[MOVED] C programming for conditional statement with c6713 dsp processor
chinnydas
Junior Member level 1
hi everybody,
I am developing the code for C6713 dsk with some conditional statements.
In that, i want to run
for(i=0;i<=0;i++)
printf("%d",i);
continuously, i want to run the loop like infinite times. so, what changes should made in this loop to execute infinite times?
Suggest me some options please.
Thank-You
regards;
chinny
Re: C programming for conditional statement with c6713 dsp processor
It Goes in infinite Loop and it will not show any result.
hi,
check it clearly,
 for(i=0;i>0;i++)
printf("%d",i);
regards,
chinny
the for loop can be written in a number of other ways as well
like for (i=0;;i++)
so you are concluding that this loop will run infinite times,
for(i=0;i>0;i++)
printf("%d",i);
if so, what will be the output?
what value it will produce?
its going to print i at each iteration so the output would be 0123... so on
how it is possible, still i don't understand...
when i=0, then it checks for condition, i>0, how it is possible, there is nothing i=0,i>0 i<0, 0 is what 0 right, then the loop will not execute even once..... right?
your code was for(i=0;i<=0;i++) where the test expression is i<=0
and in for(i=0;;i++) the test field is set empty so its always true
ok fine, in this case for(i=0;;i++) will always true.
what about in the case of, for(i=0;i>0;i++)?
As you said, the loop will not execute even once.
And i keeps the value i=0.
Regards
Z
