some problem in the boundary and port in the CPW by HFSS?
tw20053010
Member level 1
Dear Sir:
I also do a simulation in the CPW. But the result isnot correct, and I have put the structure in the attach. Could you help me!
Thanks a lot!!
Regards,
Wei
Re: some problem in the boundary and port in the CPW by HFSS
sry for my delayed response, I got ur messenge.
I modified your model a little bit, and it is attached here.
My comments: If you are investigating the performace of cpw only, there is no need to draw such a big substrate and the two parallel ground plane. The simulation should be accurate enough. About the wave port size, pls check the user manual.
Best Regards,
