 2009.(also P2D does'nt work). I'm so gratefull if you helpe me.
Describe what you want to do correctly.
You can use M-file only in Ptolemy of ADS.
You can not import block of Simulink to any domain(AnalogRF and Ptolemy) of ADS.
What do you mean ?
P2D is a data format of Keysight-EEsof Proprietary.
You can use P2D in ADS AnalogRF Domain not in Ptolemy.
You can use P2D in RF Blockset in Mathworks Simulink.
I need to import model from SIMULINK in MATLAB to ADS. Also when i try to select Tools---> Export ADS Plotemy it doesn't work it appears as a bottom but it is disabled i can't select it. What can i do, if you give me the clear direction to export file SIMULINK to ADS. Conserning the P2D, i don't have access of the simulation LSSP which appears in ADS, however when i'm searching the matter, i found that i shoud enter a licence to make it operational. If you can helpe me to solve the two matters i'm so gratefull.
I can not understand what you want to mean at all.
Describe correctly using corect terminologies.
And I think its export is for GoldenGate simulator.
Surely read my append.
You can not import simulink model to any domain of ADS.
If your simulink model is a M-file-S-function, you might be able to use it in Ptolemy domain as M-file block.
If your simulink model is a C-MEX-S-function, you might be able to use it in Ptolemy domain as System-C model.
P2D does not require any license.
Simply you have no license for HB Analysis ?
Before posting questions, you have to understand ADS.
You have to understand two domains of ADS, AnalogRF and Ptolemy.
You have to understand ADS AnalogRF can not treat M-file of MATLAB.
ADS Ptolemy can treat only M-file.
Any domain of ADS can not treat Simulink-Model.
LSSP is no more than HB-Analysis.
