UWB antenna with 500MHz bandwidth and 6GHz center frequency.
soundav
Junior Member level 3
Need help to design UWB antenna for C band
centre freq - 6GHz
bandwidth - 500MHz
gain - 6dB
Suggest some antenna designs that can be done for the specified parameters.
Thanks in advance.
centre freq - 6GHz
bandwidth - 500MHz
gain - 6dB
Thanks in advance.
a log periodic yagi
https://wa5vjb.com/pcb-pdfs/LP8565.pdf
a little bit of redesign will bring up the lower freq closer to 6GHz
I have used several of his 2 - 11 GHz LP yagis and patch antennas they work very well <--- now that is the real definition of UWB !! :-D
Dave
hi dave
thank you for your reply.
sure will try it out and see.
do you any other suggestions like patch or wire antennas because i need less computation time
thanks
soundav
You don't need log-per antenna to achieve 8 % bandwidth. A regular yagi antenna should do.
at those freq's, you are probably right .... I did consider mentioning that but went with the LPY :wink:
