What is the difference between quartz crystal and oscillator
shmoib
Junior Member level 3
crystal osc.
what is the difference between quartz crystal and oscillator?
Re: crystal osc.
Quarz crystal is a component that can be used in an oscillator circuit to generate a signal of the crystal's frequency..
You can also find so called crystal modules which basically are oscillators packed in DIL16 or similar housings and have an oscillator circuit and crystal quarz built-in ..
    shmoib
Re: crystal osc.
thnks,
can you introduce a simple circuit that uses the crystal as an oscillator? and what r the impotant thing for oscillation to start (practical things)?
i read alot but all what i get was the theories.
