[PIC] Micro stepping Pin Control using Pic Micro controller?
nick703
Advanced Member level 1
surat
Micro stepping Pin Control using Pic Micro controller ?
Hello Friends First of all I have a SilentStepstick Driver of trinimi TMC2100.
and i am controlling using PIC32MX575F256H microcontroller. now motor working perfectly . but i want to change microstep using microcontroller. below is the Microstep
now suppose i have to change in running motion of 1/4 step to 1/16 step and other that time how to control.
so which ic i have to use to change microstep using microcontroller.
simply , what can i do for control CFG1 and CFG2 pin .
is that any ic required to do such a task.
Re: Micro stepping Pin Control using Pic Micro controller ?
you have the module, so you don´t need any other IC.
On the bottom side you clearely see what pins are CFG1 and CFG2.
--> Connect CFG1 with GND and leave CFG2 unconnected.
Klaus
hello KlausST thanks for reply
But Actually i want to change microstepping in Programmatically so at that time i have use microcontroller with tri- state logic like VCC , GND , OPEN .
any tri-state buffer ic i have to use to change microsteeping.
if you want to control the config by a microcontrolelr then you need to wire the CFG pins to microcontroller three state pins.
Again: No need for additiony IC.
Klaus
