Problem with LCD in the digital thermometer project.
Santoshhh
Newbie level 6
Hi all, I am trying to design a digital thermometer using LM35, PIC16F877A, and JHD162A LCD. I have coded the microcontroller program in MPLAB IDE and compiled it using HITEC C compiler. I burnt the program using PICKIT2. After breadboarding and finally running the circuit, I came up with an annoying result. There were 16 square blocks being displayed in the LCD in the second line and nothing in the first line. I have used a crystal of 20MHz. And I grounded those crystal pins using 0.1 uF capacitors because 22pF were unavailable. In the actual circuit diagram in the internet I've seen that 22 pF capacitors are used. Can that be a reason? The LCD displayed the same result as it showed without using the crystal. ALso, all the data pins in port B were high. Are they all supposed to be high all the time? I have attached the code herewith. My another problem is that during the simulation in PROTEUS, when I give an input of 24 degree celsius to LM35, 12 degree is displayed in the LCD, when 25 is given, 13 is displayed and when it is changed to 26, still 13 is displayed. On changing the input to 27 degree celsius, output is displayed as 14 and so on i.e. linearity is present but the output is one-halved of the expected output.
The code is:
#include<htc.h>
#define data PORTB
#define RS RD0
#define EN RD1
__CONFIG(HS & PWRTEN & BORDIS & WDTDIS & LVPDIS);
int ad_result;
/*************us delay****************/
void delay_100us(int n )
   	TMR1H=0xFE;
	TMR1L=0x0C;
	T1CKPS1=0;
	T1CKPS0=0;
	TMR1CS=0;
	TMR1IF=0;
	TMR1ON=1;
   	while(n>0)
		while(!TMR1IF)  { }
		TMR1IF=0;
		TMR1H=0xFE;
		TMR1L=0x0C;
		n--;
/***********************ms delay****************/
void delay_ms(int n )
   	TMR1H=0xEC;	// EC77H=60535d
	TMR1L=0x77;
	T1CKPS1=0;
	T1CKPS0=0;
	TMR1CS=0;
	TMR1IF=0;
	TMR1ON=1;
   	while(n>0)
		while(!TMR1IF)  { }
		TMR1IF=0;
		TMR1H=0xEC;
		TMR1L=0x77;
		n--;
/******************ADC Initialisation**************/
void init_ADC()
		PCFG3=0;	PCFG2=0;  PCFG1=0;  PCFG0=0;  		//Taking channel A as analog input
	ADCS1=1;	ADCS0=0;  ADCS2=0; 					   //Using 32 Tosc
	ADFM=0; 										  //Left Justification
/**************LCD Write********************/
void LCD_Write(unsigned char value,int rs)
	data = value;
	RS = rs;
	EN = 1;
	delay_ms(1);
	EN = 0;
/**************LCD Clear********************/
void LCD_clear(void)
	LCD_Write(0x01,0);
/**************LCD GoTo********************/
void LCD_goto(unsigned char row,unsigned char column)
	if(row==1)
		LCD_Write(0x80+column,0);	//0x80 takes the cursor at 1st row
	else if(row==2)
		LCD_Write(0xC0+column,0);	//0xC0 takes the cursor at 2ns row
/**************LCD Num********************/
void LCD_num(int n)
    if(n<=9)
	    LCD_Write(48+n,1);
    else if(n<=99)
	 LCD_Write((n/10)+48,1);
	 LCD_Write((n%10)+48,1);
    else if(n<=999)
	LCD_Write((n/100)+48,1);
	LCD_Write(((n%100)/10)+48,1);
/**************LCD Initialisation********************/
void initLCD(void)
	//PORT configuration
	TRISB = 0x00;
	TRISD=0x00;
	LCD_Write(0x30,0);
	data = 0x3;         // 8 bit mode
	EN=1; EN = 0;
	LCD_Write(0x38,0);
	delay_ms(1);
	LCD_Write(0x0E,0);    //display on , cursor blinking
	delay_ms(1);
	LCD_Write(0x01,0);    // clear display screen
	delay_ms(1);
	LCD_Write(0x06,0);
    //LCD_Write(0x0F,0);	//blinking cursor
	delay_ms(1);
	LCD_clear();
	LCD_goto(1,1);
	LCD_Write('T',1);LCD_Write('e',1); LCD_Write('m',1); LCD_Write('p',1);LCD_Write('=',1);
/***************** ADC *****************/
void ADC()
	ADON=1;
	CHS2=0; CHS1=0; CHS0=0;
	delay_100us(3);
	ADGO = 1;
	while(ADGO);
	ad_result=(int)ADRESH;
	LCD_goto(1,5);
	if(ad_result<10)
			LCD_Write(' ',1);
			LCD_Write(' ',1);
		else if(ad_result<100)
			LCD_Write(' ',1);
	LCD_num(ad_result);
/********************** Main Function ****************************/
void main()
	TRISB=0x00;				//Configuring all pins of B port as output.
	PORTB=0x00;				//output at all pins will be low
	TRISA=0xff;				//Configuring all pins of A port as input
	TRISD0=TRISD1=0;
	RD0=RD1=0;
	ADIE=0;				//A/D interrupt disabled
	ADIF=0;				//A/D flag reset
	GIE=0;
	init_ADC();
	initLCD();
	while(1)
		ADC();		//call ADC
This is the schematic on PROTEUS.
enable internal pullup registers of portB will solve your problem
add this code in main:
nRBPU=0;
hopes this will help you
Thank you. I'll try that.
nRBPU=0;
After putting the code you suggested in the main(), an error saying "unidentified error" is generated. Build unsuccessful. I could not figure out What went wrong?
you have to add the include file for pic (pic16f877a.h) after including htc.h file
or add this code instead of nRBPU=0;
OPTION_REG &=0x7F;
OPTION_REG &=0x7F;
such error is generated :
"Error   [141] E:\Santosh\New folder\New folder (2)\temperature\temp.c; 2.22 can't open include file "pic16f877a.h": No such file or directory"
********** Build failed! **********
0.1uF is almost 5000 times larger than 22pF. You need to use 22pF or a value close to it (e.g. 17pF, 27pF).
Just because it works in a simulation doesn't mean it will work in real life.
Thank you for the suggestion.
Oh!! Build successful when I built the code two times and without including the pic16f877a.h file. Including that header file generated the above mentioned error. Tomorrow I will be burning the controller again and see if it works. Fingers crossed.
1. Make sure that the LCD initializes first before the microcontroller will send control commands in the module. Do this by adding delay in your microcontroller boot-up after reset.
2. Check your contrast control.
i guess this should be your problem
also first try to check if your board is really working or not by programming a simple small program that blinks an led
Yeah, that was the problem. Sorted it out. Finally got a display on the LCD.
My another problem is that during the simulation in PROTEUS, when I give an input of 24 degree celsius to LM35, 12 degree is displayed in the LCD, when 25 is given, 13 is displayed and when it is changed to 26, still 13 is displayed. On changing the input to 27 degree celsius, output is displayed as 14 and so on i.e. linearity is present but the output is one-halved of the expected output. Which part of my code went wrong?
I thought I should speak up here.
Actually, this is incorrect. When using the Hi-Tech C Compiler only the is required to include the device specific header:
#include <htc.h>
NOT
#include <pic.h>
NOT
#include <pic16f877a.h>
When the correct device is selected within the MPLAB IDE, the header file, htc.h, correctly loads the appropriate device specific header.
Although you may want to add the device specific header file to the project window for easy reference while coding, as it contains many useful redefined macros as well as the Configuration Register Bitmasks:
Typical Location, dependent on specific compiler version.
C:\Program Files\HI-TECH Software\PICC\9.83\include\pic16f877a.h
#ifndef	_HTC_H_
[COLOR="#FF0000"]#warning Header file pic16f877a.h included directly. Use #include <htc.h> instead.[/COLOR]
#endif
/* header file for the MICROCHIP PIC microcontroller
 *  16F877A
#ifndef __PIC16F877A_H
#define __PIC16F877A_H
// Configuration mask definitions
// Config Register: CONFIG
#define CONFIG               0x2007
// Oscillator Selection bits
// RC oscillator
#define FOSC_EXTRC           0xFFFF
// HS oscillator
#define FOSC_HS              0xFFFE
// XT oscillator
#define FOSC_XT              0xFFFD
// LP oscillator
#define FOSC_LP              0xFFFC
// Watchdog Timer Enable bit
// WDT enabled
#define WDTE_ON              0xFFFF
// WDT disabled
#define WDTE_OFF             0xFFFB
// Power-up Timer Enable bit
// PWRT disabled
#define PWRTE_OFF            0xFFFF
// PWRT enabled
#define PWRTE_ON             0xFFF7
// Brown-out Reset Enable bit
// BOR enabled
#define BOREN_ON             0xFFFF
// BOR disabled
#define BOREN_OFF            0xFFBF
// Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit
// RB3/PGM pin has PGM function; low-voltage programming enabled
#define LVP_ON               0xFFFF
// RB3 is digital I/O, HV on MCLR must be used for programming
#define LVP_OFF              0xFF7F
// Data EEPROM Memory Code Protection bit
// Data EEPROM code protection off
#define CPD_OFF              0xFFFF
// Data EEPROM code-protected
#define CPD_ON               0xFEFF
// Flash Program Memory Write Enable bits
// Write protection off; all program memory may be written to by EECON control
#define WRT_OFF              0xFFFF
// 0000h to 00FFh write-protected; 0100h to 1FFFh may be written to by EECON control
#define WRT_256              0xFDFF
// 0000h to 07FFh write-protected; 0800h to 1FFFh may be written to by EECON control
#define WRT_1FOURTH          0xFBFF
// 0000h to 0FFFh write-protected; 1000h to 1FFFh may be written to by EECON control
#define WRT_HALF             0xF9FF
// In-Circuit Debugger Mode bit
// In-Circuit Debugger disabled, RB6 and RB7 are general purpose I/O pins
#define DEBUG_OFF            0xFFFF
// In-Circuit Debugger enabled, RB6 and RB7 are dedicated to the debugger
#define DEBUG_ON             0xF7FF
// Flash Program Memory Code Protection bit
// Code protection off
#define CP_OFF               0xFFFF
// All program memory code-protected
#define CP_ON                0xDFFF
// Special function register definitions
// Register: INDF
volatile unsigned char           INDF                @ 0x000;
// bit and bitfield definitions
// Register: TMR0
volatile unsigned char           TMR0                @ 0x001;
// Register: PCL
volatile unsigned char           PCL                 @ 0x002;
// Register: STATUS
volatile unsigned char           STATUS              @ 0x003;
volatile bit CARRY               @ ((unsigned)&STATUS*8)+0;
volatile bit DC                  @ ((unsigned)&STATUS*8)+1;
volatile bit ZERO                @ ((unsigned)&STATUS*8)+2;
volatile bit nPD                 @ ((unsigned)&STATUS*8)+3;
volatile bit nTO                 @ ((unsigned)&STATUS*8)+4;
volatile bit IRP                 @ ((unsigned)&STATUS*8)+7;
volatile bit RP0                 @ ((unsigned)&STATUS*8)+5;
volatile bit RP1                 @ ((unsigned)&STATUS*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	C                   : 1;
        unsigned	DC                  : 1;
        unsigned	Z                   : 1;
        unsigned	nPD                 : 1;
        unsigned	nTO                 : 1;
        unsigned	RP                  : 2;
        unsigned	IRP                 : 1;
    struct {
        unsigned	                    : 5;
        unsigned	RP0                 : 1;
        unsigned	RP1                 : 1;
} STATUSbits @ 0x003;
#endif
// Register: FSR
volatile unsigned char           FSR                 @ 0x004;
// Register: PORTA
volatile unsigned char           PORTA               @ 0x005;
volatile bit RA0                 @ ((unsigned)&PORTA*8)+0;
volatile bit RA1                 @ ((unsigned)&PORTA*8)+1;
volatile bit RA2                 @ ((unsigned)&PORTA*8)+2;
volatile bit RA3                 @ ((unsigned)&PORTA*8)+3;
volatile bit RA4                 @ ((unsigned)&PORTA*8)+4;
volatile bit RA5                 @ ((unsigned)&PORTA*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RA0                 : 1;
        unsigned	RA1                 : 1;
        unsigned	RA2                 : 1;
        unsigned	RA3                 : 1;
        unsigned	RA4                 : 1;
        unsigned	RA5                 : 1;
} PORTAbits @ 0x005;
#endif
// Register: PORTB
volatile unsigned char           PORTB               @ 0x006;
volatile bit RB0                 @ ((unsigned)&PORTB*8)+0;
volatile bit RB1                 @ ((unsigned)&PORTB*8)+1;
volatile bit RB2                 @ ((unsigned)&PORTB*8)+2;
volatile bit RB3                 @ ((unsigned)&PORTB*8)+3;
volatile bit RB4                 @ ((unsigned)&PORTB*8)+4;
volatile bit RB5                 @ ((unsigned)&PORTB*8)+5;
volatile bit RB6                 @ ((unsigned)&PORTB*8)+6;
volatile bit RB7                 @ ((unsigned)&PORTB*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RB0                 : 1;
        unsigned	RB1                 : 1;
        unsigned	RB2                 : 1;
        unsigned	RB3                 : 1;
        unsigned	RB4                 : 1;
        unsigned	RB5                 : 1;
        unsigned	RB6                 : 1;
        unsigned	RB7                 : 1;
} PORTBbits @ 0x006;
#endif
// Register: PORTC
volatile unsigned char           PORTC               @ 0x007;
volatile bit RC0                 @ ((unsigned)&PORTC*8)+0;
volatile bit RC1                 @ ((unsigned)&PORTC*8)+1;
volatile bit RC2                 @ ((unsigned)&PORTC*8)+2;
volatile bit RC3                 @ ((unsigned)&PORTC*8)+3;
volatile bit RC4                 @ ((unsigned)&PORTC*8)+4;
volatile bit RC5                 @ ((unsigned)&PORTC*8)+5;
volatile bit RC6                 @ ((unsigned)&PORTC*8)+6;
volatile bit RC7                 @ ((unsigned)&PORTC*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RC0                 : 1;
        unsigned	RC1                 : 1;
        unsigned	RC2                 : 1;
        unsigned	RC3                 : 1;
        unsigned	RC4                 : 1;
        unsigned	RC5                 : 1;
        unsigned	RC6                 : 1;
        unsigned	RC7                 : 1;
} PORTCbits @ 0x007;
#endif
// Register: PORTD
volatile unsigned char           PORTD               @ 0x008;
volatile bit RD0                 @ ((unsigned)&PORTD*8)+0;
volatile bit RD1                 @ ((unsigned)&PORTD*8)+1;
volatile bit RD2                 @ ((unsigned)&PORTD*8)+2;
volatile bit RD3                 @ ((unsigned)&PORTD*8)+3;
volatile bit RD4                 @ ((unsigned)&PORTD*8)+4;
volatile bit RD5                 @ ((unsigned)&PORTD*8)+5;
volatile bit RD6                 @ ((unsigned)&PORTD*8)+6;
volatile bit RD7                 @ ((unsigned)&PORTD*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RD0                 : 1;
        unsigned	RD1                 : 1;
        unsigned	RD2                 : 1;
        unsigned	RD3                 : 1;
        unsigned	RD4                 : 1;
        unsigned	RD5                 : 1;
        unsigned	RD6                 : 1;
        unsigned	RD7                 : 1;
} PORTDbits @ 0x008;
#endif
// Register: PORTE
volatile unsigned char           PORTE               @ 0x009;
volatile bit RE0                 @ ((unsigned)&PORTE*8)+0;
volatile bit RE1                 @ ((unsigned)&PORTE*8)+1;
volatile bit RE2                 @ ((unsigned)&PORTE*8)+2;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RE0                 : 1;
        unsigned	RE1                 : 1;
        unsigned	RE2                 : 1;
} PORTEbits @ 0x009;
#endif
// Register: PCLATH
volatile unsigned char           PCLATH              @ 0x00A;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	PCLATH              : 5;
} PCLATHbits @ 0x00A;
#endif
// Register: INTCON
volatile unsigned char           INTCON              @ 0x00B;
volatile bit RBIF                @ ((unsigned)&INTCON*8)+0;
volatile bit INTF                @ ((unsigned)&INTCON*8)+1;
volatile bit TMR0IF              @ ((unsigned)&INTCON*8)+2;
volatile bit RBIE                @ ((unsigned)&INTCON*8)+3;
volatile bit INTE                @ ((unsigned)&INTCON*8)+4;
volatile bit TMR0IE              @ ((unsigned)&INTCON*8)+5;
volatile bit PEIE                @ ((unsigned)&INTCON*8)+6;
volatile bit GIE                 @ ((unsigned)&INTCON*8)+7;
volatile bit T0IF                @ ((unsigned)&INTCON*8)+2;
volatile bit T0IE                @ ((unsigned)&INTCON*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RBIF                : 1;
        unsigned	INTF                : 1;
        unsigned	TMR0IF              : 1;
        unsigned	RBIE                : 1;
        unsigned	INTE                : 1;
        unsigned	TMR0IE              : 1;
        unsigned	PEIE                : 1;
        unsigned	GIE                 : 1;
    struct {
        unsigned	                    : 2;
        unsigned	T0IF                : 1;
        unsigned	: 2;
        unsigned	T0IE                : 1;
} INTCONbits @ 0x00B;
#endif
// Register: PIR1
volatile unsigned char           PIR1                @ 0x00C;
volatile bit TMR1IF              @ ((unsigned)&PIR1*8)+0;
volatile bit TMR2IF              @ ((unsigned)&PIR1*8)+1;
volatile bit CCP1IF              @ ((unsigned)&PIR1*8)+2;
volatile bit SSPIF               @ ((unsigned)&PIR1*8)+3;
volatile bit TXIF                @ ((unsigned)&PIR1*8)+4;
volatile bit RCIF                @ ((unsigned)&PIR1*8)+5;
volatile bit ADIF                @ ((unsigned)&PIR1*8)+6;
volatile bit PSPIF               @ ((unsigned)&PIR1*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TMR1IF              : 1;
        unsigned	TMR2IF              : 1;
        unsigned	CCP1IF              : 1;
        unsigned	SSPIF               : 1;
        unsigned	TXIF                : 1;
        unsigned	RCIF                : 1;
        unsigned	ADIF                : 1;
        unsigned	PSPIF               : 1;
    struct {
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	                    : 2;
        unsigned	: 1;
        unsigned	: 1;
} PIR1bits @ 0x00C;
#endif
// Register: PIR2
volatile unsigned char           PIR2                @ 0x00D;
volatile bit CCP2IF              @ ((unsigned)&PIR2*8)+0;
volatile bit BCLIF               @ ((unsigned)&PIR2*8)+3;
volatile bit EEIF                @ ((unsigned)&PIR2*8)+4;
volatile bit CMIF                @ ((unsigned)&PIR2*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	CCP2IF              : 1;
        unsigned	                    : 2;
        unsigned	BCLIF               : 1;
        unsigned	EEIF                : 1;
        unsigned	: 1;
        unsigned	CMIF                : 1;
} PIR2bits @ 0x00D;
#endif
// Register: TMR1L
volatile unsigned char           TMR1L               @ 0x00E;
// Register: TMR1H
volatile unsigned char           TMR1H               @ 0x00F;
// Register: TMR1
volatile unsigned int            TMR1                @ 0x00E;
// Register: T1CON
volatile unsigned char           T1CON               @ 0x010;
volatile bit TMR1ON              @ ((unsigned)&T1CON*8)+0;
volatile bit TMR1CS              @ ((unsigned)&T1CON*8)+1;
volatile bit nT1SYNC             @ ((unsigned)&T1CON*8)+2;
volatile bit T1OSCEN             @ ((unsigned)&T1CON*8)+3;
volatile bit T1SYNC              @ ((unsigned)&T1CON*8)+2;
volatile bit T1CKPS0             @ ((unsigned)&T1CON*8)+4;
volatile bit T1CKPS1             @ ((unsigned)&T1CON*8)+5;
volatile bit T1INSYNC            @ ((unsigned)&T1CON*8)+2;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TMR1ON              : 1;
        unsigned	TMR1CS              : 1;
        unsigned	nT1SYNC             : 1;
        unsigned	T1OSCEN             : 1;
        unsigned	T1CKPS              : 2;
    struct {
        unsigned	                    : 2;
        unsigned	T1SYNC              : 1;
        unsigned	: 1;
        unsigned	T1CKPS0             : 1;
        unsigned	T1CKPS1             : 1;
    struct {
        unsigned	: 2;
        unsigned	T1INSYNC            : 1;
} T1CONbits @ 0x010;
#endif
// Register: TMR2
volatile unsigned char           TMR2                @ 0x011;
// Register: T2CON
volatile unsigned char           T2CON               @ 0x012;
volatile bit TMR2ON              @ ((unsigned)&T2CON*8)+2;
volatile bit T2CKPS0             @ ((unsigned)&T2CON*8)+0;
volatile bit T2CKPS1             @ ((unsigned)&T2CON*8)+1;
volatile bit TOUTPS0             @ ((unsigned)&T2CON*8)+3;
volatile bit TOUTPS1             @ ((unsigned)&T2CON*8)+4;
volatile bit TOUTPS2             @ ((unsigned)&T2CON*8)+5;
volatile bit TOUTPS3             @ ((unsigned)&T2CON*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	T2CKPS              : 2;
        unsigned	TMR2ON              : 1;
        unsigned	TOUTPS              : 4;
    struct {
        unsigned	T2CKPS0             : 1;
        unsigned	T2CKPS1             : 1;
        unsigned	                    : 1;
        unsigned	TOUTPS0             : 1;
        unsigned	TOUTPS1             : 1;
        unsigned	TOUTPS2             : 1;
        unsigned	TOUTPS3             : 1;
} T2CONbits @ 0x012;
#endif
// Register: SSPBUF
volatile unsigned char           SSPBUF              @ 0x013;
// Register: SSPCON
volatile unsigned char           SSPCON              @ 0x014;
volatile bit CKP                 @ ((unsigned)&SSPCON*8)+4;
volatile bit SSPEN               @ ((unsigned)&SSPCON*8)+5;
volatile bit SSPOV               @ ((unsigned)&SSPCON*8)+6;
volatile bit WCOL                @ ((unsigned)&SSPCON*8)+7;
volatile bit SSPM0               @ ((unsigned)&SSPCON*8)+0;
volatile bit SSPM1               @ ((unsigned)&SSPCON*8)+1;
volatile bit SSPM2               @ ((unsigned)&SSPCON*8)+2;
volatile bit SSPM3               @ ((unsigned)&SSPCON*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	SSPM                : 4;
        unsigned	CKP                 : 1;
        unsigned	SSPEN               : 1;
        unsigned	SSPOV               : 1;
        unsigned	WCOL                : 1;
    struct {
        unsigned	SSPM0               : 1;
        unsigned	SSPM1               : 1;
        unsigned	SSPM2               : 1;
        unsigned	SSPM3               : 1;
} SSPCONbits @ 0x014;
#endif
// Register: CCPR1L
volatile unsigned char           CCPR1L              @ 0x015;
// Register: CCPR1H
volatile unsigned char           CCPR1H              @ 0x016;
// Register: CCPR1
volatile unsigned int            CCPR1               @ 0x015;
// Register: CCP1CON
volatile unsigned char           CCP1CON             @ 0x017;
volatile bit CCP1Y               @ ((unsigned)&CCP1CON*8)+4;
volatile bit CCP1X               @ ((unsigned)&CCP1CON*8)+5;
volatile bit CCP1M0              @ ((unsigned)&CCP1CON*8)+0;
volatile bit CCP1M1              @ ((unsigned)&CCP1CON*8)+1;
volatile bit CCP1M2              @ ((unsigned)&CCP1CON*8)+2;
volatile bit CCP1M3              @ ((unsigned)&CCP1CON*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	CCP1M               : 4;
        unsigned	CCP1Y               : 1;
        unsigned	CCP1X               : 1;
    struct {
        unsigned	CCP1M0              : 1;
        unsigned	CCP1M1              : 1;
        unsigned	CCP1M2              : 1;
        unsigned	CCP1M3              : 1;
} CCP1CONbits @ 0x017;
#endif
// Register: RCSTA
volatile unsigned char           RCSTA               @ 0x018;
volatile bit RX9D                @ ((unsigned)&RCSTA*8)+0;
volatile bit OERR                @ ((unsigned)&RCSTA*8)+1;
volatile bit FERR                @ ((unsigned)&RCSTA*8)+2;
volatile bit ADDEN               @ ((unsigned)&RCSTA*8)+3;
volatile bit CREN                @ ((unsigned)&RCSTA*8)+4;
volatile bit SREN                @ ((unsigned)&RCSTA*8)+5;
volatile bit RX9                 @ ((unsigned)&RCSTA*8)+6;
volatile bit SPEN                @ ((unsigned)&RCSTA*8)+7;
volatile bit RCD8                @ ((unsigned)&RCSTA*8)+0;
volatile bit RC9                 @ ((unsigned)&RCSTA*8)+6;
volatile bit nRC8                @ ((unsigned)&RCSTA*8)+6;
volatile bit RC8_9               @ ((unsigned)&RCSTA*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RX9D                : 1;
        unsigned	OERR                : 1;
        unsigned	FERR                : 1;
        unsigned	ADDEN               : 1;
        unsigned	CREN                : 1;
        unsigned	SREN                : 1;
        unsigned	RX9                 : 1;
        unsigned	SPEN                : 1;
    struct {
        unsigned	RCD8                : 1;
        unsigned	                    : 5;
        unsigned	RC9                 : 1;
    struct {
        unsigned	: 6;
        unsigned	nRC8                : 1;
    struct {
        unsigned	: 6;
        unsigned	RC8_9               : 1;
} RCSTAbits @ 0x018;
#endif
// Register: TXREG
volatile unsigned char           TXREG               @ 0x019;
// Register: RCREG
volatile unsigned char           RCREG               @ 0x01A;
// Register: CCPR2L
volatile unsigned char           CCPR2L              @ 0x01B;
// Register: CCPR2H
volatile unsigned char           CCPR2H              @ 0x01C;
// Register: CCPR2
volatile unsigned int            CCPR2               @ 0x01B;
// Register: CCP2CON
volatile unsigned char           CCP2CON             @ 0x01D;
volatile bit CCP2Y               @ ((unsigned)&CCP2CON*8)+4;
volatile bit CCP2X               @ ((unsigned)&CCP2CON*8)+5;
volatile bit CCP2M0              @ ((unsigned)&CCP2CON*8)+0;
volatile bit CCP2M1              @ ((unsigned)&CCP2CON*8)+1;
volatile bit CCP2M2              @ ((unsigned)&CCP2CON*8)+2;
volatile bit CCP2M3              @ ((unsigned)&CCP2CON*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	CCP2M               : 4;
        unsigned	CCP2Y               : 1;
        unsigned	CCP2X               : 1;
    struct {
        unsigned	CCP2M0              : 1;
        unsigned	CCP2M1              : 1;
        unsigned	CCP2M2              : 1;
        unsigned	CCP2M3              : 1;
} CCP2CONbits @ 0x01D;
#endif
// Register: ADRESH
volatile unsigned char           ADRESH              @ 0x01E;
// Register: ADCON0
volatile unsigned char           ADCON0              @ 0x01F;
volatile bit ADON                @ ((unsigned)&ADCON0*8)+0;
volatile bit GO_nDONE            @ ((unsigned)&ADCON0*8)+2;
volatile bit GO                  @ ((unsigned)&ADCON0*8)+2;
volatile bit CHS0                @ ((unsigned)&ADCON0*8)+3;
volatile bit CHS1                @ ((unsigned)&ADCON0*8)+4;
volatile bit CHS2                @ ((unsigned)&ADCON0*8)+5;
volatile bit ADCS0               @ ((unsigned)&ADCON0*8)+6;
volatile bit ADCS1               @ ((unsigned)&ADCON0*8)+7;
volatile bit nDONE               @ ((unsigned)&ADCON0*8)+2;
volatile bit GO_DONE             @ ((unsigned)&ADCON0*8)+2;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	ADON                : 1;
        unsigned	                    : 1;
        unsigned	GO_nDONE            : 1;
        unsigned	CHS                 : 3;
        unsigned	ADCS                : 2;
    struct {
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 3;
        unsigned	: 2;
    struct {
        unsigned	: 2;
        unsigned	GO                  : 1;
        unsigned	CHS0                : 1;
        unsigned	CHS1                : 1;
        unsigned	CHS2                : 1;
        unsigned	ADCS0               : 1;
        unsigned	ADCS1               : 1;
    struct {
        unsigned	: 2;
        unsigned	nDONE               : 1;
    struct {
        unsigned	: 2;
        unsigned	GO_DONE             : 1;
} ADCON0bits @ 0x01F;
#endif
// Special function register definitions: Bank 1
// Register: OPTION_REG
volatile unsigned char           OPTION_REG          @ 0x081;
volatile bit PSA                 @ ((unsigned)&OPTION_REG*8)+3;
volatile bit T0SE                @ ((unsigned)&OPTION_REG*8)+4;
volatile bit T0CS                @ ((unsigned)&OPTION_REG*8)+5;
volatile bit INTEDG              @ ((unsigned)&OPTION_REG*8)+6;
volatile bit nRBPU               @ ((unsigned)&OPTION_REG*8)+7;
volatile bit PS0                 @ ((unsigned)&OPTION_REG*8)+0;
volatile bit PS1                 @ ((unsigned)&OPTION_REG*8)+1;
volatile bit PS2                 @ ((unsigned)&OPTION_REG*8)+2;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	PS                  : 3;
        unsigned	PSA                 : 1;
        unsigned	T0SE                : 1;
        unsigned	T0CS                : 1;
        unsigned	INTEDG              : 1;
        unsigned	nRBPU               : 1;
    struct {
        unsigned	PS0                 : 1;
        unsigned	PS1                 : 1;
        unsigned	PS2                 : 1;
} OPTION_REGbits @ 0x081;
#endif
// Register: TRISA
volatile unsigned char           TRISA               @ 0x085;
volatile bit TRISA0              @ ((unsigned)&TRISA*8)+0;
volatile bit TRISA1              @ ((unsigned)&TRISA*8)+1;
volatile bit TRISA2              @ ((unsigned)&TRISA*8)+2;
volatile bit TRISA3              @ ((unsigned)&TRISA*8)+3;
volatile bit TRISA4              @ ((unsigned)&TRISA*8)+4;
volatile bit TRISA5              @ ((unsigned)&TRISA*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TRISA0              : 1;
        unsigned	TRISA1              : 1;
        unsigned	TRISA2              : 1;
        unsigned	TRISA3              : 1;
        unsigned	TRISA4              : 1;
        unsigned	TRISA5              : 1;
} TRISAbits @ 0x085;
#endif
// Register: TRISB
volatile unsigned char           TRISB               @ 0x086;
volatile bit TRISB0              @ ((unsigned)&TRISB*8)+0;
volatile bit TRISB1              @ ((unsigned)&TRISB*8)+1;
volatile bit TRISB2              @ ((unsigned)&TRISB*8)+2;
volatile bit TRISB3              @ ((unsigned)&TRISB*8)+3;
volatile bit TRISB4              @ ((unsigned)&TRISB*8)+4;
volatile bit TRISB5              @ ((unsigned)&TRISB*8)+5;
volatile bit TRISB6              @ ((unsigned)&TRISB*8)+6;
volatile bit TRISB7              @ ((unsigned)&TRISB*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TRISB0              : 1;
        unsigned	TRISB1              : 1;
        unsigned	TRISB2              : 1;
        unsigned	TRISB3              : 1;
        unsigned	TRISB4              : 1;
        unsigned	TRISB5              : 1;
        unsigned	TRISB6              : 1;
        unsigned	TRISB7              : 1;
} TRISBbits @ 0x086;
#endif
// Register: TRISC
volatile unsigned char           TRISC               @ 0x087;
volatile bit TRISC0              @ ((unsigned)&TRISC*8)+0;
volatile bit TRISC1              @ ((unsigned)&TRISC*8)+1;
volatile bit TRISC2              @ ((unsigned)&TRISC*8)+2;
volatile bit TRISC3              @ ((unsigned)&TRISC*8)+3;
volatile bit TRISC4              @ ((unsigned)&TRISC*8)+4;
volatile bit TRISC5              @ ((unsigned)&TRISC*8)+5;
volatile bit TRISC6              @ ((unsigned)&TRISC*8)+6;
volatile bit TRISC7              @ ((unsigned)&TRISC*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TRISC0              : 1;
        unsigned	TRISC1              : 1;
        unsigned	TRISC2              : 1;
        unsigned	TRISC3              : 1;
        unsigned	TRISC4              : 1;
        unsigned	TRISC5              : 1;
        unsigned	TRISC6              : 1;
        unsigned	TRISC7              : 1;
} TRISCbits @ 0x087;
#endif
// Register: TRISD
volatile unsigned char           TRISD               @ 0x088;
volatile bit TRISD0              @ ((unsigned)&TRISD*8)+0;
volatile bit TRISD1              @ ((unsigned)&TRISD*8)+1;
volatile bit TRISD2              @ ((unsigned)&TRISD*8)+2;
volatile bit TRISD3              @ ((unsigned)&TRISD*8)+3;
volatile bit TRISD4              @ ((unsigned)&TRISD*8)+4;
volatile bit TRISD5              @ ((unsigned)&TRISD*8)+5;
volatile bit TRISD6              @ ((unsigned)&TRISD*8)+6;
volatile bit TRISD7              @ ((unsigned)&TRISD*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TRISD0              : 1;
        unsigned	TRISD1              : 1;
        unsigned	TRISD2              : 1;
        unsigned	TRISD3              : 1;
        unsigned	TRISD4              : 1;
        unsigned	TRISD5              : 1;
        unsigned	TRISD6              : 1;
        unsigned	TRISD7              : 1;
} TRISDbits @ 0x088;
#endif
// Register: TRISE
volatile unsigned char           TRISE               @ 0x089;
volatile bit TRISE0              @ ((unsigned)&TRISE*8)+0;
volatile bit TRISE1              @ ((unsigned)&TRISE*8)+1;
volatile bit TRISE2              @ ((unsigned)&TRISE*8)+2;
volatile bit PSPMODE             @ ((unsigned)&TRISE*8)+4;
volatile bit IBOV                @ ((unsigned)&TRISE*8)+5;
volatile bit OBF                 @ ((unsigned)&TRISE*8)+6;
volatile bit IBF                 @ ((unsigned)&TRISE*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TRISE0              : 1;
        unsigned	TRISE1              : 1;
        unsigned	TRISE2              : 1;
        unsigned	                    : 1;
        unsigned	PSPMODE             : 1;
        unsigned	IBOV                : 1;
        unsigned	OBF                 : 1;
        unsigned	IBF                 : 1;
} TRISEbits @ 0x089;
#endif
// Register: PIE1
volatile unsigned char           PIE1                @ 0x08C;
volatile bit TMR1IE              @ ((unsigned)&PIE1*8)+0;
volatile bit TMR2IE              @ ((unsigned)&PIE1*8)+1;
volatile bit CCP1IE              @ ((unsigned)&PIE1*8)+2;
volatile bit SSPIE               @ ((unsigned)&PIE1*8)+3;
volatile bit TXIE                @ ((unsigned)&PIE1*8)+4;
volatile bit RCIE                @ ((unsigned)&PIE1*8)+5;
volatile bit ADIE                @ ((unsigned)&PIE1*8)+6;
volatile bit PSPIE               @ ((unsigned)&PIE1*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TMR1IE              : 1;
        unsigned	TMR2IE              : 1;
        unsigned	CCP1IE              : 1;
        unsigned	SSPIE               : 1;
        unsigned	TXIE                : 1;
        unsigned	RCIE                : 1;
        unsigned	ADIE                : 1;
        unsigned	PSPIE               : 1;
} PIE1bits @ 0x08C;
#endif
// Register: PIE2
volatile unsigned char           PIE2                @ 0x08D;
volatile bit CCP2IE              @ ((unsigned)&PIE2*8)+0;
volatile bit BCLIE               @ ((unsigned)&PIE2*8)+3;
volatile bit EEIE                @ ((unsigned)&PIE2*8)+4;
volatile bit CMIE                @ ((unsigned)&PIE2*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	CCP2IE              : 1;
        unsigned	                    : 2;
        unsigned	BCLIE               : 1;
        unsigned	EEIE                : 1;
        unsigned	: 1;
        unsigned	CMIE                : 1;
} PIE2bits @ 0x08D;
#endif
// Register: PCON
volatile unsigned char           PCON                @ 0x08E;
volatile bit nBOR                @ ((unsigned)&PCON*8)+0;
volatile bit nPOR                @ ((unsigned)&PCON*8)+1;
volatile bit nBO                 @ ((unsigned)&PCON*8)+0;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	nBOR                : 1;
        unsigned	nPOR                : 1;
    struct {
        unsigned	nBO                 : 1;
} PCONbits @ 0x08E;
#endif
// Register: SSPCON2
volatile unsigned char           SSPCON2             @ 0x091;
volatile bit SEN                 @ ((unsigned)&SSPCON2*8)+0;
volatile bit RSEN                @ ((unsigned)&SSPCON2*8)+1;
volatile bit PEN                 @ ((unsigned)&SSPCON2*8)+2;
volatile bit RCEN                @ ((unsigned)&SSPCON2*8)+3;
volatile bit ACKEN               @ ((unsigned)&SSPCON2*8)+4;
volatile bit ACKDT               @ ((unsigned)&SSPCON2*8)+5;
volatile bit ACKSTAT             @ ((unsigned)&SSPCON2*8)+6;
volatile bit GCEN                @ ((unsigned)&SSPCON2*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	SEN                 : 1;
        unsigned	RSEN                : 1;
        unsigned	PEN                 : 1;
        unsigned	RCEN                : 1;
        unsigned	ACKEN               : 1;
        unsigned	ACKDT               : 1;
        unsigned	ACKSTAT             : 1;
        unsigned	GCEN                : 1;
} SSPCON2bits @ 0x091;
#endif
// Register: PR2
volatile unsigned char           PR2                 @ 0x092;
// Register: SSPADD
volatile unsigned char           SSPADD              @ 0x093;
// Register: SSPSTAT
volatile unsigned char           SSPSTAT             @ 0x094;
volatile bit BF                  @ ((unsigned)&SSPSTAT*8)+0;
volatile bit UA                  @ ((unsigned)&SSPSTAT*8)+1;
volatile bit R_nW                @ ((unsigned)&SSPSTAT*8)+2;
volatile bit S                   @ ((unsigned)&SSPSTAT*8)+3;
volatile bit P                   @ ((unsigned)&SSPSTAT*8)+4;
volatile bit D_nA                @ ((unsigned)&SSPSTAT*8)+5;
volatile bit CKE                 @ ((unsigned)&SSPSTAT*8)+6;
volatile bit SMP                 @ ((unsigned)&SSPSTAT*8)+7;
volatile bit R                   @ ((unsigned)&SSPSTAT*8)+2;
volatile bit D                   @ ((unsigned)&SSPSTAT*8)+5;
volatile bit I2C_READ            @ ((unsigned)&SSPSTAT*8)+2;
volatile bit I2C_START           @ ((unsigned)&SSPSTAT*8)+3;
volatile bit I2C_STOP            @ ((unsigned)&SSPSTAT*8)+4;
volatile bit I2C_DATA            @ ((unsigned)&SSPSTAT*8)+5;
volatile bit nW                  @ ((unsigned)&SSPSTAT*8)+2;
volatile bit nA                  @ ((unsigned)&SSPSTAT*8)+5;
volatile bit nWRITE              @ ((unsigned)&SSPSTAT*8)+2;
volatile bit nADDRESS            @ ((unsigned)&SSPSTAT*8)+5;
volatile bit R_W                 @ ((unsigned)&SSPSTAT*8)+2;
volatile bit D_A                 @ ((unsigned)&SSPSTAT*8)+5;
volatile bit READ_WRITE          @ ((unsigned)&SSPSTAT*8)+2;
volatile bit DATA_ADDRESS        @ ((unsigned)&SSPSTAT*8)+5;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	BF                  : 1;
        unsigned	UA                  : 1;
        unsigned	R_nW                : 1;
        unsigned	S                   : 1;
        unsigned	P                   : 1;
        unsigned	D_nA                : 1;
        unsigned	CKE                 : 1;
        unsigned	SMP                 : 1;
    struct {
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
        unsigned	: 1;
    struct {
        unsigned	                    : 2;
        unsigned	R                   : 1;
        unsigned	: 2;
        unsigned	D                   : 1;
    struct {
        unsigned	: 2;
        unsigned	I2C_READ            : 1;
        unsigned	I2C_START           : 1;
        unsigned	I2C_STOP            : 1;
        unsigned	I2C_DATA            : 1;
    struct {
        unsigned	: 2;
        unsigned	nW                  : 1;
        unsigned	: 2;
        unsigned	nA                  : 1;
    struct {
        unsigned	: 2;
        unsigned	nWRITE              : 1;
        unsigned	: 2;
        unsigned	nADDRESS            : 1;
    struct {
        unsigned	: 2;
        unsigned	R_W                 : 1;
        unsigned	: 2;
        unsigned	D_A                 : 1;
    struct {
        unsigned	: 2;
        unsigned	READ_WRITE          : 1;
        unsigned	: 2;
        unsigned	DATA_ADDRESS        : 1;
} SSPSTATbits @ 0x094;
#endif
// Register: TXSTA
volatile unsigned char           TXSTA               @ 0x098;
volatile bit TX9D                @ ((unsigned)&TXSTA*8)+0;
volatile bit TRMT                @ ((unsigned)&TXSTA*8)+1;
volatile bit BRGH                @ ((unsigned)&TXSTA*8)+2;
volatile bit SYNC                @ ((unsigned)&TXSTA*8)+4;
volatile bit TXEN                @ ((unsigned)&TXSTA*8)+5;
volatile bit TX9                 @ ((unsigned)&TXSTA*8)+6;
volatile bit CSRC                @ ((unsigned)&TXSTA*8)+7;
volatile bit TXD8                @ ((unsigned)&TXSTA*8)+0;
volatile bit nTX8                @ ((unsigned)&TXSTA*8)+6;
volatile bit TX8_9               @ ((unsigned)&TXSTA*8)+6;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	TX9D                : 1;
        unsigned	TRMT                : 1;
        unsigned	BRGH                : 1;
        unsigned	                    : 1;
        unsigned	SYNC                : 1;
        unsigned	TXEN                : 1;
        unsigned	TX9                 : 1;
        unsigned	CSRC                : 1;
    struct {
        unsigned	TXD8                : 1;
        unsigned	: 5;
        unsigned	nTX8                : 1;
    struct {
        unsigned	: 6;
        unsigned	TX8_9               : 1;
} TXSTAbits @ 0x098;
#endif
// Register: SPBRG
volatile unsigned char           SPBRG               @ 0x099;
// Register: CMCON
volatile unsigned char           CMCON               @ 0x09C;
volatile bit CIS                 @ ((unsigned)&CMCON*8)+3;
volatile bit C1INV               @ ((unsigned)&CMCON*8)+4;
volatile bit C2INV               @ ((unsigned)&CMCON*8)+5;
volatile bit C1OUT               @ ((unsigned)&CMCON*8)+6;
volatile bit C2OUT               @ ((unsigned)&CMCON*8)+7;
volatile bit CM0                 @ ((unsigned)&CMCON*8)+0;
volatile bit CM1                 @ ((unsigned)&CMCON*8)+1;
volatile bit CM2                 @ ((unsigned)&CMCON*8)+2;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	CM                  : 3;
        unsigned	CIS                 : 1;
        unsigned	C1INV               : 1;
        unsigned	C2INV               : 1;
        unsigned	C1OUT               : 1;
        unsigned	C2OUT               : 1;
    struct {
        unsigned	CM0                 : 1;
        unsigned	CM1                 : 1;
        unsigned	CM2                 : 1;
} CMCONbits @ 0x09C;
#endif
// Register: CVRCON
volatile unsigned char           CVRCON              @ 0x09D;
volatile bit CVRR                @ ((unsigned)&CVRCON*8)+5;
volatile bit CVROE               @ ((unsigned)&CVRCON*8)+6;
volatile bit CVREN               @ ((unsigned)&CVRCON*8)+7;
volatile bit CVR0                @ ((unsigned)&CVRCON*8)+0;
volatile bit CVR1                @ ((unsigned)&CVRCON*8)+1;
volatile bit CVR2                @ ((unsigned)&CVRCON*8)+2;
volatile bit CVR3                @ ((unsigned)&CVRCON*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	CVR                 : 4;
        unsigned	                    : 1;
        unsigned	CVRR                : 1;
        unsigned	CVROE               : 1;
        unsigned	CVREN               : 1;
    struct {
        unsigned	CVR0                : 1;
        unsigned	CVR1                : 1;
        unsigned	CVR2                : 1;
        unsigned	CVR3                : 1;
} CVRCONbits @ 0x09D;
#endif
// Register: ADRESL
volatile unsigned char           ADRESL              @ 0x09E;
// Register: ADCON1
volatile unsigned char           ADCON1              @ 0x09F;
volatile bit ADCS2               @ ((unsigned)&ADCON1*8)+6;
volatile bit ADFM                @ ((unsigned)&ADCON1*8)+7;
volatile bit PCFG0               @ ((unsigned)&ADCON1*8)+0;
volatile bit PCFG1               @ ((unsigned)&ADCON1*8)+1;
volatile bit PCFG2               @ ((unsigned)&ADCON1*8)+2;
volatile bit PCFG3               @ ((unsigned)&ADCON1*8)+3;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	PCFG                : 4;
        unsigned	                    : 2;
        unsigned	ADCS2               : 1;
        unsigned	ADFM                : 1;
    struct {
        unsigned	PCFG0               : 1;
        unsigned	PCFG1               : 1;
        unsigned	PCFG2               : 1;
        unsigned	PCFG3               : 1;
} ADCON1bits @ 0x09F;
#endif
// Special function register definitions: Bank 2
// Register: EEDATA
volatile unsigned char           EEDATA              @ 0x10C;
// Register: EEADR
volatile unsigned char           EEADR               @ 0x10D;
// Register: EEDATH
volatile unsigned char           EEDATH              @ 0x10E;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 6;
} EEDATHbits @ 0x10E;
#endif
// Register: EEADRH
volatile unsigned char           EEADRH              @ 0x10F;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	                    : 5;
} EEADRHbits @ 0x10F;
#endif
// Special function register definitions: Bank 3
// Register: EECON1
volatile unsigned char           EECON1              @ 0x18C;
volatile bit RD                  @ ((unsigned)&EECON1*8)+0;
volatile bit WR                  @ ((unsigned)&EECON1*8)+1;
volatile bit WREN                @ ((unsigned)&EECON1*8)+2;
volatile bit WRERR               @ ((unsigned)&EECON1*8)+3;
volatile bit EEPGD               @ ((unsigned)&EECON1*8)+7;
#ifndef _LIB_BUILD
volatile union {
    struct {
        unsigned	RD                  : 1;
        unsigned	WR                  : 1;
        unsigned	WREN                : 1;
        unsigned	WRERR               : 1;
        unsigned	                    : 3;
        unsigned	EEPGD               : 1;
} EECON1bits @ 0x18C;
#endif
// Register: EECON2
volatile unsigned char           EECON2              @ 0x18D;
#endif
BigDog
