behrazv
Hi everyone,
We have a custom board with the AGL060V2 FPGA (Actel) and the FPGA is not getting programmed. Programmer gives me an error:
Here are the screenshots for TDI, TDO, and TCK:
Do you know what the issue could be?
There is also a problem with the power - the VCC is pushed to 2.7 when 3.3V is connected to VJTAG. When we connect 1.5V to VCC, FPGA draws 50 mA and still the VCC remains at 2.7V. The screenshots are made for the case when VCC is floating, but if we do connect VCC to 1.5V nothing is working either - same error.
Please help.
Thank you in advance!
(Sometimes TDO is stuck at 1 sometimes at 0 - with a long sequence of zeros after "Compare Data".Error: programmer '92256' : Signal Integrity Failure
Integrity Check Pattern Not Found.
Integrity Check Pattern :
550FAAF000FF0000FFFF
IrScan Error.
TDO stuck at 1
Chain Analysis Failed.
Error: programmer '92256' : Data Bit length : 8272
Error: programmer '92256' : Compare Data : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF...
Error: programmer '92256' : Scan Chain FAILED.
Error: Failed to run Action.
Please help.
