[PIC] Phase angle control of thyristor w/ PIC18F
theredkid
Newbie level 5
Hello,
For the following code, I get some errors:
#include <18F452.h>
#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock = 4000000)
unsigned char FlagReg;
sbit ZC at FlagReg.B0;
void interrupt(){
if (INTCON.INTF){ //INTF flag raised, so external interrupt occured
ZC = 1;
INTCON.INTF = 0;
void main() {
PORTB = 0;
TRISB = 0x01; //RB0 input for interrupt
PORTA = 0;
ADCON1 = 7; //Disable ADC
TRISA = 0xFF; //Make all PORTA inputs
PORTD = 0;
TRISD = 0; //PORTD all output
OPTION_REG.INTEDG = 0; //interrupt on falling edge
INTCON.INTF = 0; //clear interrupt flag
INTCON.INTE = 1; //enable external interrupt
INTCON.GIE = 1; //enable global interrupt
while (1){
if (ZC){ //zero crossing occurred
delay_ms(2);
PORTD.B0 = 1; //Send a pulse
delay_us(250);
PORTD.B0 = 0;
ZC = 0;
And error list is as follows:
Clean: Deleting intermediary and output files.
Clean: Deleted file "p3.ESYM".
Clean Warning: File "D:\mehmet projeler\p1\p3.o" doesn't exist.
Clean: Deleted file "p3.ERR".
Clean: Deleted file "D:\mehmet projeler\p1\p3.mcs".
Clean: Done.
Executing: "C:\Program files\PICC\CCSC.exe" +FH "p3.c" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 48 "p3.c" Line 6(6,10): Expecting a (
*** Error 48 "p3.c" Line 6(12,14): Expecting a (
*** Error 43 "p3.c" Line 6(19,20): Expecting a declaration
*** Error 48 "p3.c" Line 6(20,22): Expecting a (
*** Error 12 "p3.c" Line 9(10,16): Undefined identifier INTCON
*** Error 12 "p3.c" Line 10(12,14): Undefined identifier ZC
*** Error 12 "p3.c" Line 11(9,15): Undefined identifier INTCON
*** Error 12 "p3.c" Line 16(12,17): Undefined identifier PORTB
*** Error 12 "p3.c" Line 17(12,17): Undefined identifier TRISB
*** Error 12 "p3.c" Line 18(12,17): Undefined identifier PORTA
*** Error 12 "p3.c" Line 19(13,19): Undefined identifier ADCON1
*** Error 12 "p3.c" Line 20(12,17): Undefined identifier TRISA
*** Error 12 "p3.c" Line 21(12,17): Undefined identifier PORTD
*** Error 12 "p3.c" Line 22(12,17): Undefined identifier TRISD
*** Error 12 "p3.c" Line 23(6,16): Undefined identifier OPTION_REG
*** Error 12 "p3.c" Line 24(6,12): Undefined identifier INTCON
*** Error 12 "p3.c" Line 25(6,12): Undefined identifier INTCON
*** Error 12 "p3.c" Line 26(6,12): Undefined identifier INTCON
*** Error 12 "p3.c" Line 29(16,18): Undefined identifier ZC
*** Error 12 "p3.c" Line 31(15,20): Undefined identifier PORTD
*** Error 12 "p3.c" Line 33(15,20): Undefined identifier PORTD
*** Error 12 "p3.c" Line 34(18,20): Undefined identifier ZC
22 Errors, 0 Warnings.
Build Failed.
Halting build on first failure as requested.
BUILD FAILED: Tue Sep 02 11:43:52 2014
What's wrong above???
While writing this code,did you select the correct microcontroller when you were creating this using the new project option?
The errors,you are experiencing,they have happened because the relevant microcontroller name has not been noticed correctly by the compiler....maybe.Write this code while going through new project option again.....might work out this time.
#include <18F252.h>//3faz full control T0
#device ADC=8
#fuses HS,NOWDT,NOPUT,NOLVP,NOBROWNOUT,NOCPD,NOWRT,NODEBUG
#use delay(clock=20000000)
/***entegreterbiyecisi@yahoo.com***/
#use fast_io(A)
#use fast_io(B)
#Byte Port_A = 0xF80
#Byte Port_B = 0xF81
#Byte Port_C = 0xF82
int16 tg1=0,tg2=0,tg3=0,set1=300,set=50;
int8 g1=0,g2=0,g3=0,i=0;
#INT_TIMER0
void temp(){
set_timer0(170);
if(set1>tg1){tg1++;if(set==tg1){g1=1;}}
if(set1>tg2){tg2++;if(set==tg2){g2=1;}}
if(set1>tg3){tg3++;if(set==tg3){g3=1;}}
#INT_EXT
void phase0(){//full wave R zerocros
tg1=0;
#INT_EXT1
void phase1(){//full wave S zerocros
tg2=0;
#INT_EXT2
void phase2(){//full wave T zerocros
tg3=0;
void main(){
set_tris_B(0b00001111);
set_tris_A(0b000111111);
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_INTERNAL);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2|T0_8_BIT);
enable_interrupts(int_timer0);//.2*2*220*85=7840US+is=9ms
enable_interrupts(INT_EXT); //20mhz t0 adc st0
enable_interrupts(INT_EXT1);
enable_interrupts(INT_EXT2);
ext_int_edge(L_TO_H);
enable_interrupts(GLOBAL);
while(true){
if(g1==1){output_bit(PIN_B5,1);delay_us(100);output_bit(PIN_B5,0);g1=0;}//trig R
if(g2==1){output_bit(PIN_B6,1);delay_us(100);output_bit(PIN_B6,0);g2=0;}//trig S
if(g3==1){output_bit(PIN_B7,1);delay_us(100);output_bit(PIN_B7,0);g3=0;}//trig T
i++;
if(i>=100){
set_adc_channel(0); //pot oku
delay_us(10);
set=read_adc();
delay_us(10);
if(set<7){set=7;}
if(set>210){set=210;}
i=0;
