stackprogramer
Full Member level 3
hi
in simulator debug:
when i uses std library for st this General Purpose Input/Output Port A (GPIOA) Dialog
is there in peripherals menu keil.please see https://www.keil.com/dd/vtr/4148/7679.htm
but when i used gui cmsis pack it is not in peripherals menu keil.
i even i change SVD for target too.
in command window it has error......
why this window is not show?
thanks for reply
i saw that for stm32f4,there is not,for st32f1 there is,..........
in simulator debug:
Running with Code Size Limit: 32K
Load "C:\\Users\\root\\Desktop\\StCubeMX\\keil3\\Objects\\st429.axf"
*** Restricted Version with 32768 Byte Code Size Limit
*** Currently used: 4288 Bytes (13%)
*** error 65: access violation at 0x40023800 : no 'read' permission
*** error 65: access violation at 0x40023800 : no 'write' permission
*** error 65: access violation at 0x40023808 : no 'write' permission
*** error 65: access violation at 0x40023804 : no 'write' permission
*** error 65: access violation at 0x4002380C : no 'write' permission
*** error 65: access violation at 0x40023C00 : no 'read' permission
*** error 65: access violation at 0x40023C00 : no 'write' permission
*** error 65: access violation at 0x40023808 : no 'read' permission
*** error 65: access violation at 0x40023840 : no 'read' permission
*** error 65: access violation at 0x40023840 : no 'write' permission
*** error 65: access violation at 0x40007000 : no 'read' permission
*** error 65: access violation at 0x40007000 : no 'write' permission
thanks for reply
