Frequensy shift modulation and phase modulation!!!
Hishamsaleh
Full Member level 1
through bulding antenna... an array antenna to get a scaning beam probagation I need to change phase shift of transmetted signal to let the beam scan the area needed.. how can I do that... I need onlythe idea of how to design my transmitter. a block diagram or what ever...
thanks
ya! the problem is that i couldn't get a useful diagram or design to change the phase w/t changing the frequency!
Am I lost in this????
I want to scan this beam!
this pic may help u... the main beam is what i need to rotate... lets say from 45 to -45 degree...
phase modulation is easily done
by using a varicap diode at the referance xtal in the pll
this way you freq modulate the referance oscillator of the pll a little this results in phase modulation of the carrier
another way is too do a similar thing too the vco
but this gives phase freq modulation so is no use too you
stick to also feeding audio as i described to the referances
i hope i helped
Maybe you can use adaptive array techniques
When implementing scanning arrays you usually use several antenna elements (dipoles for example), and the beam direction is determined by the relative phase shift between the elements.
A simple way to create a phase shift is to insert a delay line in the path of each antenna element.
Practically this can be easily done by switching transmission line sections in and out of the feed path.
EM algoritms like FDTD (XFDTD,ZELAND,CST MWS,ANSOFT)
I think that CST MWS is the best choice !
