[SOLVED] system verilog squareroot with out rounding....
dipin
Full Member level 4
hi,
in system verilog , to find the square root $sqrt(x) function can be used . but it is rounding the values.
example if the input value is 95 then $sqrt(x) will give root as 10.
is there any way to get it as 9??????
i have tried t**0.5 also. but it too rounding the value.:???:
i am new in system verilog. if you know please help.
thanks & regards
$sqrt() doesn't perform any rounding, it takes place because you assign the result to integer variable.
To get the intended result, learn about $floor() and $ceil(). You should also get a basic understanding of numeric types and automatic type conversions in SV to solve similar problems yourself.
Reactions: dipin
    dipin
hi,
thanks fvm . i used $floor()
regards
