[moved] ZedBoard communication with on-board memory
bilal_oct
Full Member level 1
How to transfer data packets from ZYNQ to DDR3 memory available on ZedBoard ? Is it possible to do this task without involving the Zynq processing system ?
Re: ZedBoard communication with on-board memory
There is the DDR controller (the MIG) that interfaces the DDR3 memory. It can be generated either to have an AXI4 i/f or an User i/f. If you have a logic through which you can drive the signals of the AXI or User i/f that can initiate write/read transactions, then just go ahead and do it.
btw- you didn't mention the source of your data packets, is it generated on the zync (perhaps by some other logic blocks) or is it coming from some external source/s?
