Sunayana Chakradhar
Member level 5
Hello All,
I plan to use DMA in Zynq PS and connect it with Microblaze. I need to transfer data to and from Zynq PS to microblaze using this DMA. I found in the configuration wizard that the Zynq PS has its DMA in the form of peripheral request interface and when I enable this it appears on the zynq PS. How should i connect these port to microblaze? I have seen that there are no DMA options in microblaze. Also there is another AXI DMA IP core which I can add on the PL and use it to connect between Zynq PS and Microblaze.Which of these 2 DMAs is recommended. Is there any document/ white paper which explains the procedure of connnecting Zynq PS to the Microblaze?
