JohnJohn20
Hi. I am building a project using the PIC16F818 and when I try to build the asm code I get this error:
My script contains tables and when I trim them down a bit (about 40 lines) the script builds OK so it looks like my main program is too big.
However, when it does build OK and I check the memory usage it is using less than half.
So, is it possible to put parts of the program in other memory blocks or do I just need to trim it down a bit for this chip.
I have attached a copy of the asm file.
Thanks Chris
Error - section 'MAIN_PROG' can not fit the section. Section 'MAIN_PROG' length=0x00000462
Thanks Chris
