+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Advanced Member level 3
    Points: 4,693, Level: 16
    Join Date
    Feb 2012
    Posts
    806
    Points
    4,693
    Level
    16
    Unwanted voltage drop across gate resistor.
    I am trying to make tunable negative biasing for an oscillator at 10GHz. I am using negative bias generator IC connected to 10kOhm potentiometer (center pin to additional 100kOhm resistor goes to gate stub, two other pins to GND and -3v generator.).
    100kOhm resistor connected to gate stub using high impedance line and quarterwave stub on it. Also there is additional 1nF and 10pF capacitors to ground. And still I observe voltage drop around 0.4v through 100kOhm resistor. When biasing becomes more negative and oscillation stopped, voltage drop disappears. Which makes me think 10GHz AC signal is somehow reaching biasing resistor or something other is going wrong.
    From what i learned no current flows to gate, and voltage drop across Rg must be zero.
    I thought i made anything proper. Quarterwave stub and 10pF must stop 10GHz from reaching 100kOhm resistor. Also i made additional "test" quarterwave stubs at LO input of mixer to check their efficiency, and their length is surely right, as mixer starts to work only after cutting them.
    Long time ago i tried to make multiplier with similar biasing scheme and it looked ok.
    •   Alt24th April 2015, 04:07
      advertising
  2. #2
    Advanced Member level 5
    Points: 34,469, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,667
    Points
    34,469
    Level
    45
    Blog Entries
    7
    Re: Unwanted voltage drop across gate resistor.
    AC gate current with RF is from MIller Capacitance and increases as RdsOn reduces often called Ciss. and if rectified slightly produce dc bias current from driver
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
    1 members found this post helpful.
