+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 1
    Points: 1,106, Level: 7
    xianweng's Avatar
    Join Date
    Aug 2011
    Posts
    32
    Points
    1,106
    Level
    7
    How an amp would oscillate if it's phase margin blew 0
    Hi ,everybody
    If PM of an amp below 0,it will oscillate nearby Vref or from 0 to VDD or something else?
    Click image for larger version.
    best regards
    •   Alt1st September 2013, 17:10
      advertising
  2. #2
    Advanced Member level 5
    Points: 39,714, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,691
    Points
    39,714
    Level
    48
    Re: How an amp would oscillate if it's phase margin blew 0
    It will oscillate at a frequency that belongs to a loop gain phase of zero deg.
    •   Alt1st September 2013, 17:28
      advertising
  3. #3
    Super Moderator
    Points: 241,738, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,971
    Points
    241,738
    Level
    100
    Stability is primarly discussed in small signal analysis. As you'll know, it uses a simplified linear OP modell and doesn't care for signal magnitude. Thus it can't answer your question.
    When advancing to large signal analysis, you have to notice the various nonlinear effects of a real system.
    To consider a simple case, the OP might show an almost linear characteristic until the output voltage is clipped near the supply rails and no slew rate limiting takes place. If the circuit oscillates at all, the oscillation magnitude will raise then up to the supply limits. Strictly speaking, the loop gain must be slightly larger than unity to get an increasing oscillation magnitude. For more complex OP characteristics, the real behaviour won't be easily to predict.
    1 members found this post helpful.
    •   Alt1st September 2013, 18:13
      advertising
  4. #4
    Member level 1
    xianweng's Avatar
    Join Date
    Aug 2011
    Posts
    32
    Points
    1,106
    Level
    7
    LvW,FvM
    Thank you, I see
