mvliege
Junior Member level 2
I used internal oscillator with PIC18F46K22 but, I have faced this problem (it's delay problem in the lcd.c, it appears when I complied. )
"function used but not defined delay_ms 609 SRC=1356"
problem is about using internal oscillator?
you can find an image for code the following attachment below
thank you,
thank you,
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 #include <main.h> #FUSES INTRC_IO #include <lcd.c> int a=0; #use delay(internal=64MHz) #INT_TIMER0 void TIMER0_isr(void) { set_timer0(15536); if(a==1) output_low(pin_c0); output_toggle(pin_c1); printf(lcd_putc,"\f ERROR \n PLC CHECK"); } #INT_EXT void EXT_isr(void) { if(input(pin_b0)==1) a=1; }
