dear all, i doing my master thesis i am feeling in implementation of dsp block in fpga using serial gigbit Ethernet, plz do suggest any hint regarding this ..
You could do it directly with coding - but producing a matlab model first will help you decide if your HDL is correct.
Dear user,
Please help me, I am in deep trouble, i choose my master project on FPGA, I want to be designed and implement FIR filter into FPGA using high-speed serial gigabit.
I Have write a code in FPGA but I am unable to implement it onto FPGA board using gigabit serial interface, can anyone help me in this regards.
Br:
Sarwan
I think you have a misunderstanding of the problem. You don't implement FIR filters using a gigabit serial interface. You supply data to or send data from the FPGA via the gigabit serial interface. The FIR filter is a normal FPGA implementation of a FIR, which the FPGA vendor probably already has an IP core that you can use.
It's really confusing.
Gigabit is just an interface to send data from A to B.
You surely don't want to process the pure gigabit signals with your FIR filter. You rather want to process some data that are transmitted using gigabit interface.
But where do the data come from? ADConverter? Continously streaming signal like audio? What data rate?
Or an image of a 3D scanner?
Or something else?
I recommend to focus on one problem, then solve it, then focus on the next problem.
