Paul Wardlaw
Newbie level 1
Hi, Ive got a problem where I am trying to create PWM's depending on the initials of your name. Its to have 2 pulses for the first initial, and then 2 for the second. And keep getting the error "Can't resolve multiple constant drivers for net "i[2]" i[1] etc. Any advice .....
//Design that will output a signal that will control a small servo
//Length of output pulses are dictated by the users first and second initials
//Looking up the corresponding ASII code for said initials
//Two output pulses (2 high, 2 low) for each inital and then resets.
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 module controller (clock, select, PWM_o, count, i); input clock, select; output reg PWM_o; output reg [2:0] i = 0; output reg [16:0] count = 0; always @(posedge PWM_o) if (PWM_o == 1) //Seperate counter that counts the amount of output pulses begin //2 Pulses of each initial needed i=i+1; end always @(posedge clock) begin count <= count+1; //Counter matches the input clock frequency, used to control the output pulses end always @(posedge count) begin if (select == 1) //Select chooses the PWM, 1 for Uppercase letters, 0 for Lowercase begin if (i<2) //Sets up loop conditions for first initial, so we get 2 pulses begin if (count < 65617) //Conditions for output wave, resulting in 2 pulses of 1.31ms PWM_o <= 0; else PWM_o <= 1; end else begin if (count < 67024) //Conditions for output wave (pulse 2),second inital PWM_o <= 0; else PWM_o <= 1; end if (i==4) //If 4 pulses have been completed, resets and starts pulsing again begin i = 0; end end else //If select = 0, lowercase initials are used begin if (i<2) //Sets up loop conditions for first initial, so we get 2 pulses begin if (count < 72046) //Conditions for output wave, resulting in 2 pulses of 1.44ms PWM_o <= 0; else PWM_o <= 1; end else begin if (count < 72993) //Conditions for output wave (pulse 2), second initial PWM_o <= 0; else PWM_o <= 1; end if (i==4) //If 4 pulses have been completed, resets and starts pulsing again begin i = 0; end end end endmodule
