Error during simulation: ncvhdl of SPI master-slave in cadence
priyankari
Newbie level 1
This is my test_bench of the main code for the master and slave:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
library work;
use work.all;
ENTITY spi_loopback_test IS
GENERIC (
N : positive := 32; -- 32bit serial word length is default
CPOL : std_logic := '0'; -- SPI mode selection (mode 0 default)
CPHA : std_logic := '1'; -- CPOL = clock polarity, CPHA = clock phase.
PREFETCH : positive := 2 -- prefetch lookahead cycles
END spi_loopback_test;
ARCHITECTURE behavior OF spi_loopback_test IS
-- Component declaration for the Unit Under Test (UUT)
****COMPONENT spi_loopback
****PORT(
********m_clk_i : IN std_logic;
********m_rst_i : IN std_logic;
********m_spi_miso_i : IN std_logic;
********m_di_i : IN std_logic_vector(31 downto 0);
********m_wren_i : IN std_logic;
********s_clk_i : IN std_logic;
********s_spi_ssel_i : IN std_logic;
********s_spi_sck_i : IN std_logic;
********s_spi_mosi_i : IN std_logic;
********s_di_i : IN std_logic_vector(31 downto 0);
********s_wren_i : IN std_logic;
********m_spi_ssel_o : OUT std_logic;
********m_spi_sck_o : OUT std_logic;
********m_spi_mosi_o : OUT std_logic;
********m_di_req_o : OUT std_logic;
********m_do_valid_o : OUT std_logic;
********m_do_o : OUT std_logic_vector(31 downto 0);
********m_do_transfer_o : OUT std_logic;
********m_wren_o : OUT std_logic;
********m_wren_ack_o : OUT std_logic;
********m_rx_bit_reg_o : OUT std_logic;
********m_state_dbg_o : OUT std_logic_vector(5 downto 0);
********m_core_clk_o : OUT std_logic;
********m_core_n_clk_o : OUT std_logic;
********m_sh_reg_dbg_o : OUT std_logic_vector(31 downto 0);
********s_spi_miso_o : OUT std_logic;
********s_di_req_o : OUT std_logic;
********s_do_valid_o : OUT std_logic;
********s_do_o : OUT std_logic_vector(31 downto 0);
********s_do_transfer_o : OUT std_logic;
********s_wren_o : OUT std_logic;
********s_wren_ack_o : OUT std_logic;
********s_rx_bit_reg_o : OUT std_logic;
********s_state_dbg_o : OUT std_logic_vector(5 downto 0)
****END COMPONENT;
-- constants
constant fifo_memory_size : integer := 16;
-- types
type fifo_memory_type is array (0 to fifo_memory_size-1) of std_logic_vector (N-1 downto 0));
-- signals to connect the instances
-- internal clk and rst
signal m_clk : std_logic := '0'; -- clock domain for the master parallel interface. Must be faster than spi bus sck.
signal s_clk : std_logic := '0'; -- clock domain for the slave parallel interface. Must be faster than spi bus sck.
signal rst : std_logic := 'U';
-- spi bus wires
signal spi_sck : std_logic;
signal spi_ssel : std_logic;
signal spi_miso : std_logic;
signal spi_mosi : std_logic;
-- master parallel interface
signal di_m : std_logic_vector (N-1 downto 0) := (others => '0');
signal do_m : std_logic_vector (N-1 downto 0) := (others => 'U');
signal do_valid_m : std_logic;
signal do_transfer_m : std_logic;
signal di_req_m : std_logic;
signal wren_m : std_logic := '0';
signal wren_o_m : std_logic := 'U';
signal wren_ack_o_m : std_logic := 'U';
signal rx_bit_reg_m : std_logic;
signal state_m : std_logic_vector (5 downto 0);
signal core_clk_o_m : std_logic;
signal core_n_clk_o_m : std_logic;
signal sh_reg_m : std_logic_vector (N-1 downto 0) := (others => '0');
-- slave parallel interface
signal di_s : std_logic_vector (N-1 downto 0) := (others => '0');
signal do_s : std_logic_vector (N-1 downto 0) := (others => 'U');
signal do_valid_s : std_logic;
signal do_transfer_s : std_logic;
signal di_req_s : std_logic;
signal wren_s : std_logic := '0';
signal wren_o_s : std_logic := 'U';
signal wren_ack_o_s : std_logic := 'U';
signal rx_bit_reg_s : std_logic;
signal state_s : std_logic_vector (5 downto 0);
-- signal sh_reg_s : std_logic_vector (N-1 downto 0);
-- Clock period definitions
constant m_clk_period : time := 10 ns; -- 100MHz master parallel clock
constant s_clk_period : time := 10 ns; -- 100MHz slave parallel clock
BEGIN
-- Component instantiation for the Unit Under Test (UUT)
Inst_spi_loopback: spi_loopback
port map(
----------------MASTER-----------------------
m_clk_i => m_clk,
m_rst_i => rst,
m_spi_ssel_o => spi_ssel,
m_spi_sck_o => spi_sck,
m_spi_mosi_o => spi_mosi,
m_spi_miso_i => spi_miso,
m_di_req_o => di_req_m,
m_di_i => di_m,
m_wren_i => wren_m,
m_do_valid_o => do_valid_m,
m_do_o => do_m,
----- debug -----
m_do_transfer_o => do_transfer_m,
m_wren_o => wren_o_m,
m_wren_ack_o => wren_ack_o_m,
m_rx_bit_reg_o => rx_bit_reg_m,
m_state_dbg_o => state_m,
m_core_clk_o => core_clk_o_m,
m_core_n_clk_o => core_n_clk_o_m,
m_sh_reg_dbg_o => sh_reg_m,
----------------SLAVE-----------------------
s_clk_i => s_clk,
s_spi_ssel_i => spi_ssel,
s_spi_sck_i => spi_sck,
s_spi_mosi_i => spi_mosi,
s_spi_miso_o => spi_miso,
s_di_req_o => di_req_s,
s_di_i => di_s,
s_wren_i => wren_s,
s_do_valid_o => do_valid_s,
s_do_o => do_s,
--- debug -----
s_do_transfer_o => do_transfer_s,
s_wren_o => wren_o_s,
s_wren_ack_o => wren_ack_o_s,
s_rx_bit_reg_o => rx_bit_reg_s,
s_state_dbg_o => state_s
-- s_sh_reg_dbg_o => sh_reg_s
-- Clock generator processes
m_clk_process : process
begin
m_clk <= '0';
wait for m_clk_period/2;
m_clk <= '1';
end process m_clk_process;
s_clk_process : process
begin
s_clk <= '0';
wait for s_clk_period/2;
s_clk <= '1';
end process s_clk_process;
-- rst_i process
rst <= '0', '1' after 20 ns, '0' after 100 ns;
-- Master interface process
master_tx_fifo_proc: process
variable fifo_memory : fifo_memory_type :=
(X"87654321",X"abcdef01",X"faceb007",X"10203049",X"85a5a5a5",X"7aaa5551",X"7adecabe",X"57564789",
X"12345678",X"beefbeef",X"fee1600d",X"f158ba17",X"5ee1a7e3",X"101096da",X"600ddeed",X"deaddead");
variable fifo_head : integer range 0 to fifo_memory_size-1;
begin
-- synchronous rst_i
wait until rst = '1';
wait until m_clk'event and m_clk = '1';
di_m <= (others => '0');
wren_m <= '0';
fifo_head := 0;
wait until rst = '0';
wait until di_req_m = '1'; -- wait shift register request for data
-- load next fifo contents into shift register
for cnt in 0 to (fifo_memory_size/2)-1 loop
fifo_head := cnt; -- pre-compute next pointer
wait until m_clk'event and m_clk = '1'; -- sync fifo data load at next rising edge
di_m <= fifo_memory(fifo_head); -- place data into tx_data input bus
wren_m <= '1'; -- write data into spi master
wren_m <= '0'; -- remove write enable signal
end loop;
wait until spi_ssel = '1';
wait for 2000 ns;
for cnt in (fifo_memory_size/2) to fifo_memory_size-1 loop
end loop;
wait;
end process master_tx_fifo_proc;
-- Slave interface process
slave_tx_fifo_proc: process
(X"90201031",X"97640231",X"ef55aaf1",X"babaca51",X"b00b1ee5",X"51525354",X"81828384",X"91929394",
X"be575ec5",X"2fa57410",X"cafed0ce",X"afadab0a",X"bac7ed1a",X"f05fac75",X"2acbac7e",X"12345678");
begin
wait until s_clk'event and s_clk = '1';
di_s <= (others => '0');
wren_s <= '0';
fifo_head := 0;
wait until di_req_s = '1'; -- wait shift register request for data
for cnt in 0 to fifo_memory_size-1 loop
wait until s_clk'event and s_clk = '1'; -- sync fifo data load at next rising edge
di_s <= fifo_memory(fifo_head); -- place data into tx_data input bus
wren_s <= '1'; -- write data into shift register
wren_s <= '0'; -- remove write enable signal
end loop;
wait;
end process slave_tx_fifo_proc;
END behavior;
my errors are in LINES 241 and 242:
ncvhdl_p: *E,EXPTYP : expecting an expression of type FIFO_MEMORY_TYPE
Can somebody help me with this error?
It looks right to me. Maybe those "X" s in front of your data should be lower case.
There seems to an extra parenthesis at the end of the type declaration..
