Verilog error: near text "wire" expecting a direction
nizdom
Member level 2
What do you mean by this error?
It means that near the text "wire", it expects a direction.
The direction would usually be in, out or inout.
Fairly self explanatory.
In Verilog this would be input, output, and inout.
You should have posted the code. If you have an error that is this basic in your code you likely have other errors too.
