Help me design a map in CPLD and check its functionality with Chipscope
vaf20
Full Member level 3
hi again
i want to map a design in a CPLD and then check it's functionality.this CPLD mounted on a board and is a part of close loop with other.it seems functionality will be checked with ChipScope during circuit's normal operation.
could anyone tell me how it would be?
tnx
chipscope cpld status
Chipscope does not support CPLD! You have to try it on FPGA
chipscope qick start guide
why CPLD's are not supported by ChipScope? JTAG chian is the same as FPGA.
what is chipscope
really sorry for my misunderstanding!
which rule play RAM in chipscope?
tnx ahead
cpld coolrunner chipscope
RAM is used to store captured data. You define condition which will be used as a trigger for internal data capturing in real-time. After that you can download this data from FPGA through JTAG to analyse in PC. CPLD has no memory (just limited number of FFs), so there is no place to store captured data.
debugging with chipscope stimulus
Does anyone have a good quick start on ChipScope?
tnx again
xilinx chipscope training
what if i am using a vio core? i think it does not need a ramblock?
cpld chipscope
Altera has In-system Sources and Probes Editor that allows on-line debugging also with CPLD, with limit acquisition capabilities, but unlike Chipscope/SignalTap also as a stimulus. May be Xilinx has something similar?
cpld/chipscope
Try Scanseer. It's a boundary-scan software like ChipScope, but it works with any chips that supports boundary-scan, not only Xilinx FPGAs. So it should work fine with your CPLD.
Re: cpld/chipscope
Update about Scanseer: Scanseer was rebranded and is now called TopJTAG Probe. It's available here: http://www.topjtag.com/probe/
