ads_ee
Full Member level 6
Folks,
I've been trying to upgrade a number of cores produced in 13.3 to the current 14.3 tool suite. I've run into a hitch though where there is a very cryptic message being generated.
I upgraded the 13.3 cores to 14.2, which worked fine, but even after that the cores still won't upgrade to the latest version of the core in 14.3.
So far I've tried this on two Win7 64-bit machines. Haven't tried with the 32-bit tools yet (Spent half the day just installing 14.3 on my laptop besides other work :-x).
I'd like it if someone can verify that they also can't upgrade a 14.2 core to a 14.3 core in CORE Generator just as a sanity check on my results.
It would also be interesting if a Linux user could try this and see if it has the same issue.
FYI. I'm using Block Memory Generator, Distributed Memory Generator, and FIFO Generator cores.
Thanks,
-alan
Thanks,
-alan
