znzn
So basically these are the steps I used in impedance matching.
1. Find impedance of square patch.
2. Add a feedline to eliminate the imaginary part of the impedance
3. use calculator to obtain the width and length of quarter wave feedline
4. Add Quarter wave .
Based on the result, i've obtained a total impedance approximately of 49+j1 impedance. I supposed this is a matched patched antenna, but the problem is that, my total efficiency simulated keep on getting -5db which is not good.
Below attached is the file. Can some1 enlighten me which part is wrong?
