+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Points: 56, Level: 1
    Join Date
    Jan 2014
    Posts
    Points
    56
    Level
    difference between DC small signal gain and AC small signal gain ?
    Hi
    Can anyone please tell me if there is a difference between DC small signal gain and AC small signal gain ?
    Thank you
    •   Alt2nd March 2014, 23:49
      advertising
  2. #2
    Advanced Member level 5
    Points: 48,710, Level: 53
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Toronto area of Canada
    Posts
    8,482
    Points
    48,710
    Level
    53
    Re: difference between DC small signal gain and AC small signal gain ?
    The capacitance of a transistor and its wiring is a filter and produces negative feedback from the collector to its base due to the Miller effect which reduces the hfe AC small signal current gain.
    The hFE DC small signal current gain is not affected so it is the highest.
    Fairchild's datasheet for the 2N3904 transistor shows a graph of the hfe AC small signal current gain dropping as the frequency gets higher.
    •   Alt3rd March 2014, 00:43
      advertising
  3. #3
    Points: 39,714, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,691
    Points
    39,714
    Level
    48
    I must confess that I have some problems to understand the meaning of "small signal dc gain". According to Audiogurus answer this would be identical to the small-signal ac gain for low frequencies.
    Moreover, the current gain depends, of course, on the quiescent collector current Ic. However, can this property lead to a term like "small signal dc gain"?
    •   Alt3rd March 2014, 09:08
      advertising
  4. #4
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Posts
    8,482
    Points
    48,710
    Level
    53
    They say "small" because the gain is different at different currents and when near saturation.
