[SOLVED] Morgan Chopper Circuit with SCR trigger circuit
Briez
Member level 5
I am new to this morgan chopper DC-DC converter. I have taken reference circuit from the book Khanchandani.
I want to make Morgan Chopper circuit for Motor Speed Control.
I Want Practical Circuit of Morgan Chopper and Trigger Circuit of SCR using 555 timer.
Please help me to make my project...
Hi Briez
You can easily design a morgan chopper . all you need is a current driver like a transistor and then a pulse transformer and then an SCR which depends on your power rating . and another thing that you need is reading this article !
https://sudhinpk.files.wordpress.com/2011/10/morgan-chopper.pdf
Best Wishes
Goldsmith
Hi Briez
Thanks GoldSmith for reply,
But i want to know that how many pulse should be provided to fire SCR? and in what manner should be applied?
And I have File which you have provided by URL, so can u please give me practical circuit of Firing SCR?
Hi Briez
How many pulses ? what do you mean by how many pulses ? i hope you know how an SCR works . when you trig it , it will be turned on while you attempt to turn it off . one trig pulse might be enough . it depends on what kind of load you have and situation of your load . some times when the load is very inductive the best method is using a pulse train .
Take a look here please :
In addition : there are plenty of circuits and methods for driving an SCR . you can search for them too .
Good Luck
Goldsmith
Thanks GoldSmith again,
Can you please tell me if i want to control 24V DC motor by morgan choppper just as project work, then which SCR and Diodes should be used?
Power ratings are 24V dc and 5A maximum.
Hi Briez
May i ask a question please ? why morgan chopper ? just for learning ? because you can use a PWM based DC motor velocity control which would be more simpler and with better specifications .
Anywhere , for answering your question :
BT151 would be good as your thyristor , and for diodes it depends on your load . but you can try 1n5408 or perhaps 1n4007 or UF4007 .
Best Wishes + Good Luck
Goldsmith
Thank you so much goldsmith for reply,
i want to control DC motor, but first i want to know how SCR fires and how it works. So practically i want to implement DC motor of 24V. And then i will go on higher voltage.
As you said SCR and Diode, i am downloading its datasheets and as per its rating try to make morgan chopper circuit.
Thanks Again....
Hi Briez
I understand you are learning about SCR and how it can be fired . but there are also many better ideas to use an SCR for speed control of a DC motor . why you didn't try them ? for instance something like this :
It is very trustful ! because you can control if as well as you want and also when you trig X2 , then X1 will be turned off . i.e: R1 is your DC motor !
BTW : x2 is a low power SCR but X1 is your main SCR .
However if you like to use the morgan chopper , i wish success to you too :wink:
Good luck with SCR !
Goldsmith
Reactions: Briez
    Briez
