[moved] full verilog code for transmitter module, channel module and reciever module
MH.AI.eAgLe
[moved]full verilog code for transmitter module , channel module and reciever module
HI
i tried to write this code but i was not successful , first i tried to write a top module consists of 3 modules (transmitter,channel,reciever) , my 7-bit data would passed from a channel , i consider 3-bit for parity check and i assumed only the 7-bit data would be changed (because of channel affect ), i applied it by this way : $random | [9:3]data_chk
[9:0]data_chk // i merged data with 3-bit parity check : [9:3]data and [2:0]chk
Since I could not do anything so I need your help
thanks
Re: [moved]full verilog code for transmitter module , channel module and reciever mo
It's highly unlikely that you will get anyone to give you code. This is not a file sharing site.
If you post the code (using the appropriate syntax tags) that "was not successful" and ask for help in making that code successful, you will likely get more help than begging forum members to give you code. As the members that answer questions are all volunteers, asking them to do your work for you is considered in poor taste.
If you are desperate for FREE code then go to Opencores and find something there. (FYI most of the code there is poorly written rubbish)
