Ananhasaasneh77
Member level 2
how can i send data from master fpga to slave fpga .. what i mean is the master sends data slave catch .. slave send data master catch.. i assigned the mosi miso sck ss for the fpga master and the slave fpga in pmod connector .. what should i do next?
here is top module code spi_loopback.
here the spi master code
here is the slave code
the ucf for spi master .
the ucf for spi slave
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 ---------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 23:44:37 05/17/2011 -- Design Name: -- Module Name: spi_loopback - Behavioral -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- This is a simple wrapper for the 'spi_master' and 'spi_slave' cores, to synthesize the 2 cores and -- test them in the simulator. -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; library work; use work.all; entity spi_loopback is Generic ( N : positive := 32; -- 32bit serial word length is default CPOL : std_logic := '0'; -- SPI mode selection (mode 0 default) CPHA : std_logic := '1'; -- CPOL = clock polarity, CPHA = clock phase. PREFETCH : positive := 2; -- prefetch lookahead cycles SPI_2X_CLK_DIV : positive := 5 -- for a 100MHz sclk_i, yields a 10MHz SCK ); Port( ----------------MASTER----------------------- m_clk_i : IN std_logic; m_rst_i : IN std_logic; m_spi_ssel_o : OUT std_logic; m_spi_sck_o : OUT std_logic; m_spi_mosi_o : OUT std_logic; m_spi_miso_i : IN std_logic; m_di_req_o : OUT std_logic; m_di_i : IN std_logic_vector(N-1 downto 0); m_wren_i : IN std_logic; m_do_valid_o : OUT std_logic; m_do_o : OUT std_logic_vector(N-1 downto 0); ----- debug ----- m_do_transfer_o : OUT std_logic; m_wren_o : OUT std_logic; m_wren_ack_o : OUT std_logic; m_rx_bit_reg_o : OUT std_logic; m_state_dbg_o : OUT std_logic_vector(3 downto 0); m_core_clk_o : OUT std_logic; m_core_n_clk_o : OUT std_logic; m_sh_reg_dbg_o : OUT std_logic_vector(N-1 downto 0); ----------------SLAVE----------------------- s_clk_i : IN std_logic; s_spi_ssel_i : IN std_logic; s_spi_sck_i : IN std_logic; s_spi_mosi_i : IN std_logic; s_spi_miso_o : OUT std_logic; s_di_req_o : OUT std_logic; -- preload lookahead data request line s_di_i : IN std_logic_vector (N-1 downto 0) := (others => 'X'); -- parallel load data in (clocked in on rising edge of clk_i) s_wren_i : IN std_logic := 'X'; -- user data write enable s_do_valid_o : OUT std_logic; -- do_o data valid strobe, valid during one clk_i rising edge. s_do_o : OUT std_logic_vector (N-1 downto 0); -- parallel output (clocked out on falling clk_i) ----- debug ----- s_do_transfer_o : OUT std_logic; -- debug: internal transfer driver s_wren_o : OUT std_logic; s_wren_ack_o : OUT std_logic; s_rx_bit_reg_o : OUT std_logic; s_state_dbg_o : OUT std_logic_vector (3 downto 0) -- debug: internal state register -- s_sh_reg_dbg_o : OUT std_logic_vector (N-1 downto 0) -- debug: internal shift register ); end spi_loopback; architecture Structural of spi_loopback is begin --============================================================================================= -- Component instantiation for the SPI master port --============================================================================================= Inst_spi_master: entity work.spi_master(rtl) generic map (N => N, CPOL => CPOL, CPHA => CPHA, PREFETCH => PREFETCH, SPI_2X_CLK_DIV => SPI_2X_CLK_DIV) port map( sclk_i => m_clk_i, -- system clock is used for serial and parallel ports pclk_i => m_clk_i, rst_i => m_rst_i, spi_ssel_o => m_spi_ssel_o, spi_sck_o => m_spi_sck_o, spi_mosi_o => m_spi_mosi_o, spi_miso_i => m_spi_miso_i, di_req_o => m_di_req_o, di_i => m_di_i, wren_i => m_wren_i, do_valid_o => m_do_valid_o, do_o => m_do_o, ----- debug ----- do_transfer_o => m_do_transfer_o, wren_o => m_wren_o, wr_ack_o => m_wren_ack_o, rx_bit_reg_o => m_rx_bit_reg_o, state_dbg_o => m_state_dbg_o, core_clk_o => m_core_clk_o, core_n_clk_o => m_core_n_clk_o, sh_reg_dbg_o => m_sh_reg_dbg_o ); --============================================================================================= -- Component instantiation for the SPI slave port --============================================================================================= Inst_spi_slave: entity work.spi_slave(rtl) generic map (N => N, CPOL => CPOL, CPHA => CPHA, PREFETCH => PREFETCH) port map( clk_i => s_clk_i, spi_ssel_i => s_spi_ssel_i, spi_sck_i => s_spi_sck_i, spi_mosi_i => s_spi_mosi_i, spi_miso_o => s_spi_miso_o, di_req_o => s_di_req_o, di_i => s_di_i, wren_i => s_wren_i, do_valid_o => s_do_valid_o, do_o => s_do_o, ----- debug ----- do_transfer_o => s_do_transfer_o, wren_o => s_wren_o, wr_ack_o => s_wren_ack_o, rx_bit_next_o => s_rx_bit_reg_o, state_dbg_o => s_state_dbg_o -- sh_reg_dbg_o => s_sh_reg_dbg_o ); end Structural;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 ----------------------------------------------------------------------------------------------------------------------- -- Author: Jonny Doin, [email]jdoin@opencores.org[/email], [email]jonnydoin@gmail.com[/email] -- -- Create Date: 12:18:12 04/25/2011 -- Module Name: SPI_MASTER - RTL -- Project Name: SPI MASTER / SLAVE INTERFACE -- Target Devices: Spartan-6 -- Tool versions: ISE 13.1 -- Description: -- -- This block is the SPI master interface, implemented in one single entity. -- All internal core operations are synchronous to the 'sclk_i', and a spi base clock is generated by dividing sclk_i downto -- a frequency that is 2x the spi SCK line frequency. The divider value is passed as a generic parameter during instantiation. -- All parallel i/o interface operations are synchronous to the 'pclk_i' high speed clock, that can be asynchronous to the serial -- 'sclk_i' clock. -- For optimized use of longlines, connect 'sclk_i' and 'pclk_i' to the same global clock line. -- Fully pipelined cross-clock circuitry guarantees that no setup artifacts occur on the buffers that are accessed by the two -- clock domains. -- The block is very simple to use, and has parallel inputs and outputs that behave like a synchronous memory i/o. -- It is parameterizable via generics for the data width ('N'), SPI mode (CPHA and CPOL), lookahead prefetch signaling -- ('PREFETCH'), and spi base clock division from sclk_i ('SPI_2X_CLK_DIV'). -- -- SPI CLOCK GENERATION -- ==================== -- -- The clock generation for the SPI SCK is derived from the high-speed 'sclk_i' clock. The core divides this reference -- clock to form the SPI base clock, by the 'SPI_2X_CLK_DIV' generic parameter. The user must set the divider value for the -- SPI_2X clock, which is 2x the desired SCK frequency. -- All registers in the core are clocked by the high-speed clocks, and clock enables are used to run the FSM and other logic -- at lower rates. This architecture preserves FPGA clock resources like global clock buffers, and avoids path delays caused -- by combinatorial clock dividers outputs. -- The core has async clock domain circuitry to handle asynchronous clocks for the SPI and parallel interfaces. -- -- PARALLEL WRITE INTERFACE -- ======================== -- The parallel interface has an input port 'di_i' and an output port 'do_o'. -- Parallel load is controlled using 3 signals: 'di_i', 'di_req_o' and 'wren_i'. 'di_req_o' is a look ahead data request line, -- that is set 'PREFETCH' clock cycles in advance to synchronize a pipelined memory or fifo to present the -- next input data at 'di_i' in time to have continuous clock at the spi bus, to allow back-to-back continuous load. -- For a pipelined sync RAM, a PREFETCH of 2 cycles allows an address generator to present the new adress to the RAM in one -- cycle, and the RAM to respond in one more cycle, in time for 'di_i' to be latched by the shifter. -- If the user sequencer needs a different value for PREFETCH, the generic can be altered at instantiation time. -- The 'wren_i' write enable strobe must be valid at least one setup time before the rising edge of the last SPI clock cycle, -- if continuous transmission is intended. If 'wren_i' is not valid 2 SPI clock cycles after the last transmitted bit, the interface -- enters idle state and deasserts SSEL. -- When the interface is idle, 'wren_i' write strobe loads the data and starts transmission. 'di_req_o' will strobe when entering -- idle state, if a previously loaded data has already been transferred. -- -- PARALLEL WRITE SEQUENCE -- ======================= -- __ __ __ __ __ __ __ -- pclk_i __/ \__/ \__/ \__/ \__/ \__/ \__/ \... -- parallel interface clock -- ___________ -- di_req_o ________/ \_____________________... -- 'di_req_o' asserted on rising edge of 'pclk_i' -- ______________ ___________________________... -- di_i __old_data____X______new_data_____________... -- user circuit loads data on 'di_i' at next 'pclk_i' rising edge -- _______ -- wren_i __________________________/ \_______... -- user strobes 'wren_i' for one cycle of 'pclk_i' -- -- -- PARALLEL READ INTERFACE -- ======================= -- An internal buffer is used to copy the internal shift register data to drive the 'do_o' port. When a complete word is received, -- the core shift register is transferred to the buffer, at the rising edge of the spi clock, 'spi_clk'. -- The signal 'do_valid_o' is set one 'spi_clk' clock after, to directly drive a synchronous memory or fifo write enable. -- 'do_valid_o' is synchronous to the parallel interface clock, and changes only on rising edges of 'pclk_i'. -- When the interface is idle, data at the 'do_o' port holds the last word received. -- -- PARALLEL READ SEQUENCE -- ====================== -- ______ ______ ______ ______ -- spi_clk bit1 \______/ bitN \______/bitN-1\______/bitN-2\__... -- internal spi 2x base clock -- _ __ __ __ __ __ __ __ __ -- pclk_i \__/ \__/ \__/ \__/ \__/ \__/ \__/ \__/ \_... -- parallel interface clock (may be async to sclk_i) -- _____________ _____________________________________... -- 1) rx data is transferred to 'do_buffer_reg' -- do_o ___old_data__X__________new_data___________________... -- after last rx bit, at rising 'spi_clk'. -- ____________ -- do_valid_o ____________________________/ \_________... -- 2) 'do_valid_o' strobed for 2 'pclk_i' cycles -- -- on the 3rd 'pclk_i' rising edge. -- -- -- The propagation delay of spi_sck_o and spi_mosi_o, referred to the internal clock, is balanced by similar path delays, -- but the sampling delay of spi_miso_i imposes a setup time referred to the sck signal that limits the high frequency -- of the interface, for full duplex operation. -- -- This design was originally targeted to a Spartan-6 platform, synthesized with XST and normal constraints. -- The VHDL dialect used is VHDL'93, accepted largely by all synthesis tools. -- ------------------------------ COPYRIGHT NOTICE ----------------------------------------------------------------------- -- -- This file is part of the SPI MASTER/SLAVE INTERFACE project [url]https://opencores.org/project,spi_master_slave[/url] -- -- Author(s): Jonny Doin, [email]jdoin@opencores.org[/email], [email]jonnydoin@gmail.com[/email] -- -- Copyright (C) 2011 Jonny Doin -- ----------------------------- -- -- This source file may be used and distributed without restriction provided that this copyright statement is not -- removed from the file and that any derivative work contains the original copyright notice and the associated -- disclaimer. -- -- This source file is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser -- General Public License as published by the Free Software Foundation; either version 2.1 of the License, or -- (at your option) any later version. -- -- This source is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied -- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for more -- details. -- -- You should have received a copy of the GNU Lesser General Public License along with this source; if not, download -- it from [url]https://www.gnu.org/licenses/lgpl.txt[/url] -- ------------------------------ REVISION HISTORY ----------------------------------------------------------------------- -- -- 2011/04/28 v0.01.0010 [JD] shifter implemented as a sequential process. timing problems and async issues in synthesis. -- 2011/05/01 v0.01.0030 [JD] changed original shifter design to a fully pipelined RTL fsmd. solved all synthesis issues. -- 2011/05/05 v0.01.0034 [JD] added an internal buffer register for rx_data, to allow greater liberty in data load/store. -- 2011/05/08 v0.10.0038 [JD] increased one state to have SSEL start one cycle before SCK. Implemented full CPOL/CPHA -- logic, based on generics, and do_valid_o signal. -- 2011/05/13 v0.20.0045 [JD] streamlined signal names, added PREFETCH parameter, added assertions. -- 2011/05/17 v0.80.0049 [JD] added explicit clock synchronization circuitry across clock boundaries. -- 2011/05/18 v0.95.0050 [JD] clock generation circuitry, with generators for all-rising-edge clock core. -- 2011/06/05 v0.96.0053 [JD] changed async clear to sync resets. -- 2011/06/07 v0.97.0065 [JD] added cross-clock buffers, fixed fsm async glitches. -- 2011/06/09 v0.97.0068 [JD] reduced control sets (resets, CE, presets) to the absolute minimum to operate, to reduce -- synthesis LUT overhead in Spartan-6 architecture. -- 2011/06/11 v0.97.0075 [JD] redesigned all parallel data interfacing ports, and implemented cross-clock strobe logic. -- 2011/06/12 v0.97.0079 [JD] streamlined wr_ack for all cases and eliminated unnecessary register resets. -- 2011/06/14 v0.97.0083 [JD] (bug CPHA effect) : redesigned SCK output circuit. -- (minor bug) : removed fsm registers from (not rst_i) chip enable. -- 2011/06/15 v0.97.0086 [JD] removed master MISO input register, to relax MISO data setup time (to get higher speed). -- 2011/07/09 v1.00.0095 [JD] changed all clocking scheme to use a single high-speed clock with clock enables to control lower -- frequency sequential circuits, to preserve clocking resources and avoid path delay glitches. -- 2011/07/10 v1.00.0098 [JD] implemented SCK clock divider circuit to generate spi clock directly from system clock. -- 2011/07/10 v1.10.0075 [JD] verified spi_master_slave in silicon at 50MHz, 25MHz, 16.666MHz, 12.5MHz, 10MHz, 8.333MHz, -- 7.1428MHz, 6.25MHz, 1MHz and 500kHz. The core proved very robust at all tested frequencies. -- 2011/07/16 v1.11.0080 [JD] verified both spi_master and spi_slave in loopback at 50MHz SPI clock. -- 2011/07/17 v1.11.0080 [JD] BUG: CPOL='1', CPHA='1' @50MHz causes MOSI to be shifted one bit earlier. -- BUG: CPOL='0', CPHA='1' causes SCK to have one extra pulse with one sclk_i width at the end. -- 2011/07/18 v1.12.0105 [JD] CHG: spi sck output register changed to remove glitch at last clock when CPHA='1'. -- for CPHA='1', max spi clock is 25MHz. for CPHA= '0', max spi clock is >50MHz. -- 2011/07/24 v1.13.0125 [JD] FIX: 'sck_ena_ce' is on half-cycle advanced to 'fsm_ce', elliminating CPHA='1' glitches. -- Core verified for all CPOL, CPHA at up to 50MHz, simulates to over 100MHz. -- 2011/07/29 v1.14.0130 [JD] Removed global signal setting at the FSM, implementing exhaustive explicit signal attributions -- for each state, to avoid reported inference problems in some synthesis engines. -- Streamlined port names and indentation blocks. -- 2011/08/01 v1.15.0135 [JD] Fixed latch inference for spi_mosi_o driver at the fsm. -- The master and slave cores were verified in FPGA with continuous transmission, for all SPI modes. -- 2011/08/04 v1.15.0136 [JD] Fixed assertions (PREFETCH >= 1) and minor comment bugs. -- ----------------------------------------------------------------------------------------------------------------------- -- TODO -- ==== -- ----------------------------------------------------------------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use ieee.std_logic_unsigned.all; --================================================================================================================ -- SYNTHESIS CONSIDERATIONS -- ======================== -- There are several output ports that are used to simulate and verify the core operation. -- Do not map any signals to the unused ports, and the synthesis tool will remove the related interfacing -- circuitry. -- The same is valid for the transmit and receive ports. If the receive ports are not mapped, the -- synthesis tool will remove the receive logic from the generated circuitry. -- Alternatively, you can remove these ports and related circuitry once the core is verified and -- integrated to your circuit. --================================================================================================================ entity spi_master is Generic ( N : positive := 32; -- 32bit serial word length is default CPOL : std_logic := '0'; -- SPI mode selection (mode 0 default) CPHA : std_logic := '0'; -- CPOL = clock polarity, CPHA = clock phase. PREFETCH : positive := 2; -- prefetch lookahead cycles SPI_2X_CLK_DIV : positive := 5); -- for a 100MHz sclk_i, yields a 10MHz SCK Port ( sclk_i : in std_logic := 'X'; -- high-speed serial interface system clock pclk_i : in std_logic := 'X'; -- high-speed parallel interface system clock rst_i : in std_logic := 'X'; -- reset core ---- serial interface ---- spi_ssel_o : out std_logic; -- spi bus slave select line spi_sck_o : out std_logic; -- spi bus sck spi_mosi_o : out std_logic; -- spi bus mosi output spi_miso_i : in std_logic := 'X'; -- spi bus spi_miso_i input ---- parallel interface ---- di_req_o : out std_logic; -- preload lookahead data request line di_i : in std_logic_vector (N-1 downto 0) := (others => 'X'); -- parallel data in (clocked on rising spi_clk after last bit) wren_i : in std_logic := 'X'; -- user data write enable, starts transmission when interface is idle wr_ack_o : out std_logic; -- write acknowledge do_valid_o : out std_logic; -- do_o data valid signal, valid during one spi_clk rising edge. do_o : out std_logic_vector (N-1 downto 0); -- parallel output (clocked on rising spi_clk after last bit) --- debug ports: can be removed or left unconnected for the application circuit --- sck_ena_o : out std_logic; -- debug: internal sck enable signal sck_ena_ce_o : out std_logic; -- debug: internal sck clock enable signal do_transfer_o : out std_logic; -- debug: internal transfer driver wren_o : out std_logic; -- debug: internal state of the wren_i pulse stretcher rx_bit_reg_o : out std_logic; -- debug: internal rx bit state_dbg_o : out std_logic_vector (3 downto 0); -- debug: internal state register core_clk_o : out std_logic; core_n_clk_o : out std_logic; core_ce_o : out std_logic; core_n_ce_o : out std_logic; sh_reg_dbg_o : out std_logic_vector (N-1 downto 0) -- debug: internal shift register ); end spi_master; --================================================================================================================ -- this architecture is a pipelined register-transfer description. -- all signals are clocked at the rising edge of the system clock 'sclk_i'. --================================================================================================================ architecture rtl of spi_master is -- core clocks, generated from 'sclk_i': initialized at GSR to differential values signal core_clk : std_logic := '0'; -- continuous core clock, positive logic signal core_n_clk : std_logic := '1'; -- continuous core clock, negative logic signal core_ce : std_logic := '0'; -- core clock enable, positive logic signal core_n_ce : std_logic := '1'; -- core clock enable, negative logic -- spi bus clock, generated from the CPOL selected core clock polarity signal spi_2x_ce : std_logic := '1'; -- spi_2x clock enable signal spi_clk : std_logic := '0'; -- spi bus output clock signal spi_clk_reg : std_logic; -- output pipeline delay for spi sck (do NOT global initialize) -- core fsm clock enables signal fsm_ce : std_logic := '1'; -- fsm clock enable signal sck_ena_ce : std_logic := '1'; -- SCK clock enable signal samp_ce : std_logic := '1'; -- data sampling clock enable -- -- GLOBAL RESET: -- all signals are initialized to zero at GSR (global set/reset) by giving explicit -- initialization values at declaration. This is needed for all Xilinx FPGAs, and -- especially for the Spartan-6 and newer CLB architectures, where a async reset can -- reduce the usability of the slice registers, due to the need to share the control -- set (RESET/PRESET, CLOCK ENABLE and CLOCK) by all 8 registers in a slice. -- By using GSR for the initialization, and reducing async RESET local init to the bare -- essential, the model achieves better LUT/FF packing and CLB usability. -- -- internal state signals for register and combinatorial stages signal state_next : natural range N+1 downto 0 := 0; signal state_reg : natural range N+1 downto 0 := 0; -- shifter signals for register and combinatorial stages signal sh_next : std_logic_vector (N-1 downto 0); signal sh_reg : std_logic_vector (N-1 downto 0); -- input bit sampled buffer signal rx_bit_reg : std_logic := '0'; -- buffered di_i data signals for register and combinatorial stages signal di_reg : std_logic_vector (N-1 downto 0); -- internal wren_i stretcher for fsm combinatorial stage signal wren : std_logic; signal wr_ack_next : std_logic := '0'; signal wr_ack_reg : std_logic := '0'; -- internal SSEL enable control signals signal ssel_ena_next : std_logic := '0'; signal ssel_ena_reg : std_logic := '0'; -- internal SCK enable control signals signal sck_ena_next : std_logic; signal sck_ena_reg : std_logic; -- buffered do_o data signals for register and combinatorial stages signal do_buffer_next : std_logic_vector (N-1 downto 0); signal do_buffer_reg : std_logic_vector (N-1 downto 0); -- internal signal to flag transfer to do_buffer_reg signal do_transfer_next : std_logic := '0'; signal do_transfer_reg : std_logic := '0'; -- internal input data request signal signal di_req_next : std_logic := '0'; signal di_req_reg : std_logic := '0'; -- cross-clock do_transfer_reg -> do_valid_o_reg pipeline signal do_valid_A : std_logic := '0'; signal do_valid_B : std_logic := '0'; signal do_valid_C : std_logic := '0'; signal do_valid_D : std_logic := '0'; signal do_valid_next : std_logic := '0'; signal do_valid_o_reg : std_logic := '0'; -- cross-clock di_req_reg -> di_req_o_reg pipeline signal di_req_o_A : std_logic := '0'; signal di_req_o_B : std_logic := '0'; signal di_req_o_C : std_logic := '0'; signal di_req_o_D : std_logic := '0'; signal di_req_o_next : std_logic := '1'; signal di_req_o_reg : std_logic := '1'; begin --============================================================================================= -- GENERICS CONSTRAINTS CHECKING --============================================================================================= -- minimum word width is 8 bits assert N >= 8 report "Generic parameter 'N' (shift register size) needs to be 8 bits minimum" severity FAILURE; -- minimum prefetch lookahead check assert PREFETCH >= 1 report "Generic parameter 'PREFETCH' (lookahead count) needs to be 1 minimum" severity FAILURE; -- maximum prefetch lookahead check assert PREFETCH <= N-5 report "Generic parameter 'PREFETCH' (lookahead count) out of range, needs to be N-5 maximum" severity FAILURE; -- SPI_2X_CLK_DIV clock divider value must not be zero assert SPI_2X_CLK_DIV > 0 report "Generic parameter 'SPI_2X_CLK_DIV' must not be zero" severity FAILURE; --============================================================================================= -- CLOCK GENERATION --============================================================================================= -- In order to preserve global clocking resources, the core clocking scheme is completely based -- on using clock enables to process the serial high-speed clock at lower rates for the core fsm, -- the spi clock generator and the input sampling clock. -- The clock generation block derives 2 continuous antiphase signals from the 2x spi base clock -- for the core clocking. -- The 2 clock phases are generated by separate and synchronous FFs, and should have only -- differential interconnect delay skew. -- Clock enable signals are generated with the same phase as the 2 core clocks, and these clock -- enables are used to control clocking of all internal synchronous circuitry. -- The clock enable phase is selected for serial input sampling, fsm clocking, and spi SCK output, -- based on the configuration of CPOL and CPHA. -- Each phase is selected so that all the registers can be clocked with a rising edge on all SPI -- modes, by a single high-speed global clock, preserving clock resources and clock to data skew. ----------------------------------------------------------------------------------------------- -- generate the 2x spi base clock enable from the serial high-speed input clock spi_2x_ce_gen_proc: process (sclk_i) is variable clk_cnt : integer range SPI_2X_CLK_DIV-1 downto 0 := 0; begin if sclk_i'event and sclk_i = '1' then if clk_cnt = SPI_2X_CLK_DIV-1 then spi_2x_ce <= '1'; clk_cnt := 0; else spi_2x_ce <= '0'; clk_cnt := clk_cnt + 1; end if; end if; end process spi_2x_ce_gen_proc; ----------------------------------------------------------------------------------------------- -- generate the core antiphase clocks and clock enables from the 2x base CE. core_clock_gen_proc : process (sclk_i) is begin if sclk_i'event and sclk_i = '1' then if spi_2x_ce = '1' then -- generate the 2 antiphase core clocks core_clk <= core_n_clk; core_n_clk <= not core_n_clk; -- generate the 2 phase core clock enables core_ce <= core_n_clk; core_n_ce <= not core_n_clk; else core_ce <= '0'; core_n_ce <= '0'; end if; end if; end process core_clock_gen_proc; --============================================================================================= -- GENERATE BLOCKS --============================================================================================= -- spi clk generator: generate spi_clk from core_clk depending on CPOL spi_sck_cpol_0_proc: if CPOL = '0' generate begin spi_clk <= core_clk; -- for CPOL=0, spi clk has idle LOW end generate; spi_sck_cpol_1_proc: if CPOL = '1' generate begin spi_clk <= core_n_clk; -- for CPOL=1, spi clk has idle HIGH end generate; ----------------------------------------------------------------------------------------------- -- Sampling clock enable generation: generate 'samp_ce' from 'core_ce' or 'core_n_ce' depending on CPHA -- always sample data at the half-cycle of the fsm update cell samp_ce_cpha_0_proc: if CPHA = '0' generate begin samp_ce <= core_ce; end generate; samp_ce_cpha_1_proc: if CPHA = '1' generate begin samp_ce <= core_n_ce; end generate; ----------------------------------------------------------------------------------------------- -- FSM clock enable generation: generate 'fsm_ce' from core_ce or core_n_ce depending on CPHA fsm_ce_cpha_0_proc: if CPHA = '0' generate begin fsm_ce <= core_n_ce; -- for CPHA=0, latch registers at rising edge of negative core clock enable end generate; fsm_ce_cpha_1_proc: if CPHA = '1' generate begin fsm_ce <= core_ce; -- for CPHA=1, latch registers at rising edge of positive core clock enable end generate; ----------------------------------------------------------------------------------------------- -- sck enable control: control sck advance phase for CPHA='1' relative to fsm clock sck_ena_ce <= core_n_ce; -- for CPHA=1, SCK is advanced one-half cycle --============================================================================================= -- REGISTERED INPUTS --============================================================================================= -- rx bit flop: capture rx bit after SAMPLE edge of sck rx_bit_proc : process (sclk_i, spi_miso_i) is begin if sclk_i'event and sclk_i = '1' then if samp_ce = '1' then rx_bit_reg <= spi_miso_i; end if; end if; end process rx_bit_proc; --============================================================================================= -- CROSS-CLOCK PIPELINE TRANSFER LOGIC --============================================================================================= -- do_valid_o and di_req_o strobe output logic -- this is a delayed pulse generator with a ripple-transfer FFD pipeline, that generates a -- fixed-length delayed pulse for the output flags, at the parallel clock domain out_transfer_proc : process ( pclk_i, do_transfer_reg, di_req_reg, do_valid_A, do_valid_B, do_valid_D, di_req_o_A, di_req_o_B, di_req_o_D ) is begin if pclk_i'event and pclk_i = '1' then -- clock at parallel port clock -- do_transfer_reg -> do_valid_o_reg do_valid_A <= do_transfer_reg; -- the input signal must be at least 2 clocks long do_valid_B <= do_valid_A; -- feed it to a ripple chain of FFDs do_valid_C <= do_valid_B; do_valid_D <= do_valid_C; do_valid_o_reg <= do_valid_next; -- registered output pulse -------------------------------- -- di_req_reg -> di_req_o_reg di_req_o_A <= di_req_reg; -- the input signal must be at least 2 clocks long di_req_o_B <= di_req_o_A; -- feed it to a ripple chain of FFDs di_req_o_C <= di_req_o_B; di_req_o_D <= di_req_o_C; di_req_o_reg <= di_req_o_next; -- registered output pulse end if; -- generate a 2-clocks pulse at the 3rd clock cycle do_valid_next <= do_valid_A and do_valid_B and not do_valid_D; di_req_o_next <= di_req_o_A and di_req_o_B and not di_req_o_D; end process out_transfer_proc; -- parallel load input registers: data register and write enable in_transfer_proc: process ( pclk_i, wren_i, wr_ack_reg ) is begin -- registered data input, input register with clock enable if pclk_i'event and pclk_i = '1' then if wren_i = '1' then di_reg <= di_i; -- parallel data input buffer register end if; end if; -- stretch wren pulse to be detected by spi fsm (ffd with sync preset and sync reset) if pclk_i'event and pclk_i = '1' then if wren_i = '1' then -- wren_i is the sync preset for wren wren <= '1'; elsif wr_ack_reg = '1' then -- wr_ack is the sync reset for wren wren <= '0'; end if; end if; end process in_transfer_proc; --============================================================================================= -- REGISTER TRANSFER PROCESSES --============================================================================================= -- fsm state and data registers: synchronous to the spi base reference clock core_reg_proc : process (sclk_i) is begin -- FF registers clocked on rising edge and cleared on sync rst_i if sclk_i'event and sclk_i = '1' then if rst_i = '1' then -- sync reset state_reg <= 0; -- only provide local reset for the state machine elsif fsm_ce = '1' then -- fsm_ce is clock enable for the fsm state_reg <= state_next; -- state register end if; end if; -- FF registers clocked synchronous to the fsm state if sclk_i'event and sclk_i = '1' then if fsm_ce = '1' then sh_reg <= sh_next; -- shift register ssel_ena_reg <= ssel_ena_next; -- spi select enable do_buffer_reg <= do_buffer_next; -- registered output data buffer do_transfer_reg <= do_transfer_next; -- output data transferred to buffer di_req_reg <= di_req_next; -- input data request wr_ack_reg <= wr_ack_next; -- write acknowledge for data load synchronization end if; end if; -- FF registers clocked one-half cycle earlier than the fsm state if sclk_i'event and sclk_i = '1' then if sck_ena_ce = '1' then sck_ena_reg <= sck_ena_next; -- spi clock enable: look ahead logic end if; end if; end process core_reg_proc; --============================================================================================= -- COMBINATORIAL LOGIC PROCESSES --============================================================================================= -- state and datapath combinatorial logic core_combi_proc : process ( sh_reg, state_reg, rx_bit_reg, ssel_ena_reg, sck_ena_reg, do_buffer_reg, do_transfer_reg, wr_ack_reg, di_req_reg, di_reg, wren ) is begin sh_next <= sh_reg; -- all output signals are assigned to (avoid latches) ssel_ena_next <= ssel_ena_reg; -- controls the slave select line sck_ena_next <= sck_ena_reg; -- controls the clock enable of spi sck line do_buffer_next <= do_buffer_reg; -- output data buffer do_transfer_next <= do_transfer_reg; -- output data flag wr_ack_next <= wr_ack_reg; -- write acknowledge di_req_next <= di_req_reg; -- prefetch data request spi_mosi_o <= sh_reg(N-1); -- default to avoid latch inference state_next <= state_reg; -- next state case state_reg is when (N+1) => -- this state is to enable SSEL before SCK spi_mosi_o <= sh_reg(N-1); -- shift out tx bit from the MSb ssel_ena_next <= '1'; -- tx in progress: will assert SSEL sck_ena_next <= '1'; -- enable SCK on next cycle (stays off on first SSEL clock cycle) di_req_next <= '0'; -- prefetch data request: deassert when shifting data wr_ack_next <= '0'; -- remove write acknowledge for all but the load stages state_next <= state_reg - 1; -- update next state at each sck pulse when (N) => -- deassert 'di_rdy' and stretch do_valid spi_mosi_o <= sh_reg(N-1); -- shift out tx bit from the MSb di_req_next <= '0'; -- prefetch data request: deassert when shifting data sh_next(N-1 downto 1) <= sh_reg(N-2 downto 0); -- shift inner bits sh_next(0) <= rx_bit_reg; -- shift in rx bit into LSb wr_ack_next <= '0'; -- remove write acknowledge for all but the load stages state_next <= state_reg - 1; -- update next state at each sck pulse when (N-1) downto (PREFETCH+3) => -- remove 'do_transfer' and shift bits spi_mosi_o <= sh_reg(N-1); -- shift out tx bit from the MSb di_req_next <= '0'; -- prefetch data request: deassert when shifting data do_transfer_next <= '0'; -- reset 'do_valid' transfer signal sh_next(N-1 downto 1) <= sh_reg(N-2 downto 0); -- shift inner bits sh_next(0) <= rx_bit_reg; -- shift in rx bit into LSb wr_ack_next <= '0'; -- remove write acknowledge for all but the load stages state_next <= state_reg - 1; -- update next state at each sck pulse when (PREFETCH+2) downto 2 => -- raise prefetch 'di_req_o' signal spi_mosi_o <= sh_reg(N-1); -- shift out tx bit from the MSb di_req_next <= '1'; -- request data in advance to allow for pipeline delays sh_next(N-1 downto 1) <= sh_reg(N-2 downto 0); -- shift inner bits sh_next(0) <= rx_bit_reg; -- shift in rx bit into LSb wr_ack_next <= '0'; -- remove write acknowledge for all but the load stages state_next <= state_reg - 1; -- update next state at each sck pulse when 1 => -- transfer rx data to do_buffer and restart if new data is written spi_mosi_o <= sh_reg(N-1); -- shift out tx bit from the MSb di_req_next <= '1'; -- request data in advance to allow for pipeline delays do_buffer_next(N-1 downto 1) <= sh_reg(N-2 downto 0); -- shift rx data directly into rx buffer do_buffer_next(0) <= rx_bit_reg; -- shift last rx bit into rx buffer do_transfer_next <= '1'; -- signal transfer to do_buffer if wren = '1' then -- load tx register if valid data present at di_i state_next <= N; -- next state is top bit of new data sh_next <= di_reg; -- load parallel data from di_reg into shifter sck_ena_next <= '1'; -- SCK enabled wr_ack_next <= '1'; -- acknowledge data in transfer else sck_ena_next <= '0'; -- SCK disabled: tx empty, no data to send wr_ack_next <= '0'; -- remove write acknowledge for all but the load stages state_next <= state_reg - 1; -- update next state at each sck pulse end if; when 0 => -- idle state: start and end of transmission di_req_next <= '1'; -- will request data if shifter empty sck_ena_next <= '0'; -- SCK disabled: tx empty, no data to send if wren = '1' then -- load tx register if valid data present at di_i spi_mosi_o <= di_reg(N-1); -- special case: shift out first tx bit from the MSb (look ahead) ssel_ena_next <= '1'; -- enable interface SSEL state_next <= N+1; -- start from idle: let one cycle for SSEL settling sh_next <= di_reg; -- load bits from di_reg into shifter wr_ack_next <= '1'; -- acknowledge data in transfer else spi_mosi_o <= sh_reg(N-1); -- shift out tx bit from the MSb ssel_ena_next <= '0'; -- deassert SSEL: interface is idle wr_ack_next <= '0'; -- remove write acknowledge for all but the load stages state_next <= 0; -- when idle, keep this state end if; when others => state_next <= 0; -- state 0 is safe state end case; end process core_combi_proc; --============================================================================================= -- OUTPUT LOGIC PROCESSES --============================================================================================= -- data output processes spi_ssel_o_proc: spi_ssel_o <= not ssel_ena_reg; -- active-low slave select line do_o_proc: do_o <= do_buffer_reg; -- parallel data out do_valid_o_proc: do_valid_o <= do_valid_o_reg; -- data out valid di_req_o_proc: di_req_o <= di_req_o_reg; -- input data request for next cycle wr_ack_o_proc: wr_ack_o <= wr_ack_reg; -- write acknowledge ----------------------------------------------------------------------------------------------- -- SCK out logic: pipeline phase compensation for the SCK line ----------------------------------------------------------------------------------------------- -- This is a MUX with an output register. -- The register gives us a pipeline delay for the SCK line, pairing with the state machine moore -- output pipeline delay for the MOSI line, and thus enabling higher SCK frequency. spi_sck_o_gen_proc : process (sclk_i, sck_ena_reg, spi_clk, spi_clk_reg) is begin if sclk_i'event and sclk_i = '1' then if sck_ena_reg = '1' then spi_clk_reg <= spi_clk; -- copy the selected clock polarity else spi_clk_reg <= CPOL; -- when clock disabled, set to idle polarity end if; end if; spi_sck_o <= spi_clk_reg; -- connect register to output end process spi_sck_o_gen_proc; --============================================================================================= -- DEBUG LOGIC PROCESSES --============================================================================================= -- these signals are useful for verification, and can be deleted after debug. do_transfer_proc: do_transfer_o <= do_transfer_reg; state_dbg_proc: state_dbg_o <= std_logic_vector(to_unsigned(state_reg, 4)); rx_bit_reg_proc: rx_bit_reg_o <= rx_bit_reg; wren_o_proc: wren_o <= wren; sh_reg_dbg_proc: sh_reg_dbg_o <= sh_reg; core_clk_o_proc: core_clk_o <= core_clk; core_n_clk_o_proc: core_n_clk_o <= core_n_clk; core_ce_o_proc: core_ce_o <= core_ce; core_n_ce_o_proc: core_n_ce_o <= core_n_ce; sck_ena_o_proc: sck_ena_o <= sck_ena_reg; sck_ena_ce_o_proc: sck_ena_ce_o <= sck_ena_ce; end architecture rtl;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 ---------------------------------------------------------------------------------- -- Author: Jonny Doin, [email]jdoin@opencores.org[/email] -- -- Create Date: 15:36:20 05/15/2011 -- Module Name: SPI_SLAVE - RTL -- Project Name: SPI INTERFACE -- Target Devices: Spartan-6 -- Tool versions: ISE 13.1 -- Description: -- -- This block is the SPI slave interface, implemented in one single entity. -- All internal core operations are synchronous to the external SPI clock, and follows the general SPI de-facto standard. -- The parallel read/write interface is synchronous to a supplied system master clock, 'clk_i'. -- Synchronization for the parallel ports is provided by input data request and write enable lines, and output data valid line. -- Fully pipelined cross-clock circuitry guarantees that no setup artifacts occur on the buffers that are accessed by the two -- clock domains. -- -- The block is very simple to use, and has parallel inputs and outputs that behave like a synchronous memory i/o. -- It is parameterizable via generics for the data width ('N'), SPI mode (CPHA and CPOL), and lookahead prefetch -- signaling ('PREFETCH'). -- -- PARALLEL WRITE INTERFACE -- The parallel interface has a input port 'di_i' and an output port 'do_o'. -- Parallel load is controlled using 3 signals: 'di_i', 'di_req_o' and 'wren_i'. -- When the core needs input data, a look ahead data request strobe , 'di_req_o' is pulsed 'PREFETCH' 'spi_sck_i' -- cycles in advance to synchronize a user pipelined memory or fifo to present the next input data at 'di_i' -- in time to have continuous clock at the spi bus, to allow back-to-back continuous load. -- The data request strobe on 'di_req_o' is 2 'clk_i' clock cycles long. -- The write to 'di_i' must occur at most one 'spi_sck_i' cycle before actual load to the core shift register, to avoid -- race conditions at the register transfer. -- The user circuit places data at the 'di_i' port and strobes the 'wren_i' line for one rising edge of 'clk_i'. -- For a pipelined sync RAM, a PREFETCH of 3 cycles allows an address generator to present the new adress to the RAM in one -- cycle, and the RAM to respond in one more cycle, in time for 'di_i' to be latched by the interface one clock before transfer. -- If the user sequencer needs a different value for PREFETCH, the generic can be altered at instantiation time. -- The 'wren_i' write enable strobe must be valid at least one setup time before the rising edge of the last clock cycle, -- if continuous transmission is intended. -- When the interface is idle ('spi_ssel_i' is HIGH), the top bit of the latched 'di_i' port is presented at port 'spi_miso_o'. -- -- PARALLEL WRITE PIPELINED SEQUENCE -- ================================= -- __ __ __ __ __ __ __ -- clk_i __/ \__/ \__/ \__/ \__/ \__/ \__/ \... -- parallel interface clock -- ___________ -- di_req_o ________/ \_____________________... -- 'di_req_o' asserted on rising edge of 'clk_i' -- ______________ ___________________________... -- di_i __old_data____X______new_data_____________... -- user circuit loads data on 'di_i' at next 'clk_i' rising edge -- ________ -- wren_i __________________________/ \______... -- 'wren_i' enables latch on rising edge of 'clk_i' -- -- -- PARALLEL READ INTERFACE -- An internal buffer is used to copy the internal shift register data to drive the 'do_o' port. When a complete -- word is received, the core shift register is transferred to the buffer, at the rising edge of the spi clock, 'spi_sck_i'. -- The signal 'do_valid_o' is strobed 3 'clk_i' clocks after, to directly drive a synchronous memory or fifo write enable. -- 'do_valid_o' is synchronous to the parallel interface clock, and changes only on rising edges of 'clk_i'. -- When the interface is idle, data at the 'do_o' port holds the last word received. -- -- PARALLEL READ PIPELINED SEQUENCE -- ================================ -- ______ ______ ______ ______ -- clk_spi_i ___/ bit1 \______/ bitN \______/bitN-1\______/bitN-2\__... -- spi base clock -- __ __ __ __ __ __ __ __ __ -- clk_i __/ \__/ \__/ \__/ \__/ \__/ \__/ \__/ \__/ \_... -- parallel interface clock -- _________________ _____________________________________... -- 1) received data is transferred to 'do_buffer_reg' -- do_o __old_data_______X__________new_data___________________... -- after last bit received, at next shift clock. -- ____________ -- do_valid_o ________________________________/ \_________... -- 2) 'do_valid_o' strobed for 2 'clk_i' cycles -- -- on the 3rd 'clk_i' rising edge. -- -- -- This design was originally targeted to a Spartan-6 platform, synthesized with XST and normal constraints. -- ------------------------------ COPYRIGHT NOTICE ----------------------------------------------------------------------- -- -- This file is part of the SPI MASTER/SLAVE INTERFACE project [url]https://opencores.org/project,spi_master_slave[/url] -- -- Author(s): Jonny Doin, [email]jdoin@opencores.org[/email], [email]jonnydoin@gmail.com[/email] -- -- Copyright (C) 2011 Jonny Doin -- ----------------------------- -- -- This source file may be used and distributed without restriction provided that this copyright statement is not -- removed from the file and that any derivative work contains the original copyright notice and the associated -- disclaimer. -- -- This source file is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser -- General Public License as published by the Free Software Foundation; either version 2.1 of the License, or -- (at your option) any later version. -- -- This source is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied -- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for more -- details. -- -- You should have received a copy of the GNU Lesser General Public License along with this source; if not, download -- it from [url]https://www.gnu.org/licenses/lgpl.txt[/url] -- ------------------------------ REVISION HISTORY ----------------------------------------------------------------------- -- -- 2011/05/15 v0.10.0050 [JD] created the slave logic, with 2 clock domains, from SPI_MASTER module. -- 2011/05/15 v0.15.0055 [JD] fixed logic for starting state when CPHA='1'. -- 2011/05/17 v0.80.0049 [JD] added explicit clock synchronization circuitry across clock boundaries. -- 2011/05/18 v0.95.0050 [JD] clock generation circuitry, with generators for all-rising-edge clock core. -- 2011/06/05 v0.96.0053 [JD] changed async clear to sync resets. -- 2011/06/07 v0.97.0065 [JD] added cross-clock buffers, fixed fsm async glitches. -- 2011/06/09 v0.97.0068 [JD] reduced control sets (resets, CE, presets) to the absolute minimum to operate, to reduce -- synthesis LUT overhead in Spartan-6 architecture. -- 2011/06/11 v0.97.0075 [JD] redesigned all parallel data interfacing ports, and implemented cross-clock strobe logic. -- 2011/06/12 v0.97.0079 [JD] implemented wr_ack and di_req logic for state 0, and eliminated unnecessary registers reset. -- 2011/06/17 v0.97.0079 [JD] implemented wr_ack and di_req logic for state 0, and eliminated unnecessary registers reset. -- 2011/07/16 v1.11.0080 [JD] verified both spi_master and spi_slave in loopback at 50MHz SPI clock. -- 2011/07/29 v2.00.0110 [JD] FIX: CPHA bugs: -- - redesigned core clocking to address all CPOL and CPHA configurations. -- - added CHANGE_EDGE to the FSM register transfer logic, to have MISO change at opposite -- clock phases from SHIFT_EDGE. -- Removed global signal setting at the FSM, implementing exhaustive explicit signal attributions -- for each state, to avoid reported inference problems in some synthesis engines. -- Streamlined port names and indentation blocks. -- 2011/08/01 v2.01.0115 [JD] Adjusted 'do_valid_o' pulse width to be 2 'clk_i', as in the master core. -- Simulated in iSim with the master core for continuous transmission mode. -- 2011/08/02 v2.02.0120 [JD] Added mux for MISO at reset state, to output di(N-1) at start. This fixed a bug in first bit. -- The master and slave cores were verified in FPGA with continuous transmission, for all SPI modes. -- 2011/08/04 v2.02.0121 [JD] Changed minor comment bugs in the combinatorial fsm logic. -- 2011/08/08 v2.02.0122 [JD] FIX: continuous transfer mode bug. When wren_i is not strobed prior to state 1 (last bit), the -- sequencer goes to state 0, and then to state 'N' again. This produces a wrong bit-shift for received -- data. The fix consists in engaging continuous transfer regardless of the user strobing write enable, and -- sequencing from state 1 to N as long as the master clock is present. If the user does not write new -- data, the last data word is repeated. -- 2011/08/08 v2.02.0123 [JD] ISSUE: continuous transfer mode bug, for ignored 'di_req' cycles. Instead of repeating the last data word, -- the slave will send (others => '0') instead. -- 2011/08/28 v2.02.0126 [JD] ISSUE: the miso_o MUX that preloads tx_bit when slave is desselected will glitch for CPHA='1'. -- FIX: added a registered drive for the MUX select that will transfer the tx_reg only after the first tx_reg update. -- ----------------------------------------------------------------------------------------------------------------------- -- TODO -- ==== -- ----------------------------------------------------------------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use ieee.std_logic_unsigned.all; entity spi_slave is Generic ( N : positive := 32; -- 32bit serial word length is default CPOL : std_logic := '0'; -- SPI mode selection (mode 0 default) CPHA : std_logic := '0'; -- CPOL = clock polarity, CPHA = clock phase. PREFETCH : positive := 3); -- prefetch lookahead cycles Port ( clk_i : in std_logic := 'X'; -- internal interface clock (clocks di/do registers) spi_ssel_i : in std_logic := 'X'; -- spi bus slave select line spi_sck_i : in std_logic := 'X'; -- spi bus sck clock (clocks the shift register core) spi_mosi_i : in std_logic := 'X'; -- spi bus mosi input spi_miso_o : out std_logic := 'X'; -- spi bus spi_miso_o output di_req_o : out std_logic; -- preload lookahead data request line di_i : in std_logic_vector (N-1 downto 0) := (others => 'X'); -- parallel load data in (clocked in on rising edge of clk_i) wren_i : in std_logic := 'X'; -- user data write enable wr_ack_o : out std_logic; -- write acknowledge do_valid_o : out std_logic; -- do_o data valid strobe, valid during one clk_i rising edge. do_o : out std_logic_vector (N-1 downto 0); -- parallel output (clocked out on falling clk_i) --- debug ports: can be removed for the application circuit --- do_transfer_o : out std_logic; -- debug: internal transfer driver wren_o : out std_logic; -- debug: internal state of the wren_i pulse stretcher rx_bit_next_o : out std_logic; -- debug: internal rx bit state_dbg_o : out std_logic_vector (3 downto 0); -- debug: internal state register sh_reg_dbg_o : out std_logic_vector (N-1 downto 0) -- debug: internal shift register ); end spi_slave; --================================================================================================================ -- SYNTHESIS CONSIDERATIONS -- ======================== -- There are several output ports that are used to simulate and verify the core operation. -- Do not map any signals to the unused ports, and the synthesis tool will remove the related interfacing -- circuitry. -- The same is valid for the transmit and receive ports. If the receive ports are not mapped, the -- synthesis tool will remove the receive logic from the generated circuitry. -- Alternatively, you can remove these ports and related circuitry once the core is verified and -- integrated to your circuit. --================================================================================================================ architecture rtl of spi_slave is -- constants to control FlipFlop synthesis constant SHIFT_EDGE : std_logic := (CPOL xnor CPHA); -- MOSI data is captured and shifted at this SCK edge constant CHANGE_EDGE : std_logic := (CPOL xor CPHA); -- MISO data is updated at this SCK edge ------------------------------------------------------------------------------------------ -- GLOBAL RESET: -- all signals are initialized to zero at GSR (global set/reset) by giving explicit -- initialization values at declaration. This is needed for all Xilinx FPGAs, and -- especially for the Spartan-6 and newer CLB architectures, where a local reset can -- reduce the usability of the slice registers, due to the need to share the control -- set (RESET/PRESET, CLOCK ENABLE and CLOCK) by all 8 registers in a slice. -- By using GSR for the initialization, and reducing RESET local init to the really -- essential, the model achieves better LUT/FF packing and CLB usability. ------------------------------------------------------------------------------------------ -- internal state signals for register and combinatorial stages signal state_next : natural range N downto 0 := 0; -- state 0 is idle state signal state_reg : natural range N downto 0 := 0; -- state 0 is idle state -- shifter signals for register and combinatorial stages signal sh_next : std_logic_vector (N-1 downto 0); signal sh_reg : std_logic_vector (N-1 downto 0); -- mosi and miso connections signal rx_bit_next : std_logic; -- sample of MOSI input signal tx_bit_next : std_logic; signal tx_bit_reg : std_logic; -- drives MISO during sequential logic signal preload_miso : std_logic; -- controls the MISO MUX -- buffered di_i data signals for register and combinatorial stages signal di_reg : std_logic_vector (N-1 downto 0); -- internal wren_i stretcher for fsm combinatorial stage signal wren : std_logic; signal wr_ack_next : std_logic := '0'; signal wr_ack_reg : std_logic := '0'; -- buffered do_o data signals for register and combinatorial stages signal do_buffer_next : std_logic_vector (N-1 downto 0); signal do_buffer_reg : std_logic_vector (N-1 downto 0); -- internal signal to flag transfer to do_buffer_reg signal do_transfer_next : std_logic := '0'; signal do_transfer_reg : std_logic := '0'; -- internal input data request signal signal di_req_next : std_logic := '0'; signal di_req_reg : std_logic := '0'; -- cross-clock do_valid_o logic signal do_valid_next : std_logic := '0'; signal do_valid_A : std_logic := '0'; signal do_valid_B : std_logic := '0'; signal do_valid_C : std_logic := '0'; signal do_valid_D : std_logic := '0'; signal do_valid_o_reg : std_logic := '0'; -- cross-clock di_req_o logic signal di_req_o_next : std_logic := '0'; signal di_req_o_A : std_logic := '0'; signal di_req_o_B : std_logic := '0'; signal di_req_o_C : std_logic := '0'; signal di_req_o_D : std_logic := '0'; signal di_req_o_reg : std_logic := '0'; begin --============================================================================================= -- GENERICS CONSTRAINTS CHECKING --============================================================================================= -- minimum word width is 8 bits assert N >= 8 report "Generic parameter 'N' error: SPI shift register size needs to be 8 bits minimum" severity FAILURE; -- maximum prefetch lookahead check assert PREFETCH <= N-5 report "Generic parameter 'PREFETCH' error: lookahead count out of range, needs to be N-5 maximum" severity FAILURE; --============================================================================================= -- GENERATE BLOCKS --============================================================================================= --============================================================================================= -- DATA INPUTS --============================================================================================= -- connect rx bit input rx_bit_proc : rx_bit_next <= spi_mosi_i; --============================================================================================= -- CROSS-CLOCK PIPELINE TRANSFER LOGIC --============================================================================================= -- do_valid_o and di_req_o strobe output logic -- this is a delayed pulse generator with a ripple-transfer FFD pipeline, that generates a -- fixed-length delayed pulse for the output flags, at the parallel clock domain out_transfer_proc : process ( clk_i, do_transfer_reg, di_req_reg, do_valid_A, do_valid_B, do_valid_D, di_req_o_A, di_req_o_B, di_req_o_D) is begin if clk_i'event and clk_i = '1' then -- clock at parallel port clock -- do_transfer_reg -> do_valid_o_reg do_valid_A <= do_transfer_reg; -- the input signal must be at least 2 clocks long do_valid_B <= do_valid_A; -- feed it to a ripple chain of FFDs do_valid_C <= do_valid_B; do_valid_D <= do_valid_C; do_valid_o_reg <= do_valid_next; -- registered output pulse -------------------------------- -- di_req_reg -> di_req_o_reg di_req_o_A <= di_req_reg; -- the input signal must be at least 2 clocks long di_req_o_B <= di_req_o_A; -- feed it to a ripple chain of FFDs di_req_o_C <= di_req_o_B; di_req_o_D <= di_req_o_C; di_req_o_reg <= di_req_o_next; -- registered output pulse end if; -- generate a 2-clocks pulse at the 3rd clock cycle do_valid_next <= do_valid_A and do_valid_B and not do_valid_D; di_req_o_next <= di_req_o_A and di_req_o_B and not di_req_o_D; end process out_transfer_proc; -- parallel load input registers: data register and write enable in_transfer_proc: process (clk_i, wren_i, wr_ack_reg) is begin -- registered data input, input register with clock enable if clk_i'event and clk_i = '1' then if wren_i = '1' then di_reg <= di_i; -- parallel data input buffer register end if; end if; -- stretch wren pulse to be detected by spi fsm (ffd with sync preset and sync reset) if clk_i'event and clk_i = '1' then if wren_i = '1' then -- wren_i is the sync preset for wren wren <= '1'; elsif wr_ack_reg = '1' then -- wr_ack is the sync reset for wren wren <= '0'; end if; end if; end process in_transfer_proc; --============================================================================================= -- REGISTER TRANSFER PROCESSES --============================================================================================= -- fsm state and data registers change on spi SHIFT_EDGE core_reg_proc : process (spi_sck_i, spi_ssel_i) is begin -- FFD registers clocked on SHIFT edge and cleared on idle (spi_ssel_i = 1) -- state fsm register (fdr) if spi_ssel_i = '1' then -- async clr state_reg <= 0; -- state falls back to idle when slave not selected elsif spi_sck_i'event and spi_sck_i = SHIFT_EDGE then -- on SHIFT edge, update state register state_reg <= state_next; -- core fsm changes state with spi SHIFT clock end if; -- FFD registers clocked on SHIFT edge -- rtl core registers (fd) if spi_sck_i'event and spi_sck_i = SHIFT_EDGE then -- on fsm state change, update all core registers sh_reg <= sh_next; -- core shift register do_buffer_reg <= do_buffer_next; -- registered data output do_transfer_reg <= do_transfer_next; -- cross-clock transfer flag di_req_reg <= di_req_next; -- input data request wr_ack_reg <= wr_ack_next; -- wren ack for data load synchronization end if; -- FFD registers clocked on CHANGE edge and cleared on idle (spi_ssel_i = 1) -- miso MUX preload control register (fdp) if spi_ssel_i = '1' then -- async preset preload_miso <= '1'; -- miso MUX sees top bit of parallel input when slave not selected elsif spi_sck_i'event and spi_sck_i = CHANGE_EDGE then -- on CHANGE edge, change to tx_reg output preload_miso <= spi_ssel_i; -- miso MUX sees tx_bit_reg when it is driven by SCK end if; -- FFD registers clocked on CHANGE edge -- tx_bit register (fd) if spi_sck_i'event and spi_sck_i = CHANGE_EDGE then tx_bit_reg <= tx_bit_next; -- update MISO driver from the MSb end if; end process core_reg_proc; --============================================================================================= -- COMBINATORIAL LOGIC PROCESSES --============================================================================================= -- state and datapath combinatorial logic core_combi_proc : process ( sh_reg, sh_next, state_reg, tx_bit_reg, rx_bit_next, do_buffer_reg, do_transfer_reg, di_reg, di_req_reg, wren, wr_ack_reg) is begin -- all output signals are assigned to (avoid latches) sh_next <= sh_reg; -- shift register tx_bit_next <= tx_bit_reg; -- MISO driver do_buffer_next <= do_buffer_reg; -- output data buffer do_transfer_next <= do_transfer_reg; -- output data flag wr_ack_next <= wr_ack_reg; -- write enable acknowledge di_req_next <= di_req_reg; -- data input request state_next <= state_reg; -- fsm control state case state_reg is when (N) => -- deassert 'di_rdy' and stretch do_valid wr_ack_next <= '0'; -- acknowledge data in transfer di_req_next <= '0'; -- prefetch data request: deassert when shifting data tx_bit_next <= sh_reg(N-1); -- output next MSbit sh_next(N-1 downto 1) <= sh_reg(N-2 downto 0); -- shift inner bits sh_next(0) <= rx_bit_next; -- shift in rx bit into LSb state_next <= state_reg - 1; -- update next state at each sck pulse when (N-1) downto (PREFETCH+3) => -- remove 'do_transfer' and shift bits do_transfer_next <= '0'; -- reset 'do_valid' transfer signal di_req_next <= '0'; -- prefetch data request: deassert when shifting data wr_ack_next <= '0'; -- remove data load ack for all but the load stages tx_bit_next <= sh_reg(N-1); -- output next MSbit sh_next(N-1 downto 1) <= sh_reg(N-2 downto 0); -- shift inner bits sh_next(0) <= rx_bit_next; -- shift in rx bit into LSb state_next <= state_reg - 1; -- update next state at each sck pulse when (PREFETCH+2) downto 3 => -- raise prefetch 'di_req_o' signal di_req_next <= '1'; -- request data in advance to allow for pipeline delays wr_ack_next <= '0'; -- remove data load ack for all but the load stages tx_bit_next <= sh_reg(N-1); -- output next MSbit sh_next(N-1 downto 1) <= sh_reg(N-2 downto 0); -- shift inner bits sh_next(0) <= rx_bit_next; -- shift in rx bit into LSb state_next <= state_reg - 1; -- update next state at each sck pulse when 2 => -- transfer received data to do_buffer_reg on next cycle di_req_next <= '1'; -- request data in advance to allow for pipeline delays wr_ack_next <= '0'; -- remove data load ack for all but the load stages tx_bit_next <= sh_reg(N-1); -- output next MSbit sh_next(N-1 downto 1) <= sh_reg(N-2 downto 0); -- shift inner bits sh_next(0) <= rx_bit_next; -- shift in rx bit into LSb do_transfer_next <= '1'; -- signal transfer to do_buffer on next cycle do_buffer_next <= sh_next; -- get next data directly into rx buffer state_next <= state_reg - 1; -- update next state at each sck pulse when 1 => -- transfer rx data to do_buffer and restart if new data is written sh_next(0) <= rx_bit_next; -- shift in rx bit into LSb di_req_next <= '0'; -- prefetch data request: deassert when shifting data state_next <= N; -- next state is top bit of new data if wren = '1' then -- load tx register if valid data present at di_reg wr_ack_next <= '1'; -- acknowledge data in transfer sh_next(N-1 downto 1) <= di_reg(N-2 downto 0); -- shift inner bits tx_bit_next <= di_reg(N-1); -- first output bit comes from the MSb of parallel data else wr_ack_next <= '0'; -- no data reload for continuous transfer mode sh_next(N-1 downto 1) <= (others => '0'); -- clear transmit shift register tx_bit_next <= '0'; -- send ZERO end if; when 0 => -- idle state: start and end of transmission sh_next(0) <= rx_bit_next; -- shift in rx bit into LSb sh_next(N-1 downto 1) <= di_reg(N-2 downto 0); -- shift inner bits tx_bit_next <= di_reg(N-1); -- first output bit comes from the MSb of parallel data wr_ack_next <= '1'; -- acknowledge data in transfer di_req_next <= '0'; -- prefetch data request: deassert when shifting data do_transfer_next <= '0'; -- clear signal transfer to do_buffer state_next <= N; -- next state is top bit of new data when others => state_next <= 0; -- safe state end case; end process core_combi_proc; --============================================================================================= -- OUTPUT LOGIC PROCESSES --============================================================================================= -- data output processes do_o_proc : do_o <= do_buffer_reg; -- do_o always available do_valid_o_proc: do_valid_o <= do_valid_o_reg; -- copy registered do_valid_o to output di_req_o_proc: di_req_o <= di_req_o_reg; -- copy registered di_req_o to output wr_ack_o_proc: wr_ack_o <= wr_ack_reg; -- copy registered wr_ack_o to output ----------------------------------------------------------------------------------------------- -- MISO driver process: preload top bit of parallel data to MOSI at reset ----------------------------------------------------------------------------------------------- -- this is a MUX that selects the combinatorial next tx bit at reset, and the registered tx bit -- at sequential operation. The mux gives us a preload of the first bit, simplifying the shifter logic. spi_miso_o_proc: process (preload_miso, tx_bit_reg, di_reg) is begin if preload_miso = '1' then spi_miso_o <= di_reg(N-1); -- copy top bit of parallel data at reset else spi_miso_o <= tx_bit_reg; -- copy top bit of shifter at sequential operation end if; end process spi_miso_o_proc; --============================================================================================= -- DEBUG LOGIC PROCESSES --============================================================================================= -- these signals are useful for verification, and can be deleted after debug. do_transfer_proc: do_transfer_o <= do_transfer_reg; state_debug_proc: state_dbg_o <= std_logic_vector(to_unsigned(state_reg, 4)); -- export internal state to debug rx_bit_next_proc: rx_bit_next_o <= rx_bit_next; wren_o_proc: wren_o <= wren; sh_reg_debug_proc: sh_reg_dbg_o <= sh_reg; -- export sh_reg to debug end architecture rtl;
the ucf for spi master .
##Clock signal
Net "m_clk_i" LOC=V10 | IOSTANDARD=LVCMOS33;
Net "m_clk_i" TNM_NET = sys_clk_pin;
TIMESPEC TS_sys_clk_pin = PERIOD sys_clk_pin 100000 kHz;
## 12 pin connectors
##JB
Net "m_spi_sck_o" LOC = K2 | IOSTANDARD = LVCMOS33; #Bank = 3, pin name = IO_L38P_M3DQ2, Sch name = JB1
Net "m_spi_ssel_o" LOC = K1 | IOSTANDARD = LVCMOS33; #Bank = 3, pin name = IO_L38N_M3DQ3, Sch name = JB2
Net "m_spi_mosi_o" LOC = L4 | IOSTANDARD = LVCMOS33; #Bank = 3, pin name = IO_L39P_M3LDQS, Sch name = JB3
Net "m_spi_miso_i" LOC = L3 | IOSTANDARD = LVCMOS33; #Bank = 3, pin name = IO_L39N_M3LDQSN, Sch name = JB4
the ucf for spi slave
##Clock signal
Net "s_clk_i" LOC=V10 | IOSTANDARD=LVCMOS33;
Net "s_clk_i" TNM_NET = sys_clk_pin;
Net "s_spi_ssel_i" LOC = J1 | IOSTANDARD = LVCMOS33; #Bank = 3, pin name = IO_L40N_M3DQ7, Sch name = JB8
Net "s_spi_mosi_i" LOC = K3 | IOSTANDARD = LVCMOS33; #Bank = 3, pin name = IO_L42N_GCLK24_M3LDM, Sch name = JB9
Net "s_spi_miso_o" LOC = K5 | IOSTANDARD = LVCMOS33; #Bank = 3, pin name = IO_L43N_GCLK22_IRDY2_M3CASN, Sch name = JB10
