ismailov-e
Member level 1
Hi everybody!!
I am writing ADMA FSM in SD Host Controller.
The Host Controller has ADMA System Address that uses as a pointer for Descriptor table of System Memory.
In specification they are explained that one descriptor line consumes 64-bit
(8-byte) memory space, 63-32 is address; 31-16 is length; 15-6 is reserved; and other bits is attribute.
The ADMA System Address also 64 bit register. I though that driver puts one descriptor line 64-bit to ADMA System Address 64-bit.
I little bit confused, because in explanation of ADMA System Address they wrote that 32-bit Address Descriptor uses lower 32-bit of this register and The ADMA increments this register address, which points to next line, when every fetching a Descriptor line.
So I have many questions but I would ask few of them:
1.Does the Host Controller interrupts for every executed Descriptor line?
2.If first 32 bits of ADMA Syst. reg. is for address, what is other bits for?
3.Does the ADMA on host controller increments the address after executing one Descriptor line?
4.Does the addresses of Descriptor table is address to write/read data?
