+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Junior Member level 3
    Points: 168, Level: 2
    Join Date
    Aug 2014
    Posts
    26
    Points
    168
    Level
    Problem with Systematic offset / Bandgap circuit
    Hi to all great designers !
    In allen Holberg I find this page and I see that mathing of two transistor is a point of problem (ie. current density should be equal and I do matching NMOS to NMOS)
    Click image for larger version.
    I`m trying to make Bandgap ref 1V supply, now I have problem with systematic offset, which I see between Vgs(N_CLl) and VDS( N_CLr). This two voltage should be equal right?
    But in my circuit the second stage is PMOS( P_BGRl) and there is a problem with mathing right? Because I can do same current density but this two device has different threshold voltage. So I try to make current density equal but Im not sure if this is good solution.
  2. #2
    Advanced Member level 2
    Points: 4,889, Level: 16
    Dominik Przyborowski's Avatar
    Join Date
    Jun 2013
    Norway
    Posts
    651
    Points
    4,889
    Level
    16
    Re: Problem with Systematic offset / Bandgap circuit
    Change your amplifier to OTA (differential pair loaded by current mirrors) or design it as floded cascode.
    1 members found this post helpful.
    •   Alt20th August 2014, 12:04
      advertising
  3. #3
    Join Date
    Aug 2014
    Posts
    26
    Points
    168
    Level
    Hi dominik,
    so in case of OTA ( symmetrical ota) can we write this equation for systematic offset solving?
    I. Vgs7=Vds8=Vgs10
    and therefore
    II, Id7/(W/L)7=Id10/(W/L)10
    Is it correct or is there any other equation? And about folded cascode what condition should be there and how it all work?
  4. #4
    Join Date
    Jun 2013
    Norway
    Posts
    651
    Points
    4,889
    Level
    16
    When You using symetrical OTA You don't worry about matching between any OTA current mirror transistors and driving stage.
    In folded cascode case the loading current mirror on pfets (I assuming input pair made also on pfets) should be match to driving transistors.
    •   Alt20th August 2014, 21:38
      advertising
  5. #5
    Newbie level 6
    Points: 1,380, Level: 8
    Achievements:
    7 years registered
    Join Date
    May 2008
    Posts
    14
    Points
    1,380
    Level
    8
    Whenever you use an NMOS Active Load referred to ground to drive a PMOS gain stage referred to VDD you'll have a systematic offset.
    Symmetrical OTA is an option or use a 2 stage amplifier (higher DC gain -> better Vp/Vn matching)
  6. #6
    Join Date
    Aug 2014
    Posts
    26
    Points
    168
    Level
    Well I try it but there is still some 90mV systematic offset, so where is the mistake?
    ( thanks culho, 2 stage amplifier isnt for me right now => stability issue)
  7. #7
    Join Date
    Jun 2013
    Norway
    Posts
    651
    Points
    4,889
    Level
    16
    I see only 0.5mV of offset. Where You have this 90mV?
    •   Alt21st August 2014, 12:14
      advertising
  8. #8
    Join Date
    Aug 2014
    Posts
    26
    Points
    168
    Level
    Vdio - Vout is systematic offset isn't it?
    All this stuff about systematic offset start at this picture, where my mentor told me that VGS(NM1)=511mV MINUS VDS(NM0)=339mV is systematic offset.
  9. #9
    Newbie level 6
    Achievements:
    7 years registered
    Join Date
    May 2008
    Posts
    14
    Points
    1,380
    Level
    8
    You can only get rid of systematic offsets if matched devices are operating in the same region. The VDS of the two devices are are not the same but if they are both deeply saturated in strong inversion the IDS current offset is very small. That is why you only see 0.5mV of offset at the input of your diff pair.
  10. #10
    Join Date
    Aug 2014
    Posts
    26
    Points
    168
    Level
    Thank you guys again, in the end I use folded cascode topology and everything is better, I like it ! :)
