[SOLVED] Help-- full wave rectifier on PSPICE design
mohit571
New Delhi, India, India
I have designed a full wave rectifier on CAPTURE on Pspice 16.3v with non linear load, but all ends show zero volt and zero amp. also while compiling it shows " No pspice template for < > , ignoring.
Pls suggest me...!!
  • design.doc
"No PSpice template" means what it says, you are probably using schematic symbols that aren't taken from the PSpice specific component library.
Before designing a simulation circuit from the scratch with Orcad capture, you should start with something more simple, e.g. opening and modifying one of the examples shipped with Pspice. Learn about the simulation related component attributes and how Spice models are linked to the component.
