+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Points: 555, Level: 5
    Join Date
    Jul 2013
    Posts
    Points
    555
    Level
    Optocoupler with common ground?
    I recently saw a circuit using an optocoupler with a common ground.
    Is there any reason you would want to use an optocoupler this way?
    To me the circuit the circuit looked pointless, same functionality could be achieved using a single transistor.
    Am I missing something here?
    •   Alt6th July 2014, 18:31
      advertising
  2. #2
    Advanced Member level 5
    Points: 17,788, Level: 32
    Achievements:
    7 years registered
    crutschow's Avatar
    Join Date
    Feb 2012
    L.A. USA Zulu -8
    Posts
    3,480
    Points
    17,788
    Level
    32
    Re: Optocoupler with common ground?
    It does seem like there would be no use for a optocoupler with a common ground. Sometimes they are used when someone wants "isolation" not realizing that such a connection does not achieve the desired result. Can you post the circuit?
    Zapper
    Curmudgeon Elektroniker
    •   Alt6th July 2014, 20:03
      advertising
  3. #3
    Join Date
    Jul 2013
    Posts
    Points
    555
    Level
    I don't have the circuit, I saw the design from a made PCB.
    The cathode of the led in the optocoupler was shorted with the ground of the micro-controller, and the emitter of the transistor was tied to an I/O pin.
    •   Alt6th July 2014, 20:16
      advertising
  4. #4
    Points: 34,469, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,667
    Points
    34,469
    Level
    45
    Blog Entries
    7
    pointless, loss of common mode rejection and HV isolation.
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
  5. #5
    Points: 13,357, Level: 27
    schmitt trigger's Avatar
    Join Date
    Apr 2013
    C4E4DEEEDCE6ECD2
    Posts
    2,249
    Points
    13,357
    Level
    27
    Engineers or designers are people. People make mistakes. This is clearly one of them.
    An optocoupler, specially the cheaper ones, are not very good at transmitting information. Its current gain most times is below unity. The frequency response sucks. Actual output drive is limited.
    The only reason one puts up with the limitations is because of isolation. But if you have common grounds, it is absolutely pointless.
