rx5
Full Member level 2
tl494 irfz44 step up
hi all..... I dont know how much voltage is present at the output of
this HV circuit... could someone maybe have a rough idea???
circuit:
TL494 on complementary output, each output pin driving a single IRFZ44
n-ch MOSFET... frequency is around 50-100kHz adjustable.. actually its
a modified ("build a poor man's PLASMA GLOBE Electronics NOw Aug 1997
issue)... i used TL494 in place of the SG3525 chip.. but same freq
range output... modified a "standard b/w FLYBACK with .02in thick shim
(spacing between U-U core)... with 15T bifilar primary.... supply is
around 12VDC@2A.... the mag has no note on how much voltage it
generates....
anyone out there have any rough idea for its output voltage and
current????
cuz, im planning to use this HV to drive an experimental Tesla coil...
i dunno IF THESE could drive those...
tnx for any info..
circuit:
generates....
current????
tnx for any info..
