IndiJones
Full Member level 2
I'm working with 30-bit TIF image captured by a camera. The camera outputs 10 bits/pixel for each of the three channels. The captured file is saved as 'Test.TIF'. When I try to open it using 'imread' in Matlab, I get the following error message:
QUOTE
??? C:\MATLAB701\work\Test.tif: Cannot handle different per-sample values for field "BitsPerSample".
error ==> imagesci\private\readtif at 32
[X, map, details] = rtifc(filename, args.index);
error ==> imread at 308
[X, map] = feval(fmt_s.read, filename, extraArgs{:});
UNQUOTE
How will I be able to read the file without doing any modifications?
Thanks!
QUOTE
UNQUOTE
Thanks!
