+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Points: 869, Level: 6
    Join Date
    Feb 2013
    Khartoum, Sudan, Sudan
    Posts
    Points
    869
    Level
    LDMOS transistor stability and feedback
    Hi every one....
    I'm working on an RF PA (Polyfet L2711) , but I face some troubles in the drain current . when I turn the PA on it start with maximum current (as designed) and it decrease along its ON, this problems happen at some frequencies with different rates . I think it is the output matching but first I want to Know about feedback. Does it change the input /output impedance of the PA and if yes how to to calculate it .. Thanks
    •   Alt18th March 2013, 08:57
      advertising
  2. #2
    Advanced Member level 5
    Points: 10,533, Level: 24
    Achievements:
    7 years registered
    tony_lth's Avatar
    Join Date
    Jul 2010
    Beijing
    Posts
    1,929
    Points
    10,533
    Level
    24
    Re: LDMOS transistor stability and feedback
    surely the feedback change everything. One way is to simulate it.
    •   Alt18th March 2013, 09:19
      advertising
  3. #3
    Join Date
    Feb 2013
    Posts
    Points
    869
    Level
    thanks for interesting @tony_lth.
    I'm using ADS 2011 ... do I need to start simulation with feedback first or the matching networks
    •   Alt18th March 2013, 09:48
      advertising
  4. #4
    Points: 26,525, Level: 39
    BigBoss's Avatar
    Join Date
    Nov 2001
    Turkey
    Posts
    3,785
    Points
    26,525
    Level
    39
    This seems to be temperature drifting problem,not impedance changing or something else.
    Check your bias circuit and temperature stability of your system.
  5. #5
    Advanced Member level 1
    Points: 2,811, Level: 12
    Join Date
    Sep 2012
    Pakistan
    Posts
    414
    Points
    2,811
    Level
    12
    i don't think so that matching can cause this.. surely either temperature or feedback ... you gotta have to check both
    If you Believe everything you Read, Better Don't Read!
    •   Alt20th March 2013, 11:49
      advertising
  6. #6
    Points: 809, Level: 6
    Join Date
    Jan 2013
    Posts
    7
    Points
    809
    Level
    Quote Originally Posted by makkawi22 View Post
    Hi every one....
    Hi brother.. if possible can u tell me how did u stabilize u r transistor.. i am also using the same transistor for my design, i did stabilize my transistor.. but i am not getting high S21 which i need.. so if possible send me u r schematic to my mail id.. hkpradeepkumar@gmail.com.. i hope u help me..
