thebadtall
Full Member level 6
Hello, I intend to build a pair of wireless - totally cordless speakers, using class D amplifier on each speaker, battery and audio receiver
I will probably use fm receiver on the speakers and car fm transmitter to transmit the audio signal.
Maximum range will be less than 10meters without obstacles. Do you know how the stereo would sound in this configuration ? ( i will amplify left channel on the first speaker box and the right channel on the second speaker box )
Can you suggest me another way to achieve this goal, for instance without using fm transmitter / receivers?
Thank you
Thank you
