shaiko
Advanced Member level 5
Hello,
I'm trying to understand the difference between the following Vivado cores:
https://www.xilinx.com/support/docu...on/axi_fifo_mm_s/v4_1/pg080-axi-fifo-mm-s.pdf
vs
https://www.xilinx.com/support/docu...xi_mm2s_mapper/v1_1/pg102-axi-mm2s-mapper.pdf
In the 6th page of the first document it's written:
When should we use one and not the other?
vs
But isn't this the whole purpose of the mapper (2nd document)?The AXI4-Stream FIFO core converts AXI4/AXI4-Lite transactions to and from AXI4-Stream
transactions
